Creating a service on Angstrom to run a python script on power up works great. I tried to do the same with Debian but had no luck. Is this possible?
Mike
Mike
If you’re using a systemd-based Debian (like the current shipping version of BBB), create a file in /etc/systemd/system/ named example.service (for example)
It should contain the following
[Unit]
Description=Example of a service[Service]
Type=oneshot
ExecStart=/bin/bash -c ‘cd /home/example ; python example.py 2> example.err > example.out’
TimeoutSec=0
RemainAfterExit=yes[Install]
WantedBy=multi-user.target
then give the command
systemctl enable example.service
When you reboot, your script will execute.
Sorry but I’m doing something wrong. Not that familiar with Linux
This code works in Angstrom showing test on a small screen
