Debugging mediaplayer corruption issues
Mans wrote the NEON support for mplayer[1], a player to make use of
the omapfb overlays[2] and kernel patches to fix the overlay
driver[3].
The 720p mp4 version of Big Buck Bunny[5] almost plays in realtime at
500MHz with all this. The problem is that I'm seeing image corruption
during playback and I don't know where the problem lays: kernel, gcc,
glibc, ffmpeg, something else...
You can get a kernel, rootfs and static player binary from [4], see
the README on how to set vars in uboot to activate the overlay.
It would be great if we can track down this issue before the LRL demo
next week.
regards,
Koen
[1]
http://git.mansr.com/?p=ffmpeg.mru;a=blob;f=libavcodec/armv4l/simple_idct_neon.S;h=943e04fc2de8b15eb7452518915048b474ed7582;hb=refs/heads/arm-neon
[2] http://git.mansr.com/?p=omapfbplay;a=summary
[3] http://gitweb.openembedded.net/?p=org.openembedded.dev.git;a=commit;h=c7be2f3d0445df58161d089994d301a3491d55ea
[4] http://amethyst.openembedded.net/~koen/beagleboard/overlay/
[5] http://www.bigbuckbunny.org/index.php/download/
If forgot to mention that it looks like this:
http://amethyst.openembedded.net/~koen/beagleboard/beagle-image-corruption.avi
driver[3].
next week.
Do you get the corruption with MPlayer or with my player (or both)?
both
regards,
Koen
koen wrote:
koen wrote:
> Hi,
> driver[3].
> next week.
both
OK, next step. How did you build FFmpeg? Which compiler?
Openembedded-Hotels, Villen, Unterkünfte in Leipzig
looking at the video, I would say the corruption is at a macroblock level, so I would say the decoding is not OK.
You can see some "trails" of broken content moving with the motion, so reference frames are getting corrupted.
ffmpeg has a regression test that compares output bitstreams vs "known good", did you run that on the platform?
Since the corruption is mostly confined to areas with motion, I would
suspect the motion compensation related functions.
Even if someone did have the patience to run the regression tests on ARM,
they would fail due to some subtle differences somewhere, resulting in
harmless +-1 differences in the output frames.
The odd thing is, the code works perfectly on my Beagle.
koen wrote:
>> koen wrote:
>> > Hi,
>> > driver[3].
>> > next week.
> both
Built with OE, gcc 4.3.1, I'm doing a build from scratch with
csl2007q3 now.
regards,
Koen
csl2007q3 now.
just a side note, 2007q3 has a bug with -Os on the OMAP3, 2008q1 fixes this.
koen wrote:
koen wrote:
>> koen wrote:
>> > Hi,
>> > driver[3].
>> > next week.
> both
csl2007q3 now.
I don't trust gcc 4.3 the slightest bit. I've been using csl2007q3
all along.
csl2007q3 now.
fixes this.
Does 2008q1 work properly with NEON? I heard reports it was
somehow broken, and didn't bother testing it myself.
With 2008q1:
- Vectorization + NEON is broken
- building static binaries with cortex-a8 flag (or any ARMv7a core) is broken
- some armv6 compilations end in ICE.
This looks too bad to even consider using it.
Laurent
Laurent Desnogues wrote:
Is that patch public?
regards,
Koen
koen wrote:
>> koen wrote:
>> >> koen wrote:
>> >> > Hi,
>> >> > driver[3].
>> >> > next week.
>> > both
> csl2007q3 now.
all along.
A build with 2007q3 makes it work without image corruption :slight_smile:
koen <koen.kooi@gmail.com> writes:
Great job, congrats all…
0
koen <koen.k...@gmail.com> writes:
>> koen wrote:
>> >> koen wrote:
>> >> >> koen wrote:
>> >> >> > Hi,
>> >> >> > driver[3].
>> >> >> > next week.
>> >> > both
>> > csl2007q3 now.
>> all along.
That's good news. If it can't compile the kernel, I don't trust it.
FFmpeg is quite good at triggering compiler bugs.
This commit: http://git.mansr.com/?p=ffmpeg.mru;a=commitdiff;h=14a339339ad6b9cfd00da21557c9c5d17cc6a372
also fix the bug with gcc 4.3.1.
regards,
Koen
> With 2008q1:
to clarify, we just picked one patch from 2008q1 into 2007q3 which fixed -Os.
--- arm-2007q3-51-arm-uclinuxeabi/gcc-4.2/gcc/config/arm/arm.c 2007-09-27 17:51:00.000000000 +0200
+++ arm-2008q1-152-arm-uclinuxeabi/gcc-4.2/gcc/config/arm/arm.c 2008-04-18 03:44:35.000000000 +0200
@@ -11591,7 +11647,8 @@
                   && count != 0
                   && !current_function_calls_eh_return
                   && bit_count(saved_regs_mask) * 4 == count
- && !IS_INTERRUPT (func_type))
+ && !IS_INTERRUPT (func_type)
+ && !cfun->tail_call_emit)
                   unsigned long mask;
                   mask = (1 << (arm_size_return_regs() / 4)) - 1;
