Carrying on from the SeeedStudio SenseCAP Gateway hacking form this conversation (https://groups.google.com/g/beagleboard/c/Y_Zx_D2HJUA)
I am now looking to get the LoRa interface working, the interface is a mPCIe SPI RAK2247 LoRa card connector.
The things I think I need to find out how to do:
Identify the correct SPI bus for the connector;
and what GPIO drives the reset pin (PIN 22) of the connector.
if anyone has any ideas on the best why to do this, please feel free to share.
result of gpioinfo:
gpiochip0 - 32 lines:
line 0: “MDIO_DATA” unused input active-high
line 1: “MDIO_CLK” unused input active-high
line 2: “SPI0_SCLK” “P9_22” input active-high [used]
line 3: “SPI0_D0” “P9_21” input active-high [used]
line 4: “SPI0_D1” “P9_18” input active-high [used]
line 5: “SPI0_CS0” “P9_17” input active-high [used]
line 6: “SPI0_CS1” “cd” input active-low [used]
line 7: “ECAP0_IN_PWM0_OUT” “P9_42” input active-high [used]
line 8: “LCD_DATA12” “P8_35” input active-high [used]
line 9: “LCD_DATA13” “P8_33” input active-high [used]
line 10: “LCD_DATA14” “P8_31” input active-high [used]
line 11: “LCD_DATA15” “P8_32” input active-high [used]
line 12: “UART1_CTSN” “P9_20” input active-high [used]
line 13: “UART1_RTSN” “P9_19” input active-high [used]
line 14: “UART1_RXD” “P9_26” input active-high [used]
line 15: “UART1_TXD” “P9_24” input active-high [used]
line 16: “GMII1_TXD3” unused input active-high
line 17: “GMII1_TXD2” unused input active-high
line 18: “USB0_DRVVBUS” unused input active-high
line 19: “XDMA_EVENT_INTR0” “A15” input active-high [used]
line 20: “XDMA_EVENT_INTR1” “P9_41” input active-high [used]
line 21: “GMII1_TXD1” unused input active-high
line 22: “GPMC_AD8” “P8_19” input active-high [used]
line 23: “GPMC_AD9” “P8_13” input active-high [used]
line 24: “NC” unused input active-high
line 25: “NC” unused input active-high
line 26: “GPMC_AD10” unused input active-high
line 27: “GPMC_AD11” unused input active-high
line 28: “GMII1_TXD0” unused input active-high
line 29: “RMII1_REFCLK” unused input active-high
line 30: “GPMC_WAIT0” “P9_11” input active-high [used]
line 31: “GPMC_WPN” “P9_13” input active-high [used]
gpiochip1 - 32 lines:
line 0: “GPMC_AD0” “P8_25” input active-high [used]
line 1: “GPMC_AD1” “P8_24” input active-high [used]
line 2: “GPMC_AD2” “P8_05” input active-high [used]
line 3: “GPMC_AD3” “P8_06” input active-high [used]
line 4: “GPMC_AD4” “P8_23” input active-high [used]
line 5: “GPMC_AD5” “P8_22” input active-high [used]
line 6: “GPMC_AD6” “P8_03” input active-high [used]
line 7: “GPMC_AD7” “P8_04” input active-high [used]
line 8: “UART0_CTSN” unused input active-high
line 9: “UART0_RTSN” unused input active-high
line 10: “UART0_RXD” unused input active-high
line 11: “UART0_TXD” unused input active-high
line 12: “GPMC_AD12” “P8_12” input active-high [used]
line 13: “GPMC_AD13” “P8_11” input active-high [used]
line 14: “GPMC_AD14” “P8_16” input active-high [used]
line 15: “GPMC_AD15” “P8_15” input active-high [used]
line 16: “GPMC_A0” “P9_15” input active-high [used]
line 17: “GPMC_A1” “P9_23” input active-high [used]
line 18: “GPMC_A2” “P9_14” input active-high [used]
line 19: “GPMC_A3” “P9_16” input active-high [used]
line 20: “GPMC_A4” unused input active-high
line 21: “GPMC_A5” “beaglebone:green:usr0” output active-high [used]
line 22: “GPMC_A6” “beaglebone:green:usr1” output active-high [used]
line 23: “GPMC_A7” “beaglebone:green:usr2” output active-high [used]
line 24: “GPMC_A8” “beaglebone:green:usr3” output active-high [used]
line 25: “GPMC_A9” unused input active-high
line 26: “GPMC_A10” unused input active-high
line 27: “GPMC_A11” unused input active-high
line 28: “GPMC_BE1N” “P9_12” input active-high [used]
line 29: “GPMC_CSN0” “LS_BUF_EN” output active-high [used]
line 30: “GPMC_CSN1” “P8_21” input active-high [used]
line 31: “GPMC_CSN2” “P8_20” input active-high [used]
gpiochip2 - 32 lines:
line 0: “GPMC_CSN3” unused input active-high
line 1: “GPMC_CLK” “P8_18” input active-high [used]
line 2: “GPMC_ADVN_ALE” “P8_07” input active-high [used]
line 3: “GPMC_OEN_REN” “P8_08” input active-high [used]
line 4: “GPMC_WEN” “P8_10” input active-high [used]
line 5: “GPMC_BE0N_CLE” “P8_09” input active-high [used]
line 6: “LCD_DATA0” “P8_45” input active-high [used]
line 7: “LCD_DATA1” “P8_46” input active-high [used]
line 8: “LCD_DATA2” “P8_43” input active-high [used]
line 9: “LCD_DATA3” “P8_44” input active-high [used]
line 10: “LCD_DATA4” “P8_41” input active-high [used]
line 11: “LCD_DATA5” “P8_42” input active-high [used]
line 12: “LCD_DATA6” “P8_39” input active-high [used]
line 13: “LCD_DATA7” “P8_40” input active-high [used]
line 14: “LCD_DATA8” “P8_37” input active-high [used]
line 15: “LCD_DATA9” “P8_38” input active-high [used]
line 16: “LCD_DATA10” “P8_36” input active-high [used]
line 17: “LCD_DATA11” “P8_34” input active-high [used]
line 18: “GMII1_RXD3” unused input active-high
line 19: “GMII1_RXD2” unused input active-high
line 20: “GMII1_RXD1” unused input active-high
line 21: “GMII1_RXD0” unused input active-high
line 22: “LCD_VSYNC” “P8_27” input active-high [used]
line 23: “LCD_HSYNC” “P8_29” input active-high [used]
line 24: “LCD_PCLK” “P8_28” input active-high [used]
line 25: “LCD_AC_BIAS_EN” “P8_30” input active-high [used]
line 26: “MMC0_DAT3” unused input active-high
line 27: “MMC0_DAT2” unused input active-high
line 28: “MMC0_DAT1” unused input active-high
line 29: “MMC0_DAT0” unused input active-high
line 30: “MMC0_CLK” unused input active-high
line 31: “MMC0_CMD” unused input active-high
gpiochip3 - 32 lines:
line 0: “GMII1_COL” unused input active-high
line 1: “GMII1_CRS” unused input active-high
line 2: “GMII1_RXER” unused input active-high
line 3: “GMII1_TXEN” unused input active-high
line 4: “GMII1_RXDV” unused input active-high
line 5: “I2C0_SDA” unused input active-high
line 6: “I2C0_SCL” unused input active-high
line 7: “EMU0” unused input active-high
line 8: “EMU1” unused input active-high
line 9: “GMII1_TXCLK” unused input active-high
line 10: “GMII1_RXCLK” unused input active-high
line 11: “NC” unused input active-high
line 12: “NC” unused input active-high
line 13: “USB1_DRVVBUS” unused input active-high
line 14: “MCASP0_ACLKX” “P9_31” input active-high [used]
line 15: “MCASP0_FSX” “P9_29” input active-high [used]
line 16: “MCASP0_AXR0” “MCASP0_AHCLKR” output active-high [used]
line 17: “MCASP0_AHCLKR” “P9_28” input active-high [used]
line 18: “MCASP0_ACLKR” “P9_92” input active-high [used]
line 19: “MCASP0_FSR” “P9_27” input active-high [used]
line 20: “MCASP0_AXR1” “P9_91” input active-high [used]
line 21: “MCASP0_AHCLKX” “P9_25” input active-high [used]
line 22: “NC” unused input active-high
line 23: “NC” unused input active-high
line 26: “NC” unused input active-high
line 27: “NC” unused input active-high
line 28: “NC” unused input active-high
line 29: “NC” unused input active-high
line 30: “NC” unused input active-high
line 31: “NC” unused input active-high
