What’s the best way to detect a change in value on a GPIO configured as OUT?
It may sound really weird why one may need that. I have a custom cape and cannot make changes to its hardware, but I need to improve certain functionality.
poll(2) on /sys/class/gpio/gpioXY/value exits with timeout.
To avoid any XY-problem I’ll explain the actual situation:
The BBB’s native RS-485 mode works fine with omap_serial driver, however, I cannot use actual hardware pins for RTS (RE/DE) because the above mentioned cape consumes all possibilities.
So, I assigned an unconnected GPIO to be the RTS and want to detect its state changes in a timing-critical application (tcdrain() takes too long).
I’m pretty sure that you can just always read the “value” inside the GPIO tree using a file read command.
So for example if you try to set the pin a certain way and it didn’t change (strong pull or short) the value read still reflects the actual state.
Put the read function in its own separate thread in a loop with a task delay resolution to match the baud rate.
Then you are done, assuming the output pin read does actually work that way.
If not you can try setting input mode, read the value, then set output mode right after you are done reading.
I think your project is a prime candidate to use the PRU Cortex-M that is included in the BBB for this type of stuff. While I have worked on many Cortex-Ms over the years, I haven’t yet tried to use the PRU so you will need to search this board for help setting that up.
They do have the new free toolchain option for it.
