I am toggling the input into a GPIO line on my BeagleBone from high to low every 500 ms using an Atmel uC. I have registered a handler for this in my Linux Kernel Module, but the handler is not being called for some reason.
My module code is -
#define GPIO 54
#define GPIO_INT_NAME "gpio_int"
#define GPIO_HIGH gpio_get_value(GPIO)
#define GPIO_LOW (gpio_get_value(GPIO) == 0)
short int irq_any_gpio = 0;
int count =0;
enum { falling, rising } type;
static irqreturn_t r_irq_handler(int irq, void *dev_id)
count++;
printk(KERN_DEBUG "interrupt received (irq: %d)\n", irq);
if (irq == gpio_to_irq(GPIO))
type = GPIO_LOW ? falling : rising;
if(type == falling)
printk("gpio pin is low\n");
else
printk("gpio pin is high\n");
return IRQ_HANDLED;
void r_int_config(void) {
if (gpio_request(GPIO, GPIO_INT_NAME ))
printk("GPIO request failure: %s\n", GPIO_INT_NAME );
return;
if ( (irq_any_gpio = gpio_to_irq(GPIO)) < 0 ) {
printk("GPIO to IRQ mapping failure %s\n",GPIO_INT_NAME );
return;
printk(KERN_NOTICE "Mapped int %d\n", irq_any_gpio);
if (request_irq(irq_any_gpio,(irq_handler_t ) r_irq_handler, IRQF_TRIGGER_HIGH, GPIO_INT_NAME, NULL))
printk("Irq Request failure\n");
return;
return;
void r_int_release(void) {
free_irq(gpio_to_irq(GPIO), NULL);
gpio_free(GPIO);;
return;
int init_module(void)
printk("<1>Hello World\n");
r_int_config();
return 0;
On calling insmod interrupt_test.ko, i get the following message
[ 76.594543] Hello World
[ 76.597137] Mapped int 214
But now when I start toggling the input into this gpio pin, the interrupt handler doesn’t get called and the message - “interrupt received” is not being displayed.
How do I solve this ? What’s causing the problem?
