Can someone point me to the source code for the HDMI and HDMI-Audio device trees?
I’ve run into an odd situation where when booting Ubuntu under the latest Robert Nelson 3.8 kernel, the HDMI-Audio device tree fails to load when the BBB is plugged into the ethernet network at bootup. I seem to get a complaint about the pin for the clock already being in use - which makes sense since I believe the ethernet interface also requires that same clock and probably enables it. I was thinking I could test my theory by dropping that pin from the source and compiling a new DTBO to test - but I can’t find the sourcecode for that one.
