Matt3
May 9, 2016, 6:12pm
1
In the process of migrating from 3.8.x to 4.1.21 and trying to get my device tree to load manually (eventually to load on boot).
As I understand it device trees are supported in 4.1.x – yes?
I the the .dts compiles with out errors however when I go to load the device tree I get the following:
echo BB-APA-01 > slots
[ 8122.326385] bone_capemgr bone_capemgr: part_number ‘BB-APA-01’, version ‘N/A’
[ 8122.333614] bone_capemgr bone_capemgr: slot #5: override
[ 8122.339116] bone_capemgr bone_capemgr: Using override eeprom data at slot 5
[ 8122.346184] bone_capemgr bone_capemgr: slot #5: ‘Override Board Name,00A0,Override Manuf,BB-APA-01’
[ 8122.369433] __of_changeset_entry_apply: add_property failed @/ocp/serial@481aa000/pinctrl-names
[ 8122.378353] of_changeset_apply: Error applying changeset (-17)
[ 8122.384609] __of_overlay_create: of_changeset_apply() failed for tree@/
[ 8122.391429] bone_capemgr bone_capemgr: slot #5: Failed to create overlay
-bash: echo: write error: File exists
My dts file is essentially the same as I had it in 3.8.x except for changing uart numbers to index from 0 instead of 1 as I’ve read that changed.
This custom device tree uses pins reserved for HDMI so I did added teh disable option to /boot/uEnv.txt:
cape_disable=capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN
What else do I need to update in my .dts or do to get a custom device tree to load?
As I understand it device trees are supported in 4.1.x -- yes?
[ 8122.326385] bone_capemgr bone_capemgr: part_number 'BB-APA-01', version
'N/A'
slot 5
[ 8122.346184] bone_capemgr bone_capemgr: slot #5: 'Override Board
Name,00A0,Override Manuf,BB-APA-01'
This also could me you used the wrong dtc compiler..
Use the one this one builds:
changing uart numbers to index from 0 instead of 1 as I've read that
changed.
this ^ doesn't do anything..
Read, section: BBB compatibility issues:
Matt3
May 9, 2016, 7:33pm
3
Yes I do believe I have the right version – as I followed your instructions in bb.org-overlays
here is the result of a version check:
root@arm:/lib/firmware# dtc --version
Version: DTC 1.4.1-g1e75ebc9
To compile an overlay I did
dtc -O dtb -o BB-APA-01-00A0.dtbo -b 0 -@ BB-APA-01-00A0.dts
Then I placed the output in /lib/firmware
Referring to https://github.com/beagleboard/bb.org-overlays/blob/master/readme.md
I changed my uEnv.txt to contain
dtb=am335x-boneblack-emmc-overlay.dtb
Stll getting this:
[ 229.625505] bone_capemgr bone_capemgr: part_number ‘BB-APA-01’, version ‘N/A’
[ 229.633234] bone_capemgr bone_capemgr: slot #4: override
[ 229.638620] bone_capemgr bone_capemgr: Using override eeprom data at slot 4
[ 229.655322] bone_capemgr bone_capemgr: slot #4: ‘Override Board Name,00A0,Override Manuf,BB-APA-01’
[ 229.676441] __of_changeset_entry_apply: add_property failed @/ocp/serial@481aa000/pinctrl-names
[ 229.676462] of_changeset_apply: Error applying changeset (-17)
[ 229.695456] __of_overlay_create: of_changeset_apply() failed for tree@/
[ 229.702544] bone_capemgr bone_capemgr: slot #4: Failed to create overlay
sh: echo: I/O error
Matt3
May 9, 2016, 11:25pm
4
Fixed this issue – was a <&uart*> number I missed changing… doh
I can now manually add the device tree :
cat /sys/devices/platform/bone_capemgr/slots
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
4: P-O-L- 0 Override Board Name,00A0,Override Manuf,BB-APA-00A0,Override Manuf,BB-APA-01
How do I bake this into my kernel such that it loads at boot?
sudo update-initramfs -uk `uname -r`
*.dtbo's from /lib/firmware/ get copied to the initramfs..
then add BB-APA-01 into /boot/uEnv.txt under the v4.1.x kernel section on
loading overlays..
Matt3
May 9, 2016, 11:59pm
6
Got the command to go but don’t quite follow you on the
then add BB-APA-01 into /boot/uEnv.txt under the v4.1.x kernel section on loading overlays…
My uEnv.txt looks like this right now:
cat /boot/uEnv.txt
uname_r=4.1.23-ti-rt-r60
uuid=8b83ed28-d947-4fda-b607-d5c5faf3dbe5
Am I missing something here in uEnv.txt?
Do I simply add this to /boot/uEnv.txt:
bone_capemgr.enable_partno=BB-APA-01
cape_enable=bone_capemgr.enable_partno=BB-APA-01
Matt3
May 10, 2016, 3:59pm
8
As always thanks for the help Robert!
That solved it!
