hi.
1. i try to use u-boot-2011.03.
commands:
--- 8< ---
make CROSS_COMPILE=arm-none-linux-gnueabi- devkit8000_config
--- 8< ---
copy u-boot.bin on a sd and try to boot from card:
--- 8< ---
Starting OS Bootloader from MMC...
U-Boot 2011.03 (May 27 2011 - 00:45:22)
OMAP3530-GP ES3.1, CPU-OPP2, L3-165MHz, Max CPU Clock 600 mHz
OMAP3 DevKit8000 + LPDDR/NAND
I2C: ready
DRAM: 256
--- 8< ---
2. i try compile linux kernel from linux-omap-devkit8000
--- 8< ---
make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- distclean
make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- devkit8000_defconfig
make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- uImage
--- 8< ---
copy arch/arm/boot/uImage on a sd and boot (with u-boot 1.3.3):
--- 8< ---
Texas Instruments X-Loader 1.41
Starting OS Bootloader...
U-Boot 1.3.3 (Dec 21 2010 - 16:13:44)
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
OMAP3 DevKit8000 Board + LPDDR/NAND
DRAM: 256 MB
NAND: 256 MiB
Using default environment
In: serial
Out: serial
Err: serial
NAND read: device 0 offset 0x280000, size 0x240000
2359296 bytes read: OK
## Booting kernel from Legacy Image at 80300000 ...
Image Name: Linux-2.6.38-rc1-g34a02d2-dirty
Data Size: 2393988 Bytes = 2.3 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... Bad Data CRC
ERROR: can't get kernel image!
OMAP3 DevKit8000 #
--- 8< ---
what i do not so? where i can find some howto with the assemblage description?
ps. i wish to use new kernel with angstrom rootfs, xorg and tcl, but i can't...
