I've been working on loading images into RAM using DFU on the
BeagleBoard-xM. It seemed that there were several bitrotting patches
around. I've merged the best of each into something that works for
me for loading images into RAM on the -xM (but flash support is
broken and untested).
For posterity, attached is a patch against u-boot releases 2010.12
and 2011.03-rc1 (applies to either). It's still not in a clean
enough state for merging into u-boot, but I thought this list may
appreciate it.
I've had to revert to an older version of the musb_udc driver to get
it working, as the one in mainline u-boot seems to have a broken
state machine (which I was able to fix), and did not support High
Speed gadget mode (which I couldn't easily fix).
Rhe warning message about dfu-util should be nothing to worry about. FTR, I've used the dfu-util that comes with both Ubuntu Maverick (10.10) and Debian Lenny (5.0).
Can you try dropping the transfer size down by passing -t 0x40 to dfu-util? Try powers of two between 32 (0x20) and 4096 (0x1000). It might be that your USB host controller or driver has issues with larger frames on EP0.
Rick and I resolved this issue off-list. It turns out that the patch
did not correctly populate one of the fields used by newer versions
of dfu-util (specifically, bwPollTimeout). This version fixes it.
