Long story short, I am refactoring an application I had originally written for Raspbian. One of the features is the ability to modify the devices network settings (either use DHCP or set a static IP).
When refactoring this for the Begalebone, I was running into weird issues that I assume were happening because of conman. After many hours I stumbled into installing DHCPCD5.
I then added eth0 to NetworkInterfaceBlacklist in /etc/conman/main.conf
I modified /etc/network/interfaces to be
interfaces(5) file used by ifup(8) and ifdown(8)
Please note that this file is written to be used with dhcpcd
For static IP, consult /etc/dhcpcd.conf and ‘man dhcpcd.conf’
Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
Then, programatically, I was able to switch between dhcp and static settings as I expected with my application.
I then noticed in /var/log/syslog that I was getting a TON of logged messages related to can0 and can1.
I added can0 and can1 to conman/main.conf NetworkInterfaceBlacklist
I added denyinterfaces can0 can1 in /etc/dhcpcd.conf
I thought I had this resolved after the two steems above but it seems that is not the case.
What else can I do to keep this behavior from occurring? The issue is causing a noticeable lag when SSH’ed into my beaglebone or using the web interface I am running on it. Not to mention the file space it is consuming.
If DHCPCD is not a viable candidate, how can I get more predictable behavior out of conman? (Issues I was running into included changing settings in /network/interfaces did not alsways respond as expected, issues with configuring a fallback static IP when DHCP failed, etc.)
BTW I am running the Debian 8.7 IoT image (need it in order to run mongodb on the beaglebone)
