If I just tap the power button on the BBBW, it immediately begins the shutdown sequence. We need to avoid that behavior; it seems the way to do so is to disable the PB-state change IRQ (from the TPS65217 datasheet):
8.6.4 Interrupt Register (INT) (Address = 0x02) [reset = 0x80]
Bit 6: PBM R/W 0b = Interrupt is issued when PB status changes.
Bit 6: PBM R/W 1b = No interrupt is issued when PB status changes.
The bit is cleared:
i2cget -f -y 0 0x24 0x2
0x20
A similar post from 2017 didn’t really seem to have a resolution:
“Disabling PowerOff and Reset button” https://groups.google.com/g/beagleboard/c/4qv0osguaDI/m/0ITntryPAQAJ
I’ve followed a similar path, outlined in more detail below, without being able to disable the PB IRQ, either.
Thanks for any assistance.
The hardware is a BBBW with a 4D Systems gen4 cape and LCD.
$ uname -a
Linux beaglebone 4.19.94-ti-r43 #1buster SMP PREEMPT Wed Apr 22 06:11:16 UTC 2020 armv7l GNU/Linux
The image is from https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Debian_Buster_LXQt_Snapshot , as it works with the LCD out-of-the-box.
- start with RCN’s DT repo:
git clone https://github.com/beagleboard/BeagleBoard-DeviceTreespushd ~/BeagleBoard-DeviceTrees-
fgrep -rni . -e 'tps65217-pwrbutton'
./src/arm/tps65217.dtsi:27: compatible = "ti,tps65217-pwrbutton"; -
nano ./src/arm/tps65217.dtsi
comment out thepwrbuttonnode
pwrbutton {
interrupts = <2>;
status = "disabled";
Note that it doesn’t matter if the above file is modified, or the one below, or both. In no case is the PB IRQ disabled.
edit the common BB file,
am335x-bone-common.dtsi, to disable thepwrbutton -
pushd ~/BeagleBoard-DeviceTrees -
nano -l ./src/arm/am335x-bone-common.dtsi -
the line to edit is ~365
change status from
okaytodisabled:
pwrbutton {
- build the dtb files:
make - back up the current dtb file, then copy the new dtb file
debian@beaglebone:~/BeagleBoard-DeviceTrees$ sudo mv /boot/dtbs/4.19.94-ti-r43/am335x-boneblack-wireless.dtb /boot/dtbs/4.19.94-ti-r43/am335x-boneblack-wireless.bak.dtb
debian@beaglebone:~/BeagleBoard-DeviceTrees$ sudo cp ./src/arm/am335x-boneblack-wireless.dtb /boot/dtbs/4.19.94-ti-r43/am335x-boneblack-wireless.dtb
- Compare the resulting dtb file with the original:
- the entire
pwrbuttonsection commented out intps65217.dtsi -
pwrbuttonset todisabledinam335x-bone-common.dtsi
$ dtdiff /boot/dtbs/4.19.94-ti-r43/am335x-boneblack-wireless.bak.dtb /boot/dtbs/4.19.94-ti-r43/am335x-boneblack-wireless.dtb
--- /dev/fd/63 2020-10-28 02:56:38.720410323 +0000
+++ /dev/fd/62 2020-10-28 02:56:38.720410323 +0000
@@ -280,7 +280,7 @@
chosen {
base_dtb = "am335x-boneblack-wireless.dts";
- base_dtb_timestamp = "Wed Apr 22 06:09:34 2020";
+ base_dtb_timestamp = "Tue Oct 27 19:48:20 2020";
stdout-path = "/ocp/serial@44e09000";
@@ -851,9 +851,7 @@
pwrbutton {
- compatible = "ti,tps65217-pwrbutton";
- interrupts = < 0x02 >;
- status = "okay";
+ status = "disabled";
regulators {
- check IRQ’s:
$ cat /proc/interrupts | grep 65217
142: 0 INTC 7 Level tps65217-irq
144: 0 tps65217 0 Edge vbus
145: 0 tps65217 2 Edge tps65217_pwr_but
