Using the latest “Debian 9.3 2018-01-28 4GB SD IoT”, I’d like to disable routing between any of the interfaces. If I have wlan0 configured to connect to the internet, I don’t want being connected to the SoftAP to give me internet access. I plan to install a 4G module and I definitely don’t want the BB to become an internet access point. I just want to use the SoftAP as an easy way to access the BB (ssh and web).
Thanks.
SoftAP is controlled thru /etc/default/bb-wl18xx
If I set TETHER_ENABLED=no, then I lose the SoftAP interface completely. I still want the SoftAP, I just don’t want data to be routed between the SoftAP and wlan0 (or 4G or USB eth0, etc).
I am not very familiar with it, but is it something in iptables? Initially it was:
debian@beaglebone:~$ sudo iptables -S
-P INPUT ACCEPT
-P FORWARD ACCEPT
-P OUTPUT ACCEPT
-A FORWARD -i wlan0 -o SoftAp0 -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -i SoftAp0 -o wlan0 -j ACCEPT
I tried removing the last two lines to make it:
-P INPUT ACCEPT
-P FORWARD ACCEPT
-P OUTPUT ACCEPT
But, that still didn’t stop internet access while connected to the SoftAP.
Thanks.
i think..
iptables -A INPUT -i SoftAp0 -p tcp ! --dport 22 -j DROP
then you can ssh into SoftAP0...
That works if I only wanted SSH, but I still want to be able to access the webserver on the BB.
If I add another rule for port 80, we’re back to square one where it routes incoming web requests on SoftAP to wlan0.
