Display problem in Angstrom linux on Beagle Xm Ver B
Hi
I have sucessfully tested ubuntu on beaglebeard Xm Ver B but it is too
slow even with the mpu rate tweak so i decided to go for Angstrom
linux which i have already tested on my previous Beagleboard Ver C3.
Now when i install the image on my sd card and insert into Beagleboard
Xm Ver B and power on.
I see the debug messages on my PC and the beagleboard Xm ver B boots
ok till the login prompt but i dont see any display. My display shows
a message
'Out of Range'
which means i have to set the resolution but this resolution worked
fine on ubuntu natty on my beagle Xm Ver B. The boot.scr is as given
below which is working when i put ubuntu natty.
   fatload mmc 0:1 0x80000000 uImage
    fatload mmc 0:1 0x81600000 uInitrd
    setenv bootargs vram=12M omapfb.mode=dvi:1280x720MR-16@60
mpurate=800 root=/dev/mmcblk0p2 fixrtc quiet splash
    bootm 0x80000000 0x81600000
whether i will have to change this for Angstrom linux. my Angstrom
linux demo image is Angstrom 2009.X.test-20100309. I am using this
image as i have successfully run this on my earlier Beagleboard Ver
C3. And i am able to run my application fine without any problem.
Please guide me what am doing wrong.
Thanks in Advance.
Anuj.
why don’t you take the latest images ? yours seem to be pretty old
hi
I wanted to use the same image because it do not want a heavy system.
I want a system with minimal applications and speed is also a factor
which the old image gives me. As i am using Beagle Xm it is very fast
with old image. But the latest image takes time to boot and it has all
unnecessary applications which i do not want. I just want a minimal
system with Ethernet working and a very lite one.
if there are images which are lite mainly Angstrom linux or ubuntu if
it is faster than angstrom which is not the case i think, please send
me the link of such a image.
Anuj.
