What brand of LCD display are you using? We have seen some displays that have trouble picking up some of the colors after a period of time. The same board that looks bad on one display will look great on 10 other displays.
No, we can fix it. It requires replacing the TFP410. I would request an RMA and get it repaired. This happens sometrimes when you plug in the DVI cable before you power up the board. It causes the output level to drop over time by a few millivolts which makes it tough to pick up the levels on certain LCD panels.
What was described was just one color missing. If the symptoms are different, then it may be that issue. It is worth a try before sending the board back for repair.
