boardzoo offers a 128x128 spi display cape found here:
http://boardzoo.com/index.php/minidisplay-cape.html
I know that the adafruit ST7735R based display found here:
https://www.adafruit.com/products/358
Is documented as working complete with wiring diagram and instructions here:
http://elinux.org/images/1/19/Passing_Time_With_SPI_Framebuffer_Driver.pdf
will the boardzoo minidisplay cape referenced above work with the same driver as the adafruit st7735R based display? What needs tweaked to make the boardzoo minidisplay cape work? Will the boardzoo minidisplay cape work plug n play? is there a device tree overlay for either of these displays? once these displays are working via framebuffer can they be used to support both text console and graphical display modes?
Eric
