Hello All
I already have manually installed & working Opencv 2.3.1 on my ubuntu 11.04 and I am following Opencv-DSP Accelration tutorial which have step of bitbake Opencv.
When I did ``bitbake -f -c configure opencv ,new opencv 2.3.1 folder created. But when I did bitbake opencv, I am getting errors. Is it because the system already have opencv 2.3.1 ?
DO I need to Uninstall first copy of opencv 2.3.1 to run bitbkae opencv successfully ? if bitbake opencv giving me error, Can I manually make & make install in new Opencv 2.3.1 folder to build ?
Hello Gary,
I solved that problem by sudo apt-get install libacl1-dev
find new generated libacl.la, libacl.a, libacl.so.1 and other libacl related files. Copy all these files and paste into the folder where system was not able to find these files.
So bitbake ti-linuxutils built successfully.
I am running bitbake opencv right now. I will let you know progress. Thanks for direction.
Hello All
When I did bitbake -f -c configure opencv ,new opencv 2.3.1 folder created. But when I did bitbake opencv, I am getting errors. Is it because the system already have opencv 2.3.1 ?
folder to build ?
It looks like you are missing some dependencies, I think ti-linuxutils in particular.
Try this sequence:
% bitbake ti-linuxutils
% bitbake opencv
Hi Gary,
I tried to run bitbake ti-linuxutils.But I am ended up with folloowing error http://pastebin.com/KRgfjyPq
looks like libacl packages are missing. What do you suggest ?
Hello Gary,
Hello Gary,
When I did run bitbake Opencv, I got following errors. I tried most of options but giving same error.
…/…/lib/libopencv_core.so.2.3.1: undefined reference to CMEM_init' ../../lib/libopencv_core.so.2.3.1: undefined reference to CMEM_alloc’
…/…/lib/libopencv_core.so.2.3.1: undefined reference to CMEM_free' collect2: ld returned 1 exit status make[2]: *** [bin/opencv_test_core] Error 1 make[2]: Leaving directory /home/metrans/setup-scripts/build/tmp-angstrom_2010_x-eglibc/work/armv7a-angstrom-linux-gnueabi/opencv-2.3.1-r3/opencv’
make[1]: *** [modules/core/CMakeFiles/opencv_test_core.dir/all] Error 2
