After trying to cross-compile with the hard float library without success, I finally use the soft float library and it work.
I would like to check if the cause is really the hard float.
I’m using the default Angstrom distribution. Does it use soft float and how to check that ?
If Angstrom distribution doesn’t use hard float, why ?
Regards
As I think this a sane question (ie : everyone should ask himself/herself this ) I answer you that :
- the BBB is based on the AM335x
- This last is itself is based on Cortex A8
Therefore if you dig into the A8 arm documentation CortexA_ProgGuide.pdf that you can easily download from Arm website ( free account is required)
you’ll see :
If your target platform supports hardware floating-point or NEON, specify this to ensure that
the compiler can make use of these instructions. For a Cortex-A5 target, you would specify
–mfpu=neon-vfpv4.
-mfloat-abi=
This option specifies the floating-point ABI to use. Values for are:
soft causes GCC to generate code containing calls to the software floating-point
library for floating-point operations.
softfp enables GCC to generate code containing hardware floating-point instructions,
but still uses the software floating-point linkage.
hard enables GCC to generate code containing hardware floating-point instructions
and uses FPU-specific hardware floating-point linkage.
The default depends on the target configuration. You must compile your entire program with the
same ABI, and link with a compatible set of libraries.
Table 19-1 shows a few examples of code generation for floating-point operations.
19.1.5 armcc optimization options
The armcc compiler enables you to compile your C and C++ code. It is an optimizing compiler
with a range of command-line options to enable you to control the level of optimization.
The command line option gives a choice of optimization levels, as follows:
• -Ospace. This option instructs the compiler to perform optimizations to reduce image size
at the expense of a possible increase in execution time.
• -Otime. This option instructs the compiler to perform optimizations to reduce execution
time at the expense of a possible increase in image size.
• -O0. Turns off most optimizations. It gives the best possible debug view and the lowest
• -O1. Removes unused inline functions and unused static functions. Turns off optimizations
that seriously degrade the debug view. If used with --debug, this option gives a satisfactory
debug view with good code density.
• -O2 (default). High optimization. If used with --debug, the debug view might be less
satisfactory because the mapping of object code to source code is not always clear.
• -O3. performs the same optimizations as -O2 however the balance between space and time
optimizations in the generated code is more heavily weighted towards space or time
compared with -O2. That is:
— -O3 -Otime aims to produce faster code than -O2 -Otime, at the risk of
increasing your image size
— -O3 -Ospace aims to produce smaller code than -O2 -Ospace, but performance might
be degraded.
Table 19-1 Floating-point code generation
-mfpu -mfloat-abi Resultant code
Any value soft Floating-point emulation using software floating-point library
vfpv3 softfp VFPv3 floating-point code
vfpv3-d16 softfp VFPv3 floating-point code
neon hard VFPv3 and Advanced SIMD code, where the floating-point and
SIMD types use the hardware FP registers
So in clear, as far as you use neon option (which is hardwired in the BBB) you need to define the hardfloat as well .
Hope this will help
Thanks dlewin555.
I understand that it’s possible to use hard float. Some Android or arm Ubuntu version are using it.
But for the default Angstrom (this the BeagleBone Black is delivered with). How can we check the hard float is not used ?
I guess I could rebuild Anstrong using hard float but I am wondering why the default build doesn’t use it ?
I trust the Angstrom builder. It should have better knowledge than me. So if he preferred not to use the hard float it should have a good reason and I would like to know it.
Regards
I believe there is also an issue that using hard float makes context switches much more expensive. When hardfloat is in use, all the additional registers (possibly including wide vector registers) have to be saved and restore on every context switch regardless of whether the running application is using floating point or not. I have not looked at the Sitara but some processors have hardware assistance for this context switching that reduces the cost but with the exception of shadow register sets used in hard RTOS systems there is always a memory bandwidth cost. This context switching cost slows the entire system down.
Our application is floating point arithmetic intensive so hard float is the better option, but I suspect there are many common workloads that do better under softfloat.
Dean
Interesting.Nevertheless,the only reference to the fp operation context switch cost I’ve found is related to the VFP which we don’t use with the Sitara under Angstrom.
For some eventual interested people :
Wow, way wrong... Angstrom has "always" utilized the floating point unit
on these parts. Even way before the "armhf" versions of ubuntu/debian and
fedora came out. The only thing that hasn't changed yet, is to use the
same armhf linker those guys use (/lib/ld-linux-armhf.so.3).
I think that it can be -at worst -ambiguous, not so wrong: let me resay it :
“Nevertheless,the only reference to the fp operation context switch cost I’ve found is related to the VFP which we don’t use ONLY with the Sitara under Angstrom” as we are talking about hardfloat and softfloat , vfpv3 is not used as is ( read soft/softfp) . when hard for gcc option is used this implies neon : then your code will be VFP3 and SIMD codes.
Hope this is clearer.
"hard" with gcc doesn't actually imply neon either..
'armhf' in ubuntu/debian is actually built for "--with-fpu=vfpv3-d16
--with-float=hard --with-mode=thumb" which allows "non-neon"
implementations (such as the tegra2 and one marvel chip) to use it.
Whereas Angstrom for the beagle has always used the full floating
point resources as the omap/sitara parts from TI have the full 32
register vfpv3 with neon implementation..
Maybe is that because you have missed the start of the discussion, where I’ve said :
(…)Therefore if you dig into the A8 arm documentation CortexA_ProgGuide.pdf that you can easily download from Arm website ( free account is required)
as the question was about Angstrom only, and I was refering to the Arm documentation you will find :
neon + hard = VFPv3 and Advanced SIMD code, where the floating-point and
is free to use any NEON or VFPv3 registers for floating-point values.
Nevertheless, I could eventually misunderstanding the documentation, please then let me know.
Finally it’s become darker for me.
Robert, did you mean that Angstrom distribution use hard float but not the armhf that we have in ubuntu ? This is why I can’t run software compiled with the ubuntu arm-linux-gnueabihf- tool chain ?
In this case I should better use the Android toolchain (even is less easy to use than the ubuntu packet) or does the ubuntu arm-linux-gnueabi toolchain is acceptable ?.
Regards
Finally it's become darker for me.
armhf that we have in ubuntu ? This is why I can't run software compiled
Correct, as Angstrom doesn't have the new hard float linker..
is acceptable ?.
Actually just use Angstrom's sdk gcc, it's hardfp enabled, and matches
the libraries in Angstrom.
http://www.angstrom-distribution.org/toolchains/
Are there any technical difficulties to use a hard float linker? And if
there is no hard linker in system, what's the effect of the system?
Hi tee,
on the BBB in /lib I just did:
ln -s ld-linux.so.3 ld-linux-armhf.so.3
Now my cross compiled binaries work on BBB.
I used crosstool-ng 1.19 for generating the cross-toolchain on my PC (opensuse 12.2).
I attach the .config for crosstool-ng.
config.bbb.hardfp (13 KB)
Of course it works. There is even the same from the OE environment -and I mean : from the official repo - , here is set for my angstrom-SDK :
export CC=“arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb-interwork -mfloat-abi=hard -mfpu=neon -mtune=cortex-a8 --sysroot=/usr/local/oecore-i686/sysroots/cortexa8hf-vfp-neon-angstrom-linux-gnueabi”
Here are the options that pointed out from the Arm Cortex Documentation.
Which works nicely on my board.
David
