Hi Robert,
Yesterday, I built u-boot wrong after making your recommended change to board/ti/am57xx/board.c. The build date on my u-boot from yesterday was showing May 16, 2017.
When I made your recommended change in another 2017.01 u-boot tree on another VM, the change allowed my 571x/5718 IDK to get to u-boot (see below).
I’m sorry, I should have noticed the build date issue yesterday!!
My console output thus far follows. Please note that this build of u-boot pulls in the default device tree for 2017.01 u-boot CONFIG_DEFAULT_DEVICE_TREE=“am572x-idk” and the TI SDK’s mux_data.h file
!!! Thanks a lot for your help yesterday !!!
I think our board engineer is designing in the 5728 at this point, but I’ll relay these results to the manager and team.
**** Console Output after making change.
U-Boot SPL 2017.01-00318-g9fd6070-dirty (Jun 12 2017 - 15:31:55)
DRA722-GP ES2.0
Trying to boot from MMC1
** First descriptor is NOT a primary desc on 0:1 **
** No partion table - mmc 0 **
Using default environment
U-Boot 2017.01-00318-g9fd6070-dirty (Jun 12 2017 - 15:31:5-0500)
CPU : DRA722-GP ES2.0
Model: TI AM5728 BeagleBoard15
Board: AM571x IDK REV 1.3B
DRAM: 1 GiB
CACHE: Misaligned operation at range [bffbb290, bffbba90]
** rst descriptor is NOT a primary desc on 0:1 **
** No partition table - mmc 0 **
Usindefault environment
setup_board_eeprom_env: am571x_idk
am5_idk_lcd_detect: Touch screen detect failed: 1!
SCSI: SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
fgs: 64bit ncq stag pm led clo only pmp pio slum part ccc apst scanning bus for devices…
Found 0 device(s).
cpsw
Press SCE to abort autoboot in 2 seconds
usb_boot is currently disabled
scsi_boot is currently disabled
switch to partions #0, OK
mmc0 is current device
** First descriptor is NOT a priry desc on 0:1 **
Scanning mmc device 0
Checking for: /uEnv.t …
Checking for: /boot/uEnv.txt …
** partition table - mmc 0 **
- No partition table - mmc 0 ***
** No partition tle - mmc 0 **
** First descriptor is NOT a primary desc on 1:1 **
switch toartitions #0, OK
** First descriptor is NOT a pmary desc on 1:1 **
Scanning mmc device 1
Checking for: /uEntxt …
** No partition table - mmc 1 **
** No ptition table - mmc 1 **
** partition table - mmc 1 **
** No partition tabl- mmc 1 **
DRA722-GP ES2.0
DRAM: 1 GiB
Found 0 device(s).
cpsw
