doesn't load the nk.bin
Hi everybody,
I have followed all described steps from the provided instructions
with the evaluation BSP.
It worked as I did it the first time after I have received the
beagleboard.
Then, I have attempted loading again the BEAGLEBOARD-nand.raw, via
EVMFlash, and since then, nothing is working. And I cannot understand
why.
Is there a possibility that the overwrite I have proceeded erased some
fundamental information?
This seems to me it is not, since when I push reset button, I still
see the communication between PC and beagleboard via the hyperterminal
(RS232) and can make all the demanded configuration. So I configure it
with my IP address, subnet mask (I am also not pretty sure about what
to feed it here, but as I said it worked previously)...and then open
visual studio. VS sees the beagleboard (connectivity options ->
settings). I can see sent bootme to 255.255.255.255
into hypeterminal.
Then when I click "attach the device", after few seconds, the device
is disconnected and I can read in the VS console "(CoreCon) Error:
Failed to download image. Please check connection settings."
has anyone an idea???
Thank you for help...
Nathaniel P.
