I’m still confused about the PRU availability in the TDA4VM. The datasheet and the technical reference manual both indicate that the PRU is not implemented but several posts here indicated that it is present in the BBAI-64.
I want to use the DRA829JM in a new project. Is it safe to begin a new design that assumes the PRU will be present?
Here is TI’s reply to this issue.
TI does not offer ongoing direct design support for this hardware. For support while working through your design, contact BeagleBoard.org Foundation.
No official PRU support from TI will be offered to the public. I’m sure that Tier 1 device builders get a different answer since the PRU’s are actually intact and functional.
