Hi. This seems like it should be simple, but it's giving us a bit of trouble.
I can control the GPIO (139, pin 3 of the expansion connector) just fine. The problem is that the 1.78V output doesn't seem to be enough to trigger any of the MOSFETs we've tried - most recently a BS107A. The load we're trying to drive is a bank of LEDs, drawing about 100 mA at just under 12V. With the BS107A I'm getting about 9.5V out (which isn't enough), presumably because the MOSFET isn't being fully triggered.
What have others used successfully to switch the power to a load on and off using a BeagleBoard GPIO?
Any help appreciated.
Cheers,
Chris MacGregor
