I enabled DSP support (dspbridge) on my BeagleBoard running Debian Lenny
using the latest kernel (2.6.35) and patches and installed all the
required TI's bins and libs, but when I try to play a video using
gstreamer and the DSP algorithms I get a scrambled video decoding, as
shown in the following screenshot:
http://img716.imageshack.us/img716/2879/bbbdistort.png
Kernel log shows no errors on boot:
[ 38.823394] bridgedriver: module is from the staging directory, the
quality is unknown, you have been warned.
[ 38.998535] proc_load: Processor Loaded /lib/dsp/baseimage.dof
[ 39.007049] omap mailbox rev 4.0
[ 39.015289] proc_start: dsp in running state
[ 39.026397] DSP Bridge driver loaded
The provided ping utility also works.
Can anyone help me sorting out this problem?
Pietro Pizzo
thats not scrambled, that is just an image stride issue.
The omap YUV overlays expect the image to have a width which is a multiple
of 16 pixels, so the dsp decoder needs to add padding for clips that are
not a multiple of 16 wide...
Or this image is decoded correctly, but somebody copies it not taking the
16x stride into account...
Thanks for your quick reply Vladimir. I tried with other movies with a
width multiple of 16 pixels and it worked like a sharm!
Just a question: is it possible to play movies which don't respect
width limitations? Could it be possible to insert a component in the
gstreamer pipeline which pads the frames with blank pixels?
Thanks again.
Pietro
