Can someone please explain the convoluted make system for dsplink?
Basic info : As much as I've tried, I cant get bitbake to work.
I used Linux PSP Kernel from the dvsdk.
I am using the toolchain that I downloaded from narcissus.
I have installed the Code Sourcery toolchain. Had to use one path from
it.
It is pretty messed up :s
Anyhow. Editing here and there. I managed to compile the sample
applications successfully!
But now I want to use fstream to read a file and pass it to the dsp
and perform some math on it using dsplib.
Sample app: Loop.
And I got stuck on the gpp side. (Havent tried dsp yet)
I have the following questions.
I get insane errors :s
expected declaration specifiers before 'template'
expected declaration specifiers before ';' token
declaration for parameter 'xxxx' but no such parameter.
http://pastebin.com/Y99HG0Np
Pretty sure i messed up the includes. But i cant figure out what is
what :s
Base_buildos = ? Kernel source? Or more?
Osinc generic?
Osinc platform?
Osinc target?
Guidance please..
I mentioned earlier... "As much as I've tried, I cant get bitbake to
work."
I've tried!
Ok. I found one part of the problem.
Its C!!
Not C++
fstream is C++. I was trying to include it.
Should've realized it sooner :s
This is difficult. Don't think my programming is good enough to make a
C++ wrapper for the convoluted(complicated) dsplink...
I'll use C..
work."
I've tried!
But I see no postings from you on the angstrom-devel list about any troubles, so to me it looks like you didn't try. What didn't work? Did you actually follow all the steps in http://www.angstrom-distribution.org/building-angstrom ? Most people tend to skip steps which is what trips them up.
I was stuck in a git issue. Not the oebb.sh
Without sudo git didn't have read access to some files/folders.
Fetch_head and some other one.
I tried some searching. Used chmod and chown etc.
Didn't work.
With sudo, bit bake gave an error of don't use bitbake with sudo.
Check some variable.
You aren't right that i didn't try.
I just didn't try hard enough.
Primarily because of another issue though. I have to find a place with
stable internet and electricity for longer durations.
Don't ask how i manage without those two.
