DSPNode_allocated failed: 0xffffffff
I have some problem with dsp bridge
my step:
git clone git://dev.omapzoom.org/pub/scm/tidspbridge/kernel-dspbridge.git
// TI website
wget http://gitorious.org/vjaquez-beagleboard/marmita/blobs/raw/master/meta-marmita/linux/linux-omap-bridgedriver/defconfig
-O .config // beagle board website
make menuconfig // module dsp
bridge , I use default set
modprobe mailbox
modprobe bridgedriver base_img=/lib/dsp/baseimage.dof
./ping.out
terminal display
DSP device detected !!
DSPNode_Allocate failed: 0xffffffff
please tell me what's wrong ...thx
my step:
// TI website
modprobe mailbox
./ping.out
terminal display
Do you have stored the socket nodes in /lib/dsp ??
You need this one: pingdyn_3430.dll64P
Checkout BeagleBoard/DSP Howto - eLinux.org
vmjl
I had try it
./dynreg.out -r pingdyn_3430.dll64P
the result still is
I had try it
the result still is
I don't know the current state of the tidspbridge library since I
don't use it anymore. What I should recommend is to try with the
dsp-tools[1] or try to debug libtidspbridge[2] by your self.
1. BeagleBoard/dsp-tools - eLinux.org
2. http://gitorious.org/vjaquez-beagleboard/libbridge
Hi
modprobe dspbridge
modprobe bridgedriver base_img=baseimage.dof
./cexec ddspbase_tiomap3430.dof64P
./cexec dynbase_tiomap3430.dof64P
./dynreg -r pingdyn_3430.dll64P
kindly check above procedure
saminath
2010/9/29 Victor Manuel Jáquez Leal <ceyusa@gmail.com>
modprobe dspbridge
This is usually done by udev.
This is correct, although it's easier to put this into
'/etc/modprobe.d/bridgedriver.conf':
options bridgedriver base_img=/lib/dsp/baseimage.dof
So you only need to do 'modprobe bridgedriver'. And also, I think udev
is also loading bridgedriver, so the above would make it work from the
boot.
This is reloading the baseimage... if you are going to do that, then do:
modprobe bridgedriver base_img=ddspbase_tiomap3430.dof64P
Ditto.
I believe if you use 'ddspbase_tiomap3430.dof64P' that's not
necessary. But as Victor said with dsp-tools it's much easier:
http://elinux.org/BeagleBoard/dsp-tools
Thank All
"cat /proc/interrupts"
I found I only had "28" & lacked "26"
"26" sometimes show up, but the probability is very less
once "26" show up , I can execute "ping" right
