A kernel upgrade on our devices requires using the dtb-rebuilder to get our modified base DTB-s (am335x-boneblack.dtb). For the 4.19-ti series the most recent supported kernel version in your repo appears to be "4.19.25-ti-r17" from 6 months ago (when looking at commit comments).
The beagleboard repo doesn't list any kernel versions anywhere. When using this repo, how would I recognize which 4.19-ti kernel version I'd be able to apply my modified DTB-s to?
That shouldn't be an issue going forward.. (easy to say as 4.19-ti has
quieted down, so that might backfire with 5.4-ti)
With the old dtb-rebuilder repo, we'd always push a dts patch to the
kernel build script first, tag it and then manually copy it back to
the dtb-rebuilder. So things would get out of sync if i didn't copy
it over..
With the new repo, everything gets pushed to the
BeagleBoard-DeviceTrees repo first, and the files get sync'ed directly
back to the kernel build script afterwards:
it over..
But I have a rather simpler question. How would I match a specific kernel deb package to a BeagleBoard-DeviceTrees repo commit which went into _this_ package?
I suspect I can't randomly pick a set of DTB files meant for one kernel, modify and then apply those to another kernel.
E.g. I've chosen linux-image-4.19.50-ti-r24 as my kernel (from your apt repo). Now I wish to modify the DTB-s corresponding to _this_ kernel package. Not for 5.x, not for some newer or older release of 4.19-ti. How would I find the DTB-s in this package from the BeagleBoard-DeviceTrees repo?
Off-topic: I'm also assuming that the kernel packages in repos.rcn-ee.com are all tested and good for production use, which may or may not be correct.
So yeah, i test what i can, can't test everything especially if Ubuntu
or Debian throws in a wrench with a broken gcc version or something
else in their testing repos..
Ok, so you verify that the kernel builds, then package and publish the result and finally run some integration tests using real hardware. Sounds great.
Question: when you run the weekly or daily integration tests on your little farm, how can I consume only the kernel packages that passed?
Now, before we go more into the details, i don't' "guarantee"
anything.. If your worried about something breaking, have a test node
you test with before you push out to many units..
Sounds great.
