.dts file not compiling.
The code is only compiling when clock is being commented out.
It is stating a syntax error. But i cant find any.
This is the error
debian@BeagleBone:/opt/source/dtb-6.1-Beagle$ sudo make
DTC src/arm64/overlays/k3-am67a-beagley-ai-csi1-imx415.dtb
Error: src/arm64/overlays/k3-am67a-beagley-ai-csi1-imx415.dts:18.24-40 syntax error
FATAL ERROR: Unable to parse input tree
make[1]: *** [Makefile:181: src/arm64/overlays/k3-am67a-beagley-ai-csi1-imx415.dtb] Error 1
make: *** [Makefile:105: all_arm64] Error 2
// SPDX-License-Identifier: GPL-2.0
 * DT Overlay for Sony IMX415 Camera on BeagleY-AI *** CSI1 Port ***
 * Target: CSI1 Connector, I2C Bus 3 (main_i2c3), Address 0x37.
 * **** CLOCK DEFINITION REMOVED. CLOCK USAGE COMMENTED OUT TO ALLOW COMPILATION ****
 * Uses CSI1 nodes (ti_csi2rx1, dphy1, csi2rx1_in_sensor) and driver requirements.
 * Copyright (C) 2023 Texas Instruments Incorporated - https://www.ti.com/
 * Modifications Copyright (C) 2024 <Your Name/Handle>
/dts-v1/;
/plugin/;
#include <dt-bindings/gpio/gpio.h>
// <<<< Clock Definition Block REMOVED Entirely >>>>
// Ensure the MCU GPIO controller potentially used for reset is enabled
// Verify which controller the CSI1 reset pin actually uses
&mcu_gpio0 {
    status = "okay";
// Target I2C Bus 3 for BeagleY-AI
&main_i2c3 {
    status = "okay";
    // Pinctrl might be needed if I2C3 pins are not muxed by default
    // pinctrl-names = "default";
    // pinctrl-0 = <&main_i2c3_pins_default>;
    clock-frequency = <400000>; // Standard 400kHz
    #address-cells = <1>;
    #size-cells = <0>;
    // Define the IMX415 sensor directly on I2C3
    imx415: sensor@37 {
        compatible = "sony,imx415"; // Driver match string
        reg = <0x37>;             // Confirmed I2C address on Bus 3
        // Clock Usage - Driver requires "inck". Kept commented out for compilation.
        // clocks = <&some_existing_clock_label>; // <<< Needs a valid phandle when uncommented
        // clock-names = "inck";              // <<< Correct name for driver
        // Reset GPIO for BeagleY-AI CSI1 - **** THIS PIN/CONTROLLER NEEDS VERIFICATION ****
        reset-gpios = <&mcu_gpio0 15 GPIO_ACTIVE_LOW>; // <<< GUESSING Pin 15 for CSI1, corrected polarity
        // Port definition linking sensor output to CSI1 receiver input
        port {
            csi2_cam1: endpoint { // Label for sensor output endpoint (using '1' for CSI1)
                remote-endpoint = <&csi2rx1_in_sensor>; // Link to CSI1 receiver input endpoint
                // Link frequency - adjust if camera module/mode requires different
                link-frequencies = /bits/ 64 <456000000>;
                clock-lanes = <0>; // Standard CSI clock lane
                data-lanes = <1 2>; // Assuming 2 data lanes - VERIFY camera module!
// Configure the CSI1 Receiver Endpoint
// Assuming the structure involves modifying a port within cdns_csi2rx0.
// The exact nodes (&csi0_port1, &cdns_csi2rx0) might need verification against BeagleY base DT.
&cdns_csi2rx0 { // Assuming the Cadence CSI receiver IP block handles multiple ports
    ports {
        // Reference Port 1 for CSI1 connection
        // The label '&csi0_port1' might need verification for BeagleY's specific structure for port 1
        &csi0_port1 {
            status = "okay";
            csi2rx1_in_sensor: endpoint { // Receiver input endpoint for CSI1
                remote-endpoint = <&csi2_cam1>; // Link back to sensor output endpoint
                bus-type = <4>; // CSI2 DPHY
                clock-lanes = <0>;
                data-lanes = <1 2>; // Must match data-lanes in sensor node
        }; // End of csi0_port1 definition/modification
    }; // End of ports node
}; // End of cdns_csi2rx0 node modification
// Ensure the TI CSI1 Wrapper/Driver is enabled (based on imx219 CSI1 example)
&ti_csi2rx1 {
    status = "okay";
// Ensure the DPHY for CSI1 is enabled (based on imx219 CSI1 example)
&dphy1 {
    status = "okay";
// Optional: Disable CSI0 components if definitely not used
// &ti_csi2rx0 {
//     status = "disabled";
// &dphy0 {
Can anyone tell the right syntax, both xclk and inck. But it is still showing same error.
The code is only getting compiled when clock part is commented out, so the problem lies somewhere in the clock.
I would have thought that clocks = <&inck>; should have worked?
It might not be called that though; you’ll have to check the underlying dts…
The issue has been resolved. The code got compiled without errors.
Great; but perhaps pass it forward, by showing what you did to fix it?
(and maybe use the solution button to mark topic done)
Pro-tip: When you want to show a file, please do enclose it with tripple-backticks, like so:
This is my file
line 2
You can also show diffs:
- This line is going away.
+ This is the new line replacing it.
Now, isn’t that better?
All the formatting can be found here:
Formatting posts using markdown, BBCode, and HTML - Documentation / Using Discourse - Discourse Meta
I would like to forward it, but i am still testing it.
I was required to use 6.6 kernel. And recompile it to enable the imx415 sensor.
This version on enabling will recognise the sensor but will not initialize it.
The imx415.c inside the kernel got an update. Which needs to be patched.
After that patch i will be able to test my .dts file and weather its functional.
I will post the tested one. within a few days after i confirmed it works
This is the compiled code for now.
 * DT Overlay for Sony IMX415 on CSI1 J722S BeagleY-AI board.
 * Based on IMX219 overlay and imx415.c driver analysis.
 * Targets I2C bus /dev/i2c-3 (main_i2c1) and address 0x37.
 * Uses 1440Mbps lane rate (720MHz link frequency) for 24MHz INCK.
 * Copyright (C) 2024 <Your Name/Organization>
 * Adapted from work by Texas Instruments Incorporated - https://www.ti.com/
 /dts-v1/;
/plugin/;
    chosen {
        overlays {
            k3-am67a-beagley-ai-csi1-imx415.kernel = **TIMESTAMP**;
    mipi_switch: mipi-switch {
        oe-pin {
            default-state = "off";
        sel-pin {
            default-state = "on"; // Assuming 'on' selects CSI1 path
    clk_csi1_imx415_fixed: csi1-imx415-inck {
        compatible = "fixed-clock";
        #clock-cells = <0>;
        clock-frequency = <24000000>; // For 1440Mbps mode
        status = "okay";
&main_gpio1 {
    status = "okay";
&main_i2c1 {
    status = "okay";
    pinctrl-0 = <&main_i2c1_pins_default>;
    #size-cells = <0>;
    imx415_1: sensor@37 {
        reg = <0x37>;
        status = "okay";
        clocks = <&clk_csi1_imx415_fixed>;
        pinctrl-0 = <&csi1_gpio_pins_default>;
        reset-gpios = <&main_gpio1 24 GPIO_ACTIVE_HIGH>;
        port {
            csi2_imx415_1: endpoint {
                remote-endpoint = <&csi2rx1_in_imx415>;
                link-frequencies = /bits/ 64 <720000000>;
                clock-lanes = <0>;
                data-lanes = <1 2 3 4>;
                status = "okay";
&cdns_csi2rx1 {
    status = "okay";
    ports {
        #size-cells = <0>;
        csi1_port0: port@0 {
            reg = <0>;
            status = "okay";
            csi2rx1_in_imx415: endpoint {
                remote-endpoint = <&csi2_imx415_1>;
                clock-lanes = <0>;
                status = "okay";
&ti_csi2rx1 {
    status = "okay";
&dphy1 {
    status = "okay";
&main_pmx0 {
    main_i2c1_pins_default: main-i2c1-default-pins {
        pinctrl-single,pins = <
            J722S_IOPAD(0x01e8, PIN_INPUT_PULLUP, 0) // I2C1_SCL (C24)
            J722S_IOPAD(0x01ec, PIN_INPUT_PULLUP, 0) // I2C1_SDA (A22)
    csi1_gpio_pins_default: csi1-gpio-default-pins {
            J722S_IOPAD(0x01d8, PIN_OUTPUT, 7) // GPIO1_24 (D22) Reset Pin
Thanks for the reply. I’ll use theses standards to post my code from now on.
