hi there,
I experience this below:
Need to get 64.4 MB of archives.
After this operation, 244 kB of additional disk space will be used.
E: You don’t have enough free space in /var/cache/apt/archives/.
I install my debian image in the 4Gb sd-card. I tried 8Gb, I still experience the same thing.
Some advice to install on the SD-card, but that’s what i did.
Questions:
- How to install app onto the SD-card?
- when i check the capacity, df -h, why it doesnt show the full capacity of the SD card which is 4GB?
- Even when i used 8GB, I still see that it uses only 2GB, the rest of the sd card is “unallocated”. why?
How to increase the capacity of the sd-card? (I believe this is because I used the image).
thanks
root@beaglebone:/var/lib/apt/lists# df -h
Filesystem Size Used Avail Use% Mounted on
rootfs 1.6G 1.6G 0 100% /
udev 10M 0 10M 0% /dev
tmpfs 100M 544K 99M 1% /run
/dev/mmcblk0p2 1.6G 1.6G 0 100% /
tmpfs 249M 0 249M 0% /dev/shm
tmpfs 249M 0 249M 0% /sys/fs/cgroup
tmpfs 100M 0 100M 0% /run/user
tmpfs 5.0M 0 5.0M 0% /run/lock
/dev/mmcblk0p1 96M 70M 27M 73% /boot/uboot
