Easiest Way to Run BBB off of a Battery?
I am looking for a way to run my BBB off of a rechargeable battery. I want to be able to run either a full or headless system, with a wireless adapter plugged in over USB. I don’t have much electronics experience, and would rather not have to solder anything on to my board. If there is a simple-ish way that I can get a battery hooked up using the battery/charging pins on the board (without a cape), I would really appreciate instructions on finding the correct battery and setting it up!
Wasabi Fan
No need 2 touch the BBB. Get your rechargeable battery or batteries with about 6V output, a 2.1x5.5 mm barrel plug, a 100 uF capacitor, and a 7805 voltage regulator and you are in business.
Wasabi Fan <junkytomato@hotmail.com> [13-09-07 19:08]:
plugged in over USB. I don't have much electronics experience, and would
Wasabi Fan
For more options, visit http://beagleboard.org/discuss
You received this message because you are subscribed to the Google Groups "BeagleBoard" group.
To unsubscribe from this group and stop receiving emails from it, send an email to beagleboard+unsubscribe@googlegroups.com.
For more options, visit https://groups.google.com/groups/opt_out.
I am running my BBB with LCD7 off a rechargeable emergency pocket charger for cell phones like
this one:
http://www.reichelt.de/Mobile-Powerpacks/VTB-22/3/index.html?&ACTION=3&LA=446&ARTICLE=117929&GROUPID=4491&artnr=VTB+22
delivers 5V/2A 7200mAh.
Charging is simplistic: Connect to the USB port and wait.
HTH!
Best regards,
mcc
  1. Get one of those USB charging gizmos like an uNu Enerpak or Duracell pocket charger.
  2. Plug a mini-USB cable between the charger and the BBB.
  3. Done!
I ran my BBB over 9 hours on a 5000mAh uNu as a test, and that was with a GPS receiver on top of the Beaglebone. YMMV.
