eds-dbus SVN repo. isn't accessible on o-hand.com
I've been trying to build beagleboard-demo-image these days using OE's
stable/2009 and the build system fails at eds-dbus while fetching the
source code from the SVN repository. I check the website on o-hand.com
and indeed it looks like they migrated the eds-dbus bits from the SVN
repo. to a GIT based one (http://git.o-hand.com/cgit.cgi/eds-dbus/).
Is possible to update eds-dubs's .bb recipe to fetch the code from
that location instead?
On a side note, what's the most fit image to build in order to get the
latest PowerVR and DSP features of the beagleboard demoed and running?
Do I have to use another bleeding edge branch of openembedded, to get
access to that newer functionality? which one?
-Ilyes Gouta
If you want to build a recent sgx and dsp use http://gitorious.org/angstrom/angstrom-setup-scripts
regards,
Koen
The same goes for the org.openembedded.dev branch. eds-dbus can't be fetched.
-Ilyes Gouta
Here is a patch for eds-dbus to enable fetching and building
eds-dbus's source code from the git repository
(git://git.o-hand.com/eds-dbus) instead of the deprecated svn. This is
needed for the current org.openembedded.dev branch to build
beagleboard-demo-image.
-Ilyes Gouta
eds-dbus_git.tar.gz (3.92 KB)
