I have multiple beagle boards. They are all BeagleBoard xM Rev C.
Most of them I am able to run the PowerVR demos with no problems. Yet,
there are some exceptions:
I have already run into two boards that I get the following prompts
during the boot log:
OMAP36XX/37XX-GP ES2.1, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
and
No SGX hardware, not starting PVR
On these boards whenever I try to run a PowerVR demo I get the
following error prior to exiting the demo app:
PVRShell: EGL Error (EGL_BAD_ALLOC)
InitAPI failed!
PVRShell: Unable to initialise EGL
To fix this problem you can edit this file on the beagleBoard:
/usr/bin/cpuType
and replace the following line:
sed -e 's/0x00005C00/OMAP3503/' -e 's/0x00001C00/OMAP3515/' -e 's/
0x00004C00/OMAP3525/' -e 's/0x00000C00/OMAP3530/'
with the following line:
0x00004C00/OMAP3525/' -e 's/0x00000C00/OMAP3530/' -e 's/0x00000E00/
OMAP3530/'
which is effectively adding -e 's/0x00000E00/OMAP3530/' to such line.
After this change proceed to reboot and you should be able to run the
PowerVR demos without any trouble.
If anybody is interested on why this work please let me know and I
could elaborate more.
