And with debug added by Joel:
Texas Instruments X-Loader 1.5.0 (Jun 7 2011 - 09:51:36)
Beagle xM
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2011.06-rc3-00023-g63bfa80 (Jun 22 2011 - 18:46:00)
OMAP3630/3730-GP ES2.1, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle xM Rev C
No EEPROM on expansion board
Die ID #546800029ff80000015f26ad0f02b022
Net: Net Initialization Skipped
No ethernet found.
OMAP3 beagleboard.org # usb start
(Re)start USB...
USB: Register 1313 NbrPorts 3
USB EHCI 1.00
scanning bus for devices... req=6 (0x6), type=128 (0x80), value=256, index=0
USB_DT_DEVICE request
req=5 (0x5), type=0 (0x0), value=1, index=0
USB_REQ_SET_ADDRESS
Len is 0
req=6 (0x6), type=128 (0x80), value=512, index=0
USB_DT_CONFIG config
req=9 (0x9), type=0 (0x0), value=1, index=0
USB_REQ_SET_CONFIGURATION
Len is 0
req=6 (0x6), type=128 (0x80), value=768, index=0
USB_DT_STRING config
req=6 (0x6), type=128 (0x80), value=769, index=1
req=6 (0x6), type=128 (0x80), value=770, index=1
req=6 (0x6), type=160 (0xa0), value=10496, index=0
USB_DT_HUB config
USB_DT_HUB config
req=0 (0x0), type=160 (0xa0), value=0, index=0
req=3 (0x3), type=35 (0x23), value=8, index=1
Len is 0
req=3 (0x3), type=35 (0x23), value=8, index=2
Len is 0
req=3 (0x3), type=35 (0x23), value=8, index=3
Len is 0
req=0 (0x0), type=163 (0xa3), value=0, index=1
req=0 (0x0), type=163 (0xa3), value=0, index=2
req=1 (0x1), type=35 (0x23), value=16, index=2
Len is 0
req=3 (0x3), type=35 (0x23), value=4, index=2
Len is 0
req=1 (0x1), type=35 (0x23), value=20, index=2
Len is 0
dev=9ffb00fc, pipe=88000083, buffer=9ff077ac, length=64, req=9ffafbac
req=6 (0x6), type=128 (0x80), value=256 (0x100), index=0
TOKEN=0x9c00
Len is 0
Len is 0
dev=9ffb00fc, pipe=88000000, buffer=(null), length=0, req=9ffafbac
req=5 (0x5), type=0 (0x0), value=2 (0x2), index=0
TOKEN=0x8d00
dev=9ffb00fc, pipe=88000283, buffer=9ffb01fc, length=18, req=9ffafbac
TOKEN=0x9c00
dev=9ffb00fc, pipe=88000283, buffer=9ff077ac, length=9, req=9ffafbac
req=6 (0x6), type=128 (0x80), value=512 (0x200), index=0
TOKEN=0x9c00
dev=9ffb00fc, pipe=88000283, buffer=9ff077ac, length=41, req=9ffafbac
TOKEN=0x9c00
dev=9ffb00fc, pipe=88000203, buffer=(null), length=0, req=9ffafbac
req=9 (0x9), type=0 (0x0), value=1 (0x1), index=0
TOKEN=0x8d00
dev=9ffb00fc, pipe=88000283, buffer=9ff0757c, length=4, req=9ffafbac
req=6 (0x6), type=160 (0xa0), value=10496 (0x2900), index=0
TOKEN=0x9c00
dev=9ffb00fc, pipe=88000283, buffer=9ff0757c, length=9, req=9ffafbac
TOKEN=0x9c00
req=0 (0x0), type=160 (0xa0), value=0 (0x0), index=0
TOKEN=0x9c00
req=3 (0x3), type=35 (0x23), value=8 (0x8), index=1
TOKEN=0x8d00
req=3 (0x3), type=35 (0x23), value=8 (0x8), index=2
TOKEN=0x8d00
req=3 (0x3), type=35 (0x23), value=8 (0x8), index=3
TOKEN=0x8d00
req=3 (0x3), type=35 (0x23), value=8 (0x8), index=4
TOKEN=0x8d00
req=3 (0x3), type=35 (0x23), value=8 (0x8), index=5
TOKEN=0x8d00
dev=9ffb00fc, pipe=88000283, buffer=9ff0777c, length=4, req=9ffafbac
req=0 (0x0), type=163 (0xa3), value=0 (0x0), index=1
TOKEN=0x9c00
dev=9ffb00fc, pipe=88000283, buffer=9ff07560, length=4, req=9ffafbac
TOKEN=0x9c00
req=1 (0x1), type=35 (0x23), value=16 (0x10), index=1
TOKEN=0x8d00
req=3 (0x3), type=35 (0x23), value=4 (0x4), index=1
TOKEN=0x8d00
dev=9ffb00fc, pipe=88000283, buffer=9ff0753c, length=4, req=9ffafbac
TOKEN=0x9c00
req=1 (0x1), type=35 (0x23), value=20 (0x14), index=1
TOKEN=0x8d00
dev=9ffb0644, pipe=88000083, buffer=9ff07344, length=64, req=9ffafbac
TOKEN=0x9c00
TOKEN=0x8d00
dev=9ffb00fc, pipe=88000283, buffer=9ff07314, length=4, req=9ffafbac
TOKEN=0x9c00
TOKEN=0x8d00
dev=9ffb0644, pipe=88000000, buffer=(null), length=0, req=9ffafbac
req=5 (0x5), type=0 (0x0), value=3 (0x3), index=0
TOKEN=0x8d00
dev=9ffb0644, pipe=88000383, buffer=9ffb0744, length=18, req=9ffafbac
TOKEN=0x9c00
dev=9ffb0644, pipe=88000383, buffer=9ff07344, length=9, req=9ffafbac
TOKEN=0x9c00
dev=9ffb0644, pipe=88000383, buffer=9ff07344, length=39, req=9ffafbac
TOKEN=0x9c00
dev=9ffb0644, pipe=88000303, buffer=(null), length=0, req=9ffafbac
TOKEN=0x8d00
req=0 (0x0), type=163 (0xa3), value=0 (0x0), index=2
TOKEN=0x9c00
req=0 (0x0), type=163 (0xa3), value=0 (0x0), index=3
TOKEN=0x9c00
TOKEN=0x9c00
req=1 (0x1), type=35 (0x23), value=16 (0x10), index=3
TOKEN=0x8d00
req=3 (0x3), type=35 (0x23), value=4 (0x4), index=3
TOKEN=0x8d00
TOKEN=0x9c00
req=1 (0x1), type=35 (0x23), value=20 (0x14), index=3
TOKEN=0x8d00
dev=9ffb0b8c, pipe=88000083, buffer=9ff07344, length=64, req=9ffafbac
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x8d00
dev=9ffb0b8c, pipe=88000000, buffer=(null), length=0, req=9ffafbac
req=5 (0x5), type=0 (0x0), value=4 (0x4), index=0
TOKEN=0x8d00
dev=9ffb0b8c, pipe=88000483, buffer=9ffb0c8c, length=18, req=9ffafbac
TOKEN=0x9c00
dev=9ffb0b8c, pipe=88000483, buffer=9ff07344, length=9, req=9ffafbac
TOKEN=0x9c00
dev=9ffb0b8c, pipe=88000483, buffer=9ff07344, length=32, req=9ffafbac
TOKEN=0x9c00
dev=9ffb0b8c, pipe=88000403, buffer=(null), length=0, req=9ffafbac
TOKEN=0x8d00
dev=9ffb0b8c, pipe=88000483, buffer=9ff07120, length=255, req=9ffafbac
req=6 (0x6), type=128 (0x80), value=768 (0x300), index=0
TOKEN=0x9c00
req=6 (0x6), type=128 (0x80), value=769 (0x301), index=1033
TOKEN=0x9c00
req=6 (0x6), type=128 (0x80), value=770 (0x302), index=1033
TOKEN=0x9c00
req=6 (0x6), type=128 (0x80), value=771 (0x303), index=1033
TOKEN=0x9c00
req=0 (0x0), type=163 (0xa3), value=0 (0x0), index=4
TOKEN=0x9c00
req=0 (0x0), type=163 (0xa3), value=0 (0x0), index=5
TOKEN=0x9c00
req=0 (0x0), type=163 (0xa3), value=0, index=3
4 USB Device(s) found
scanning bus for storage devices... dev=9ffb0b8c, pipe=88000483, buffer=9ff07e37, length=1, req=9ffafbac
req=254 (0xfe), type=161 (0xa1), value=0 (0x0), index=0
TOKEN=0x9c00
dev=9ffb0b8c, pipe=c8010403, buffer=9ff07d7c, length=31, req=(null)
TOKEN=0x80008c01
dev=9ffb0b8c, pipe=c8008483, buffer=9ffba870, length=36, req=(null)
TOKEN=0x80008d00
dev=9ffb0b8c, pipe=c8008483, buffer=9ff07db8, length=13, req=(null)
TOKEN=0x8d00
dev=9ffb0b8c, pipe=c8010403, buffer=9ff07d5c, length=31, req=(null)
TOKEN=0x8c01
dev=9ffb0b8c, pipe=c8008483, buffer=9ff07d98, length=13, req=(null)
TOKEN=0x80008d00
TOKEN=0x80008c01
dev=9ffb0b8c, pipe=c8008483, buffer=9ffba5cc, length=18, req=(null)
TOKEN=0x8d00
TOKEN=0x80008d00
TOKEN=0x8c01
TOKEN=0x8d00
TOKEN=0x80008c01
dev=9ffb0b8c, pipe=c8008483, buffer=9ff07df0, length=8, req=(null)
TOKEN=0x80008d00
TOKEN=0x8d00
dev=9ffb0b8c, pipe=c8010403, buffer=9ff07b04, length=31, req=(null)
TOKEN=0x8c01
dev=9ffb0b8c, pipe=c8008483, buffer=9ff07b40, length=13, req=(null)
TOKEN=0x80008d00
dev=9ffb0b8c, pipe=c8010403, buffer=9ff07b24, length=31, req=(null)
TOKEN=0x80008c01
dev=9ffb0b8c, pipe=c8008483, buffer=9ff07be0, length=512, req=(null)
TOKEN=0x8d00
dev=9ffb0b8c, pipe=c8008483, buffer=9ff07b60, length=13, req=(null)
TOKEN=0x80008d00
1 Storage Device(s) found
scanning bus for ethernet devices... dev=9ffb0644, pipe=88000303, buffer=9ff07dec, length=4, req=9ffafbac
req=160 (0xa0), type=64 (0x40), value=0 (0x0), index=264
TOKEN=0x8d00
req=160 (0xa0), type=64 (0x40), value=0 (0x0), index=260
TOKEN=0x8d00
1 Ethernet Device(s) found
OMAP3 beagleboard.org # dhcp
dev=9ffb0644, pipe=88000303, buffer=9ff07d9c, length=4, req=9ffafbac
req=160 (0xa0), type=64 (0x40), value=0 (0x0), index=20
TOKEN=0x8d00
dev=9ffb0644, pipe=88000383, buffer=9ff07db4, length=4, req=9ffafbac
req=161 (0xa1), type=192 (0xc0), value=0 (0x0), index=20
TOKEN=0x9c00
req=160 (0xa0), type=64 (0x40), value=0 (0x0), index=32
TOKEN=0x8d00
req=161 (0xa1), type=192 (0xc0), value=0 (0x0), index=32
TOKEN=0x9c00
dev=9ffb0644, pipe=88000303, buffer=9ff07d8c, length=4, req=9ffafbac
TOKEN=0x8d00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
req=160 (0xa0), type=64 (0x40), value=0 (0x0), index=56
TOKEN=0x8d00
req=161 (0xa1), type=192 (0xc0), value=0 (0x0), index=56
TOKEN=0x9c00
req=160 (0xa0), type=64 (0x40), value=0 (0x0), index=108
TOKEN=0x8d00
req=161 (0xa1), type=192 (0xc0), value=0 (0x0), index=108
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
req=160 (0xa0), type=64 (0x40), value=0 (0x0), index=8
TOKEN=0x8d00
req=161 (0xa1), type=192 (0xc0), value=0 (0x0), index=0
TOKEN=0x9c00
req=160 (0xa0), type=64 (0x40), value=0 (0x0), index=284
TOKEN=0x8d00
req=160 (0xa0), type=64 (0x40), value=0 (0x0), index=44
TOKEN=0x8d00
dev=9ffb0644, pipe=88000383, buffer=9ffbb860, length=4, req=9ffafbac
req=161 (0xa1), type=192 (0xc0), value=0 (0x0), index=256
TOKEN=0x9c00
req=160 (0xa0), type=64 (0x40), value=0 (0x0), index=288
TOKEN=0x8d00
dev=9ffb0644, pipe=88000383, buffer=9ff07db0, length=4, req=9ffafbac
req=161 (0xa1), type=192 (0xc0), value=0 (0x0), index=304
TOKEN=0x9c00
req=160 (0xa0), type=64 (0x40), value=0 (0x0), index=304
TOKEN=0x8d00
dev=9ffb0644, pipe=88000383, buffer=9ff07d7c, length=4, req=9ffafbac
req=161 (0xa1), type=192 (0xc0), value=0 (0x0), index=276
TOKEN=0x9c00
dev=9ffb0644, pipe=88000303, buffer=9ff07d84, length=4, req=9ffafbac
req=160 (0xa0), type=64 (0x40), value=0 (0x0), index=280
TOKEN=0x8d00
req=160 (0xa0), type=64 (0x40), value=0 (0x0), index=276
TOKEN=0x8d00
dev=9ffb0644, pipe=88000383, buffer=9ff07d94, length=4, req=9ffafbac
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x8d00
TOKEN=0x9c00
dev=9ffb0644, pipe=88000383, buffer=9ff07d74, length=4, req=9ffafbac
TOKEN=0x9c00
dev=9ffb0644, pipe=88000303, buffer=9ff07d7c, length=4, req=9ffafbac
TOKEN=0x8d00
TOKEN=0x9c00
dev=9ffb0644, pipe=88000383, buffer=9ff07d8c, length=4, req=9ffafbac
req=161 (0xa1), type=192 (0xc0), value=0 (0x0), index=280
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x8d00
TOKEN=0x9c00
req=161 (0xa1), type=192 (0xc0), value=0 (0x0), index=104
TOKEN=0x9c00
req=160 (0xa0), type=64 (0x40), value=0 (0x0), index=104
TOKEN=0x8d00
req=160 (0xa0), type=64 (0x40), value=0 (0x0), index=256
TOKEN=0x8d00
req=160 (0xa0), type=64 (0x40), value=0 (0x0), index=16
TOKEN=0x8d00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
Waiting for Ethernet connection... dev=9ffb0644, pipe=88000383, buffer=9ff07d74, length=4, req=9ffafbac
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x9c00
TOKEN=0x8d00
TOKEN=0x9c00
TOKEN=0x9c00
done.
BOOTP broadcast 1
dev=9ffb0644, pipe=c8010303, buffer=9ff077dc, length=350, req=(null)
TOKEN=0x80008c00
dev=9ffb0644, pipe=c8008383, buffer=9ffbc1cc, length=2048, req=(null)
TOKEN=0x87bc8d00
TOKEN=0x6908d00
*** Unhandled DHCP Option in OFFER/ACK: 19
*** Unhandled DHCP Option in OFFER/ACK: 28
dev=9ffb0644, pipe=c8010303, buffer=9ff07754, length=350, req=(null)
TOKEN=0x8c00
TOKEN=0x86908d00
DHCP client bound to address 172.20.2.53
Using sms0 device
TFTP from server 0.0.0.0; our IP address is 172.20.2.53; sending through gateway 172.20.3.1
Filename 'uImage.beagle'.
Load address: 0x82000000
Loading: dev=9ffb0644, pipe=c8010303, buffer=9ff0770c, length=95, req=(null)
TOKEN=0x80008c00
TOKEN=0x7bc8d00
dev=9ffb0644, pipe=c8010303, buffer=9ff077b4, length=50, req=(null)
TOKEN=0x8c00
TOKEN=0x5828d00
dev=9ffb0644, pipe=c8010303, buffer=9ff077b4, length=70, req=(null)
TOKEN=0x80008c00
#dev=9ffb0644, pipe=c8010303, buffer=9ff07724, length=54, req=(null)
TOKEN=0x8c00
TOKEN=0x5ed8d00
TOKEN=0x5ca8d00
#dev=9ffb0644, pipe=c8008383, buffer=9ffbc1cc, length=2048, req=(null)
TOKEN=0x87248d00
T dev=9ffb0644, pipe=c8010303, buffer=9ff07794, length=54, req=(null)
TOKEN=0x80008c00
TOKEN=0x85ca8d00
TOKEN=0x72e8d00
TOKEN=0x5ca8d00
#T dev=9ffb0644, pipe=c8010303, buffer=9ff07794, length=54, req=(null)
TOKEN=0x8c00
TOKEN=0x87bc8d00
TOKEN=0x7bc8d00
TOKEN=0x87bc8d00
TOKEN=0x85ca8d00
EHCI timed out on TD - token=0x88008d80
EHCI timed out on TD - token=0x368c80
iMac:~ koen$
