eMMC drive disappears on BBAI-64
I am facing a strange problem,
When the system boots from the SD card with the image TDA4VM Debian 11.3 2022-06-14 10GB SD XFCE, I cannot see the eMMC.
The mmcblk1 is the SD card 32GB, not an eMMC.
debian@BeagleBone:~$ df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            991M     0  991M   0% /dev
tmpfs           215M  1.9M  213M   1% /run
/dev/mmcblk1p2   30G  8.1G   20G  30% /
tmpfs           1.1G     0  1.1G   0% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
/dev/mmcblk1p1  127M   46M   81M  37% /boot/firmware
tmpfs           215M   28K  215M   1% /run/user/1000
debian@BeagleBone:~$ lsblk
NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
mmcblk1     179:0    0 29.7G  0 disk
|-mmcblk1p1 179:1    0  128M  0 part /boot/firmware
`-mmcblk1p2 179:2    0 29.6G  0 part /
and
debian@BeagleBone:~$ sudo beagle-version
eeprom:[BBONEAI-64-B0-B0007801B00001643422BBBBBB2219]
model:[BeagleBoard.org_BeagleBone_AI-64]
dogtag:[BeagleBoard.org Debian Bullseye Xfce Image 2022-06-14]
strings: '/dev/mmcblk0boot0': No such file
bootloader:[/dev/mmcblk1]:[/boot/firmware/tiboot3.bin]:[U-Boot SPL 2021.01-g09210092 (Jun 01 2022 - 16:48:34 +0000)]
bootloader:[/dev/mmcblk1]:[/boot/firmware/tispl.bin]:[U-Boot SPL 2021.01-g09210092 (Jun 01 2022 - 16:48:34 +0000)]
bootloader:[/dev/mmcblk1]:[/boot/firmware/u-boot.img]:[U-Boot 2021.01-g09210092 (Jun 01 2022 - 16:48:34 +0000)]
UBOOT: Booted Device-Tree:[k3-j721e-beagleboneai64.dts]
kernel:[5.10.109-ti-arm64-r49]
nodejs:[v12.22.12]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade <pkg>]
pkg:[bb-customizations]:[1.20221108.0-0~bullseye+20221108]
pkg:[bb-usb-gadgets]:[1.20220816.0-0~bullseye+20220816]
cmdline:[console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0]
dmesg | grep remote
[    5.731512] remoteproc remoteproc0: b034000.pru is available
[    5.759181] remoteproc remoteproc1: b004000.rtu is available
[    5.765843] remoteproc remoteproc2: b00a000.txpru is available
[    5.772202] remoteproc remoteproc3: b038000.pru is available
[    5.778386] remoteproc remoteproc4: b006000.rtu is available
[    5.784568] remoteproc remoteproc5: b00c000.txpru is available
[    5.790860] remoteproc remoteproc6: b134000.pru is available
[    5.797012] remoteproc remoteproc7: b104000.rtu is available
[    5.803178] remoteproc remoteproc8: b10a000.txpru is available
[    5.809425] remoteproc remoteproc9: b138000.pru is available
[    5.815551] remoteproc remoteproc10: b106000.rtu is available
[    5.821817] remoteproc remoteproc11: b10c000.txpru is available
[   12.307760] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
[   12.371000] remoteproc remoteproc12: 4d80800000.dsp is available
[   12.442373] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
[   12.449864] remoteproc remoteproc12: powering up 4d80800000.dsp
[   12.456274] remoteproc remoteproc12: Booting fw image vision_apps_eaik/vx_app_rtos_linux_c6x_1.out, size 1461044
[   12.489205]  remoteproc12#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[   12.510147]  remoteproc12#vdev0buffer: registered virtio0 (type 7)
[   12.516378] remoteproc remoteproc12: remote processor 4d80800000.dsp is now up
[   12.525923] remoteproc remoteproc13: 4d81800000.dsp is available
[   12.556645] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
[   12.570642] remoteproc remoteproc14: 64800000.dsp is available
[   12.579530] remoteproc remoteproc13: powering up 4d81800000.dsp
[   12.591882] remoteproc remoteproc13: Booting fw image vision_apps_eaik/vx_app_rtos_linux_c6x_2.out, size 1461012
[   12.625335]  remoteproc13#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[   12.636634]  remoteproc13#vdev0buffer: registered virtio1 (type 7)
[   12.643190] remoteproc remoteproc13: remote processor 4d81800000.dsp is now up
[   12.946267] remoteproc remoteproc14: powering up 64800000.dsp
[   12.952058] remoteproc remoteproc14: Booting fw image vision_apps_eaik/vx_app_rtos_linux_c7x_1.out, size 13242432
[   12.972686] remoteproc remoteproc14: unsupported resource 65538
[   13.007454]  remoteproc14#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
[   13.018846]  remoteproc14#vdev0buffer: registered virtio2 (type 7)
[   13.027210] remoteproc remoteproc14: remote processor 64800000.dsp is now up
[   13.471901] remoteproc remoteproc15: 41000000.r5f is available
[   13.478016] remoteproc remoteproc15: attaching to 41000000.r5f
[   13.504157]  remoteproc15#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[   13.530925]  remoteproc15#vdev0buffer: registered virtio3 (type 7)
[   13.544671] remoteproc remoteproc15: remote processor 41000000.r5f is now attached
[   13.704597] platform 5c00000.r5f: configured R5F for remoteproc mode
[   13.800193] remoteproc remoteproc16: 5c00000.r5f is available
[   13.923965] platform 5d00000.r5f: configured R5F for remoteproc mode
[   13.934492] remoteproc remoteproc16: powering up 5c00000.r5f
[   13.940300] remoteproc remoteproc16: Booting fw image vision_apps_eaik/vx_app_rtos_linux_mcu2_0.out, size 572788
[   13.968224]  remoteproc16#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[   13.977867]  remoteproc16#vdev0buffer: registered virtio4 (type 7)
[   13.984079] remoteproc remoteproc16: remote processor 5c00000.r5f is now up
[   13.986742] remoteproc remoteproc17: 5d00000.r5f is available
[   13.997896] remoteproc remoteproc17: powering up 5d00000.r5f
[   13.997906] remoteproc remoteproc17: Booting fw image vision_apps_eaik/vx_app_rtos_linux_mcu2_1.out, size 297932
[   14.002852]  remoteproc17#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[   14.002923]  remoteproc17#vdev0buffer: registered virtio5 (type 7)
[   14.002927] remoteproc remoteproc17: remote processor 5d00000.r5f is now up
[   14.050351] platform 5e00000.r5f: configured R5F for remoteproc mode
[   14.052915] remoteproc remoteproc18: 5e00000.r5f is available
[   14.053096] remoteproc remoteproc18: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[   14.053104] remoteproc remoteproc18: powering up 5e00000.r5f
[   14.053121] remoteproc remoteproc18: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[   14.053125] remoteproc remoteproc18: request_firmware failed: -2
[   14.087025] platform 5f00000.r5f: configured R5F for remoteproc mode
[   14.144864] remoteproc remoteproc19: 5f00000.r5f is available
[   14.145022] remoteproc remoteproc19: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[   14.145028] remoteproc remoteproc19: powering up 5f00000.r5f
[   14.145047] remoteproc remoteproc19: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[   14.145051] remoteproc remoteproc19: request_firmware failed: -2
dmesg | grep pru
dmesg | grep pinctrl-single
[    1.392652] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    1.398910] pinctrl-single 11c000.pinctrl: 173 pins, size 692
dmesg | grep gpio-of-helper
lsusb
Bus 002 Device 002: ID 0451:8140 Texas Instruments, Inc. TUSB8041 4-Port Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 8087:0025 Intel Corp. Wireless-AC 9260 Bluetooth Adapter
Bus 001 Device 004: ID 1c4f:0026 SiGma Micro Keyboard
Bus 001 Device 003: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 002: ID 0451:8142 Texas Instruments, Inc. TUSB8041 4-Port Hub
END
Please note ‘/dev/mmcblk0boot0’: No such file
And of course, I can’t boot the system from eMMC when I remove the SD card (the BBAI-64 did not start, the Led kernel heartbeat not blinking, no logs serial port).
Now, I turn off power and boot from the SD card, and the system starts and boots OS normally.
The clear log from turn on power to login
Model: Texas Instruments K3 J721E SoC
Board: BBONEAI-64-B0- rev B0
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
TLB table from ffffc000 to 00000000
>>SPL: board_init_r()
spl_init
Trying to boot from MMC2
spl: mmc boot mode: fs
board_fit_image_post_process: processing image: addr=70000000, size=39864, os=arm-trusted-firmware
board_fit_image_post_process: matched image for ID 0
board_fit_image_post_process: processing image: addr=9e800000, size=374648, os=tee
board_fit_image_post_process: matched image for ID 1
board_fit_image_post_process: processing image: addr=89000000, size=217356, os=DM
board_fit_image_post_process: matched image for ID 3
board_fit_image_post_process: processing image: addr=80080000, size=163168, os=U-Boot
board_fit_image_post_process: matched image for ID 2
board_fit_image_post_process: processing image: addr=ffffffff, size=10103, os=
Unsupported OS image.. Jumping nevertheless..
loaded - jumping to U-Boot...
jump_to_image_no_args: jumping to address 41010000
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.5(release):0588523
NOTICE:  BL31: Built : 16:48:34, Jun  1 2022
TLB table from ffff4000 to 100000000
SPL malloc() before relocation used 0x2500 bytes (9 KB)
>>SPL: board_init_r()
spl_init
ti_i2c_eeprom_am6_parse_record: Ignoring record id 17
Jumping to U-Boot
image entry point: 0x80800000
SoC:   J721E SR2.0
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   am65_cpsw_nuss_slave ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
eth0: ethernet@46000000
Press SPACE to abort autoboot in 2 seconds
board_name=[BBONEAI-64-B0-] ...
name_fdt=[k3-j721e-beagleboneai64.dtb] ...
i2c_write: error waiting for data ACK (status=0x116)
pca953x gpio@22: Error reading output register
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
206 bytes read in 8 ms (24.4 KiB/s)
1:      Linux microSD
Retrieving file: /initrd.img
15780943 bytes read in 681 ms (22.1 MiB/s)
Retrieving file: /Image
28889600 bytes read in 1237 ms (22.3 MiB/s)
append: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0
Retrieving file: /k3-j721e-beagleboneai64.dtb
207687 bytes read in 20 ms (9.9 MiB/s)
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8f0f3000, end 8ffffc4f ... OK
   Loading Device Tree to 000000008f0bd000, end 000000008f0f2b46 ... OK
Linux kernel Image start = 0x82000000 end = 0x83c50000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.145-ti-arm64-r72 (voodoo@rpi4b8g-19) (gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1bullseye SMP Sun Nov 6 02:37:37 UTC 2022
[    0.000000] Machine model: BeagleBoard.org BeagleBone AI-64
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 560 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@fb000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb800000, size 24 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@fb800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000aeffffff]
[    0.000000]   node   0: [mem 0x00000000af000000-0x00000000afffffff]
[    0.000000]   node   0: [mem 0x00000000b0000000-0x00000000b7ffffff]
[    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000fcffffff]
[    0.000000]   node   0: [mem 0x00000000fd000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x000000088fffffff]
[    0.000000]   node   0: [mem 0x0000000890000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] cma: Reserved 144 MiB at 0x0000000095800000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 31 pages/cpu s88984 r8192 d29800 u126976
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x0000000091800000-0x0000000095800000] (64MB)
[    0.000000] Memory: 2063780K/4194304K available (16896K kernel code, 2228K rwdata, 5236K rodata, 3712K init, 721K bss, 1983068K reserved, 147456K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @890800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008900d0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008900e0000
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008544] Console: colour dummy device 80x25
[    0.013109] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023779] pid_max: default: 32768 minimum: 301
[    0.028618] LSM: Security Framework initializing
[    0.033354] Yama: becoming mindful.
[    0.036980] AppArmor: AppArmor initialized
[    0.041166] TOMOYO Linux initialized
[    0.044880] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.052456] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.061496] rcu: Hierarchical SRCU implementation.
[    0.066980] Platform MSI: msi-controller@1820000 domain created
[    0.073414] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.082795] EFI services will not be available.
[    0.087665] smp: Bringing up secondary CPUs ...
[    0.092970] Detected PIPT I-cache on CPU1
[    0.092992] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.093003] GICv3: CPU1: using allocated LPI pending table @0x00000008900f0000
[    0.093038] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.093095] smp: Brought up 1 node, 2 CPUs
[    0.122439] SMP: Total of 2 processors activated.
[    0.127242] CPU features: detected: 32-bit EL0 Support
[    0.132490] CPU features: detected: CRC32 instructions
[    0.156216] CPU: All CPU(s) started at EL2
[    0.160429] alternatives: patching kernel code
[    0.165589] devtmpfs: initialized
[    0.180750] KASLR disabled due to lack of seed
[    0.185427] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.195407] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.204254] pinctrl core: initialized pinctrl subsystem
[    0.209938] DMI not present or invalid.
[    0.214252] NET: Registered protocol family 16
[    0.219513] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.226824] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.234876] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.242987] audit: initializing netlink subsys (disabled)
[    0.248669] audit: type=2000 audit(0.160:1): state=initialized audit_enabled=0 res=1
[    0.248956] thermal_sys: Registered thermal governor 'fair_share'
[    0.256588] thermal_sys: Registered thermal governor 'bang_bang'
[    0.262813] thermal_sys: Registered thermal governor 'step_wise'
[    0.268947] thermal_sys: Registered thermal governor 'user_space'
[    0.275081] thermal_sys: Registered thermal governor 'power_allocator'
[    0.281918] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.295557] ASID allocator initialised with 65536 entries
[    0.326087] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.332948] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.339818] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.346665] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.354466] cryptd: max_cpu_qlen set to 1000
[    0.360526] raid6: skip pq benchmark and using algorithm neonx8
[    0.366586] raid6: using neon recovery algorithm
[    0.371784] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.380593] vsys_3v3: supplied by evm_12v0
[    0.384940] vsys_5v0: supplied by evm_12v0
[    0.389530] iommu: Default domain type: Translated
[    0.394795] SCSI subsystem initialized
[    0.398717] usbcore: registered new interface driver usbfs
[    0.404354] usbcore: registered new interface driver hub
[    0.409792] usbcore: registered new device driver usb
[    0.415253] mc: Linux media interface: v0.10
[    0.419622] videodev: Linux video capture interface: v2.00
[    0.425259] pps_core: LinuxPPS API ver. 1 registered
[    0.430330] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.439667] PTP clock support registered
[    0.443686] EDAC MC: Ver: 3.0.0
[    0.447885] NetLabel: Initializing
[    0.451357] NetLabel:  domain hash size = 128
[    0.455809] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.461617] NetLabel:  unlabeled traffic allowed by default
[    0.467633] clocksource: Switched to clocksource arch_sys_counter
[    0.788062] VFS: Disk quotas dquot_6.6.0
[    0.792121] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.799232] FS-Cache: Loaded
[    0.802372] CacheFiles: Loaded
[    0.805754] AppArmor: AppArmor Filesystem Enabled
[    0.813976] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[    0.820310] NET: Registered protocol family 2
[    0.825040] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.833810] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.842794] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.851211] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.858956] TCP: Hash tables configured (established 32768 bind 32768)
[    0.865907] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[    0.873573] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.880503] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.887931] NET: Registered protocol family 1
[    0.892780] RPC: Registered named UNIX socket transport module.
[    0.898844] RPC: Registered udp transport module.
[    0.903648] RPC: Registered tcp transport module.
[    0.908451] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.915033] NET: Registered protocol family 44
[    0.919578] PCI: CLS 0 bytes, default 64
[    0.923691] Trying to unpack rootfs image as initramfs...
[    1.209897] Freeing initrd memory: 15408K
[    1.214696] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    1.225490] Initialise system trusted keyrings
[    1.230130] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    1.238819] zbud: loaded
[    1.242468] NFS: Registering the id_resolver key type
[    1.247706] Key type id_resolver registered
[    1.251977] Key type id_legacy registered
[    1.256115] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.262963] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.270532] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    1.278129] fuse: init (API version 7.32)
[    1.302682] xor: measuring software checksum speed
[    1.308855]    8regs           :  7754 MB/sec
[    1.314388]    32regs          :  9064 MB/sec
[    1.320040]    arm64_neon      :  8180 MB/sec
[    1.324487] xor: using function: 32regs (9064 MB/sec)
[    1.329650] Key type asymmetric registered
[    1.333831] Asymmetric key parser 'x509' registered
[    1.338833] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    1.346460] io scheduler mq-deadline registered
[    1.352720] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    1.358971] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    1.368040] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    1.374299] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    1.380644] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[    1.387061] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[    1.395065] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[    1.401488] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[    1.409435] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[    1.415860] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[    1.423814] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[    1.430138] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[    1.438085] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[    1.444408] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[    1.454359] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    1.463097] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    1.471350] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[    1.478406] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[    1.486820] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    1.499558] brd: module loaded
[    1.631670] loop: module loaded
[    1.635514] megasas: 07.714.04.00-rc1
[    1.641828] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    1.648254] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.654338] sky2: driver version 1.30
[    1.658753] VFIO - User Level meta-driver version: 0.3
[    1.664496] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.671203] ehci-pci: EHCI PCI platform driver
[    1.676127] usbcore: registered new interface driver uas
[    1.681584] usbcore: registered new interface driver usb-storage
[    1.688406] i2c /dev entries driver
[    1.692112] Driver for 1-wire Dallas network protocol.
[    1.697383] DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko
[    1.704427] sdhci: Secure Digital Host Controller Interface driver
[    1.710744] sdhci: Copyright(c) Pierre Ossman
[    1.715450] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.723558] ledtrig-cpu: registered to indicate activity on CPUs
[    1.729913] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.736531] hid: raw HID events driver (C) Jiri Kosina
[    1.741893] usbcore: registered new interface driver usbhid
[    1.747586] usbhid: USB HID core driver
[    1.752003] optee: probing for conduit method.
[    1.756557] optee: revision 3.12 (cac3fef2)
[    1.756823] optee: initialized driver
[    1.765926] drop_monitor: Initializing network drop monitor service
[    1.772704] NET: Registered protocol family 10
[    1.792010] Segment Routing with IPv6
[    1.795861] mip6: Mobile IPv6
[    1.798889] NET: Registered protocol family 17
[    1.803533] Key type dns_resolver registered
[    1.807916] mpls_gso: MPLS GSO support
[    1.811897] registered taskstats version 1
[    1.816084] Loading compiled-in X.509 certificates
[    1.821041] zswap: loaded using pool lzo/zbud
[    1.825636] Key type ._fscrypt registered
[    1.829737] Key type .fscrypt registered
[    1.833740] Key type fscrypt-provisioning registered
[    1.842388] Btrfs loaded, crc32c=crc32c-generic
[    1.847110] AppArmor: AppArmor sha1 policy hashing enabled
[    1.857256] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    1.863607] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    1.873404] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
[    1.933223] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    1.939381] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    1.945871] at24 2-0050: supply vcc not found, using dummy regulator
[    1.975767] at24 2-0050: 512 byte 24c04 EEPROM, writable, 1 bytes/write
[    1.982559] omap_i2c 42120000.i2c: bus 2 rev0.12 at 400 kHz
[    1.988843] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[    1.995955] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[    2.002254] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[    2.008765] omap_i2c 2050000.i2c: bus 6 rev0.12 at 400 kHz
[    2.015218] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    2.025203] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    2.034027] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    2.043899] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    2.067987] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.075655] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.083933] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.092209] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.101591] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    2.111481] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    2.118241] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    2.127469] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    2.137621] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    2.144380] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    2.152371] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[    2.161844] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 30, base_baud = 3000000) is a 8250
[    2.170594] printk: console [ttyS2] enabled
[    2.179032] printk: bootconsole [ns16550a0] disabled
[    2.189558] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 31, base_baud = 3000000) is a 8250
[    2.198532] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 32, base_baud = 3000000) is a 8250
[    2.215582] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[    2.222740] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
[    2.235302] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[    2.279633] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.291330] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    2.299656] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    2.312468] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    2.319674] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    2.326056] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    2.336276] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
[    2.379633] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.387190] davinci_mdio c000f00.mdio: no live phy, scanning all
[    2.504919] davinci_mdio c000f00.mdio: phy[0]: device c000f00.mdio:00, driver unknown
[    2.512789] davinci_mdio c000f00.mdio: phy[1]: device c000f00.mdio:01, driver unknown
[    2.520606] davinci_mdio c000f00.mdio: phy[2]: device c000f00.mdio:02, driver unknown
[    2.528419] davinci_mdio c000f00.mdio: phy[3]: device c000f00.mdio:03, driver unknown
[    2.536229] davinci_mdio c000f00.mdio: phy[4]: device c000f00.mdio:04, driver unknown
[    2.544038] davinci_mdio c000f00.mdio: phy[5]: device c000f00.mdio:05, driver unknown
[    2.551850] davinci_mdio c000f00.mdio: phy[6]: device c000f00.mdio:06, driver unknown
[    2.559664] davinci_mdio c000f00.mdio: phy[7]: device c000f00.mdio:07, driver unknown
[    2.567476] davinci_mdio c000f00.mdio: phy[8]: device c000f00.mdio:08, driver unknown
[    2.575287] davinci_mdio c000f00.mdio: phy[9]: device c000f00.mdio:09, driver unknown
[    2.583097] davinci_mdio c000f00.mdio: phy[10]: device c000f00.mdio:0a, driver unknown
[    2.590995] davinci_mdio c000f00.mdio: phy[11]: device c000f00.mdio:0b, driver unknown
[    2.598892] davinci_mdio c000f00.mdio: phy[12]: device c000f00.mdio:0c, driver unknown
[    2.606790] davinci_mdio c000f00.mdio: phy[13]: device c000f00.mdio:0d, driver unknown
[    2.614687] davinci_mdio c000f00.mdio: phy[14]: device c000f00.mdio:0e, driver unknown
[    2.622587] davinci_mdio c000f00.mdio: phy[15]: device c000f00.mdio:0f, driver unknown
[    2.630488] davinci_mdio c000f00.mdio: phy[16]: device c000f00.mdio:10, driver unknown
[    2.638387] davinci_mdio c000f00.mdio: phy[17]: device c000f00.mdio:11, driver unknown
[    2.646285] davinci_mdio c000f00.mdio: phy[18]: device c000f00.mdio:12, driver unknown
[    2.654182] davinci_mdio c000f00.mdio: phy[19]: device c000f00.mdio:13, driver unknown
[    2.662080] davinci_mdio c000f00.mdio: phy[20]: device c000f00.mdio:14, driver unknown
[    2.669977] davinci_mdio c000f00.mdio: phy[21]: device c000f00.mdio:15, driver unknown
[    2.677875] davinci_mdio c000f00.mdio: phy[22]: device c000f00.mdio:16, driver unknown
[    2.685774] davinci_mdio c000f00.mdio: phy[23]: device c000f00.mdio:17, driver unknown
[    2.693672] davinci_mdio c000f00.mdio: phy[24]: device c000f00.mdio:18, driver unknown
[    2.701569] davinci_mdio c000f00.mdio: phy[25]: device c000f00.mdio:19, driver unknown
[    2.709467] davinci_mdio c000f00.mdio: phy[26]: device c000f00.mdio:1a, driver unknown
[    2.717364] davinci_mdio c000f00.mdio: phy[27]: device c000f00.mdio:1b, driver unknown
[    2.725261] davinci_mdio c000f00.mdio: phy[28]: device c000f00.mdio:1c, driver unknown
[    2.733161] davinci_mdio c000f00.mdio: phy[29]: device c000f00.mdio:1d, driver unknown
[    2.741058] davinci_mdio c000f00.mdio: phy[30]: device c000f00.mdio:1e, driver unknown
[    2.748957] davinci_mdio c000f00.mdio: phy[31]: device c000f00.mdio:1f, driver unknown
[    2.756928] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA01901, cpsw version 0x6BA80101 Ports: 9 quirks:00000000
[    2.769606] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@1 error retrieving port phy: -19
[    2.782962] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    2.795161] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.800668] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    2.808409] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[    2.817799] xhci-hcd xhci-hcd.0.auto: irq 232, io mem 0x06410000
[    2.823977] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    2.832228] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.839452] usb usb1: Product: xHCI Host Controller
[    2.844316] usb usb1: Manufacturer: Linux 5.10.145-ti-arm64-r72 xhci-hcd
[    2.850999] usb usb1: SerialNumber: xhci-hcd.0.auto
[    2.856087] hub 1-0:1.0: USB hub found
[    2.859848] hub 1-0:1.0: 1 port detected
[    2.863912] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.869395] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    2.877038] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    2.883602] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.891736] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    2.899982] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.907186] usb usb2: Product: xHCI Host Controller
[    2.912049] usb usb2: Manufacturer: Linux 5.10.145-ti-arm64-r72 xhci-hcd
[    2.918740] usb usb2: SerialNumber: xhci-hcd.0.auto
[    2.923790] hub 2-0:1.0: USB hub found
[    2.927543] hub 2-0:1.0: 1 port detected
[    3.034162] mmc0: CQHCI version 5.10
[    3.040166] gpio gpiochip2: gpio-line-names is length 37 but should be at most length 36
[    3.049229] vdd_mmc1: supplied by vsys_3v3
[    3.054330] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    3.061202] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    3.068052] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    3.074265] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    3.074897] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    3.088900] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    3.099087] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.106597] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.114680] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.122759] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.123640] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    3.193392] mmc0: mmc_select_hs200 failed, error -110
[    3.198436] mmc0: error -110 whilst initialising MMC card
[    3.233491] j721e-pcie 2910000.pcie: Link up
[    3.237757] j721e-pcie 2910000.pcie: Link up
[    3.242087] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
[    3.248346] pci_bus 0000:00: root bus resource [bus 00-ff]
[    3.253820] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x18001000-0x18010fff])
[    3.263278] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
[    3.270172] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[    3.276174] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    3.285869] pci 0000:00:00.0: supports D1
[    3.289868] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    3.296528] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[    3.299240] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.304704] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[    3.312824] pci 0000:01:00.0: [8086:2526] type 00 class 0x028000
[    3.319800] usb 1-1: SerialNumber: D20508591EA6
[    3.330369] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    3.337267] hub 1-1:1.0: USB hub found
[    3.337396] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[    3.347103] hub 1-1:1.0: 4 ports detected
[    3.359178] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    3.365808] pci 0000:00:00.0: BAR 14: assigned [mem 0x18100000-0x181fffff]
[    3.372671] pci 0000:01:00.0: BAR 0: assigned [mem 0x18100000-0x18103fff 64bit]
[    3.379983] pci 0000:00:00.0: PCI bridge to [bus 01]
[    3.384938] pci 0000:00:00.0:   bridge window [mem 0x18100000-0x181fffff]
[    3.391904] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    3.398136] pcieport 0000:00:00.0: PME: Signaling with IRQ 506
[    3.404148] pcieport 0000:00:00.0: AER: enabled with IRQ 506
[    3.410871] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    3.421972] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[    3.437065] spi-nor spi11.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    3.444027] spi-nor: probe of spi11.0 failed with error -2
[    3.479666] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[    3.497668] mmc0: mmc_select_hs200 failed, error -110
[    3.502711] mmc0: error -110 whilst initialising MMC card
[    3.503869] usb 2-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 1.00
[    3.516255] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.523870] hub 2-1:1.0: USB hub found
[    3.527630] hub 2-1:1.0: 4 ports detected
[    3.627816] mmc0: mmc_select_hs200 failed, error -110
[    3.632860] mmc0: error -110 whilst initialising MMC card
[    3.639632] usb 1-1.1: new full-speed USB device number 3 using xhci-hcd
[    3.679571] Console: switching to colour frame buffer device 160x45
[    3.701765] tidss 4a00000.dss: [drm] fb0: tidssdrmfb frame buffer device
[    3.746404] usb 1-1.1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.09
[    3.754742] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.762035] usb 1-1.1: Product: USB Receiver
[    3.766294] usb 1-1.1: Manufacturer: Logitech
[    3.783054] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-xhci-hcd.0.auto-1.1/input2
[    3.843102] mmc0: mmc_select_hs200 failed, error -110
[    3.848147] mmc0: error -110 whilst initialising MMC card
[    3.925986] input: Logitech M585/M590 as /devices/platform/bus@100000/4114000.cdns-usb/6400000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.2/0003:046D:C52B.0003/0003:046D:406B.0004/input/input0
[    3.943415] logitech-hidpp-device 0003:046D:406B.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech M585/M590] on usb-xhci-hcd.0.auto-1.1/input2:1
[    3.999636] usb 1-1.2: new low-speed USB device number 4 using xhci-hcd
[    4.108972] usb 1-1.2: New USB device found, idVendor=1c4f, idProduct=0026, bcdDevice= 1.10
[    4.117305] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.124599] usb 1-1.2: Product: USB Keyboard
[    4.128856] usb 1-1.2: Manufacturer: SIGMACHIP
[    4.140679] input: SIGMACHIP USB Keyboard as /devices/platform/bus@100000/4114000.cdns-usb/6400000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:1C4F:0026.0005/input/input1
[    4.172053] mmc1: CQHCI version 5.10
[    4.172186] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[    4.182848] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[    4.191383] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    4.198712] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    4.206031] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    4.213345] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    4.221823] input: gpio-keys as /devices/platform/gpio-keys/input/input2
[    4.228839] hid-generic 0003:1C4F:0026.0005: input,hidraw2: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-xhci-hcd.0.auto-1.2/input0
[    4.228966] of_cfs_init
[    4.244035] of_cfs_init: OK
[    4.247520] input: SIGMACHIP USB Keyboard Consumer Control as /devices/platform/bus@100000/4114000.cdns-usb/6400000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.1/0003:1C4F:0026.0006/input/input3
[    4.323776] input: SIGMACHIP USB Keyboard System Control as /devices/platform/bus@100000/4114000.cdns-usb/6400000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.1/0003:1C4F:0026.0006/input/input4
[    4.340910] hid-generic 0003:1C4F:0026.0006: input,hidraw3: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-xhci-hcd.0.auto-1.2/input1
[    4.431636] usb 1-1.3: new full-speed USB device number 5 using xhci-hcd
[    4.536772] usb 1-1.3: New USB device found, idVendor=8087, idProduct=0025, bcdDevice= 0.02
[    4.545106] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    5.236297] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    5.246080] Freeing unused kernel memory: 3712K
[    5.272692] Checked W+X mappings: passed, no W+X pages found
[    5.278366] Run /init as init process
Loading, please wait...
[    5.297601] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
[    5.304764] mmcblk1: mmc1:aaaa SC32G 29.7 GiB
[    5.314095]  mmcblk1: p1 p2
Starting version 247.3-7+deb11u1
[    6.031512] remoteproc remoteproc0: b034000.pru is available
[    6.037491] remoteproc remoteproc1: b004000.rtu is available
[    6.047453] remoteproc remoteproc2: b00a000.txpru is available
[    6.053541] remoteproc remoteproc3: b038000.pru is available
[    6.059381] remoteproc remoteproc4: b006000.rtu is available
[    6.065268] remoteproc remoteproc5: b00c000.txpru is available
[    6.071283] remoteproc remoteproc6: b134000.pru is available
[    6.077110] remoteproc remoteproc7: b104000.rtu is available
[    6.082959] remoteproc remoteproc8: b10a000.txpru is available
[    6.088951] remoteproc remoteproc9: b138000.pru is available
[    6.094751] remoteproc remoteproc10: b106000.rtu is available
[    6.100696] remoteproc remoteproc11: b10c000.txpru is available
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
Begin: Will now check root file system ... fsck from util-linux 2.36.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk1p2] fsck.ext4 -a -C0 /dev/mmcblk1p2
rootfs: clean, 123635/1941504 files, 2300615/7758715 blocks
done.
[    6.442776] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... done.
[    6.560143] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[    6.908450] systemd[1]: System time before build time, advancing clock.
[    7.000506] systemd[1]: systemd 247.3-7+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[    7.023655] systemd[1]: Detected architecture arm64.
Welcome to Debian GNU/Linux 11 (bullseye)!
[    7.036646] systemd[1]: Set hostname to <BeagleBone>.
[    7.328844] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[    7.420730] systemd[1]: Queued start job for default target Graphical Interface.
[    7.428139] systemd[1]: Unnecessary job for /dev/bone/uart/0 was removed.
[    7.434928] systemd[1]: Unnecessary job for /sys/devices/platform/bus@100000/2800000.serial/tty/ttyS2 was removed.
[    7.448913] random: systemd: uninitialized urandom read (16 bytes read)
[    7.481343] systemd[1]: Created slice system-getty.slice.
[    7.487029] random: systemd: uninitialized urandom read (16 bytes read)
[  OK  ] Created slice system-getty.slice    7.494518] systemd[1]: Created slice system-modprobe.slice.
m.
[    7.504982] random: systemd: uninitialized urandom read (16 bytes read)
[  OK  ] Created slice system-modprobe.slice[    7.512957] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgett[    7.524513] systemd[1]: Created slice User and Session Slice.
y.slice.
[    7.535910] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Created slice User and Session Slic[    7.544966] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
e.
[  OK  ] Started Forward Password R[    7.559683] systemd[1]: Reached target Remote File Systems.
…uests to Wall Directory Watch.
[  OK  ] Set [    7.570581] systemd[1]: Reached target Slices.
up automount Arbitrary…s File System Automount Point systemd[1]: Reached target Swap.
[0m.
[  OK  ] Reached target Remote File S[    7.590671] systemd[1]: Listening on Syslog Socket.
ystems.
[  OK  ] Reached target Slices[    7.601092] systemd[1]: Listening on fsck to fsckd communication Socket.
[  OK  ] Reached target Swap.
[    7.613134] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on Syslog Socket.
[[    7.625408] systemd[1]: Listening on Journal Audit Socket.
  OK  ] Listening on fsck to fsckd communica[    7.636264] systemd[1]: Listening on Journal Socket (/dev/log).
tion Socket.
[  OK  ] Listening on ini[    7.647781] systemd[1]: Listening on Journal Socket.
[  OK  ] Listeni[    7.658339] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] L[    7.670179] systemd[1]: Listening on udev Control Socket.
[  [    7.680987] systemd[1]: Listening on udev Kernel Socket.
OK  ] Listening on Journal Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Listening on udev Kernel[    7.713363] systemd[1]: Mounting Huge Pages File System...
 Socket.
[    7.721936] systemd[1]: Mounting POSIX Message Queue File System...
         Mounting POSIX Message Queue File System..[    7.734909] systemd[1]: Mounting /sys/kernel/debug...
[    7.745820] systemd[1]: Mounting Kernel Trace File System...
[    7.757126] systemd[1]: Starting Set the console keyboard layout...
         Starting Set the console keyboard layout..[    7.768422] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st…odes for the curr[    7.782394] systemd[1]: Starting Load Kernel Module configfs...
ent kernel...
[    7.794174] systemd[1]: Starting Load Kernel Module drm...
[    7.806913] systemd[1]: Starting Load Kernel Module fuse...
[    7.817851] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    7.830050] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.858943] systemd[1]: Starting Journal Service...
[    7.871939] systemd[1]: Starting Load Kernel Modules...
[    7.913955] systemd[1]: Starting Remount Root and Kernel File Systems...
         Starting Remount Root and Kernel File Systems NET: Registered protocol family 36
[    7.926205] systemd[1]: Starting Coldplug All udev Devices...
[0m...
[    7.949917] systemd[1]: Mounted Huge Pages File System.
[    7.955404] usbcore: registered new interface driver wpanusb
[    7.955877] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted Huge Pages File System.[    7.972320] systemd[1]: Mounted /sys/kernel/debug.
[  OK  ] Mounted POSIX Message Queue File[    7.977960] systemd[1]: Mounted Kernel Trace File System.
 System.
[  OK  ] Mounted /sys/kernel/[    7.990656] systemd[1]: Finished Set the console keyboard layout.
debug.
[  OK  ] Mounted Kernel Trace F[    8.001504] systemd[1]: Finished Create list of static device nodes for the current kernel.
ile System.
[    8.014802] systemd[1]: modprobe@configfs.service: Succeeded.
[  OK  ] Finished Set the console keyboard l[    8.021826] systemd[1]: Finished Load Kernel Module configfs.
ayout.
[  OK  ] Finished Create list of st… nodes for the current kernel.
[    8.041586] gb_bootrom: module is from the staging directory, the quality is unknown, you have been warned.
[  OK  ] Finished Load Kernel Module configf[    8.052754] systemd[1]: modprobe@drm.service: Succeeded.
s.
[    8.066049] EXT4-fs (mmcblk1p2): re-mounted. Opts: errors=remount-ro
[    8.073138] systemd[1]: Finished Load Kernel Module drm.
[    8.084009] greybus: registered new driver bootrom
[  OK  ] Finished Load Kernel Module drm[    8.091195] systemd[1]: modprobe@fuse.service: Succeeded.
[    8.102475] systemd[1]: Finished Load Kernel Module fuse.
[    8.108418] gb_spilib: module is from the staging directory, the quality is unknown, you have been warned.
[    8.118727] systemd[1]: Started Journal Service.
[  OK  ] Finished Load Kernel Module fuse    8.125359] gb_firmware: module is from the staging directory, the quality is unknown, you have been warned.
m.
[  OK  ] Started Journal Service.
[    8.140098] greybus: registered new driver gb-firmware
[  OK  ] Finished Remount Root and Kernel Fi[    8.154097] gb_gbphy: module is from the staging directory, the quality is unknown, you have been warned.
le Systems.
[    8.165253] greybus: registered new driver gbphy
[    8.181294] gb_gpio: module is from the staging directory, the quality is unknown, you have been warned.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System    8.198601] gb_gbphy: registered new driver gpio
m...
         Starting Flush Journal to Persistent Storage...
         Starting Load/Save Random Seed...
         Starting Create System Users...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[    8.238756] systemd-journald[413]: Received client request to flush runtime journal.
[    8.247288] gb_hid: module is from the staging directory, the quality is unknown, you have been warned.
[    8.257157] greybus: registered new driver hid
[    8.261504] systemd-journald[413]: File /var/log/journal/2bda0d0cd8b24efcac2afdbf9138d6f9/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    8.280459] gb_i2c: module is from the staging directory, the quality is unknown, you have been warned.
[    8.290773] gb_gbphy: registered new driver i2c
[    8.304269] gb_log: module is from the staging directory, the quality is unknown, you have been warned.
[    8.314108] greybus: registered new driver log
[    8.335998] gb_loopback: module is from the staging directory, the quality is unknown, you have been warned.
[    8.346784] greybus: registered new driver loopback
[  OK  ] Finished Create System Users.
[    8.381321] gb_raw: module is from the staging directory, the quality is unknown, you have been warned.
         Starting Create Static Device Nodes in /dev...
[    8.412166] greybus: registered new driver raw
[  OK  ] Finished Coldplug All udev Devices gb_spi: module is from the staging directory, the quality is unknown, you have been warned.
[0m.
[    8.435345] gb_gbphy: registered new driver spi
[    8.839120] gb_uart: module is from the staging directory, the quality is unknown, you have been warned.
[    8.850740] gb_gbphy: registered new driver uart
         Starting Helper to synchronize boot up for ifupdown...
[    8.874626] random: systemd: uninitialized urandom read (16 bytes read)
[  OK  ] Finished Load Kernel Modules.
         Starting Apply Kernel Variables...
[  OK  ] Finished Helper to synchronize boot up for ifupdown.
[  OK  ] Finished Flush Journal to Persisten[    8.903255] random: systemd: uninitialized urandom read (16 bytes read)
t Storage.
[  OK  ] Finished Create St[    8.913866] random: systemd-journal: uninitialized urandom read (16 bytes read)
[  OK  ] Reached target Local File Systems (Pre).
         Starting Rule-based Manage…for Device Events and Files...
[  OK  ] Finished Apply Kernel Variables.
[  OK  ] Started Rule-based Manager for Device Events and Files.
         Starting Show Plymouth Boot Screen...
         Starting Network Service...
[  OK  ] Started Show Plymouth Boot Screen.
[  OK  ] Started Forward Password R…s to Plymouth Directory Watch.
[  OK  ] Reached target Local Encrypted Volumes.
[  OK  ] Reached target Paths.
[  OK  ] Started Network Service.
[    9.252027] am65-cpsw-nuss 46000000.ethernet: down msc_sl f0000000 tmo 0
[    9.265722] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    9.283170] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[    9.292679] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[  OK  ] Found device /dev/ttyS2.
[    9.928177] random: crng init done
[    9.931580] random: 73 urandom warning(s) missed due to ratelimiting
[    9.944066] ov5640 4-003c: supply DOVDD not found, using dummy regulator
[    9.950970] ov5640 4-003c: supply AVDD not found, using dummy regulator
[    9.957706] ov5640 4-003c: supply DVDD not found, using dummy regulator
[  OK  ] Reached target Hardware activated USB gadget.
[  OK  ] Finished Load/Save Random Seed.
[   10.037062] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
[   10.104149] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[   10.121679] img_enc 4200000.video-encoder: encoder registered as /dev/video0
[   10.163748] ov5640 4-003c: ov5640_read_reg: error: reg=300a
[   10.169353] ov5640 4-003c: ov5640_check_chip_id: failed to read chip identifier
[   10.187879] ov5640: probe of 4-003c failed with error -121
[   10.191869] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
[   10.201572] ov5640 6-003c: supply DOVDD not found, using dummy regulator
[   10.208463] ov5640 6-003c: supply AVDD not found, using dummy regulator
[   10.215209] ov5640 6-003c: supply DVDD not found, using dummy regulator
[   10.239702] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
[   10.248098] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   10.259292] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   10.267794] img_dec 4300000.video-decoder: decoder registered as /dev/video1
[   10.275781] remoteproc remoteproc12: 4d80800000.dsp is available
[   10.306104] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[   10.319166] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
[   10.331891] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
[   10.340442] remoteproc remoteproc13: 4d81800000.dsp is available
[   10.348746] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
[   10.351777] ov5640 6-003c: ov5640_read_reg: error: reg=300a
[   10.363873] ov5640 6-003c: ov5640_check_chip_id: failed to read chip identifier
[   10.371570] remoteproc remoteproc12: powering up 4d80800000.dsp
[   10.377552] remoteproc remoteproc12: Booting fw image vision_apps_eaik/vx_app_rtos_linux_c6x_1.out, size 1461044
[   10.391820] ov5640: probe of 6-003c failed with error -121
[   10.402552] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
[   10.409516] remoteproc remoteproc14: 64800000.dsp is available
[   10.418264] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa8d9a000
[   10.430588] remoteproc remoteproc13: powering up 4d81800000.dsp
[   10.436568] remoteproc remoteproc13: Booting fw image vision_apps_eaik/vx_app_rtos_linux_c6x_2.out, size 1461012
[   10.454184] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa9d9a000
[   10.465597]  remoteproc12#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[   10.475293]  remoteproc12#vdev0buffer: registered virtio0 (type 7)
[   10.481515] remoteproc remoteproc12: remote processor 4d80800000.dsp is now up
[   10.490074]  remoteproc13#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[   10.499781]  remoteproc13#vdev0buffer: registered virtio1 (type 7)
[   10.506048] remoteproc remoteproc13: remote processor 4d81800000.dsp is now up
[   10.530069] Intel(R) Wireless WiFi driver for Linux
[   10.535315] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[   10.584103] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[   10.661372] iwlwifi 0000:01:00.0: WRT: Overriding region id 0
[   10.667183] iwlwifi 0000:01:00.0: WRT: Overriding region id 1
[   10.672947] iwlwifi 0000:01:00.0: WRT: Overriding region id 2
[   10.678701] iwlwifi 0000:01:00.0: WRT: Overriding region id 3
[   10.684447] iwlwifi 0000:01:00.0: WRT: Overriding region id 4
[   10.690219] iwlwifi 0000:01:00.0: WRT: Overriding region id 6
[   10.695977] iwlwifi 0000:01:00.0: WRT: Overriding region id 8
[   10.701748] iwlwifi 0000:01:00.0: WRT: Overriding region id 9
[   10.707526] iwlwifi 0000:01:00.0: WRT: Overriding region id 10
[   10.713382] iwlwifi 0000:01:00.0: WRT: Overriding region id 11
[   10.719245] iwlwifi 0000:01:00.0: WRT: Overriding region id 15
[   10.725101] iwlwifi 0000:01:00.0: WRT: Overriding region id 16
[   10.730952] iwlwifi 0000:01:00.0: WRT: Overriding region id 18
[   10.736798] iwlwifi 0000:01:00.0: WRT: Overriding region id 19
[   10.742652] iwlwifi 0000:01:00.0: WRT: Overriding region id 20
[   10.748500] iwlwifi 0000:01:00.0: WRT: Overriding region id 21
[   10.754354] iwlwifi 0000:01:00.0: WRT: Overriding region id 28
[   10.761974] iwlwifi 0000:01:00.0: loaded firmware version 46.6f9f215c.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
[   10.808999] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[  OK  ] Found device /dev/mmcblk1p1.
         Mounting /boot/firmware...
[   10.964393] platform 41000000.r5f: configured R5F for IPC-only mode
[   10.970984] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[   10.980623] remoteproc remoteproc15: 41000000.r5f is available
[   10.986540] remoteproc remoteproc15: attaching to 41000000.r5f
[   10.992572] platform 41000000.r5f: R5F core initialized in IPC-only mode
[   10.999310]  remoteproc15#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[   11.008945]  remoteproc15#vdev0buffer: registered virtio2 (type 7)
[   11.015141] remoteproc remoteproc15: remote processor 41000000.r5f is now attached
[   11.046483] platform 5c00000.r5f: configured R5F for remoteproc mode
[   11.075887] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[   11.086275] remoteproc remoteproc16: 5c00000.r5f is available
[   11.093091] remoteproc remoteproc14: powering up 64800000.dsp
[   11.098917] remoteproc remoteproc14: Booting fw image vision_apps_eaik/vx_app_rtos_linux_c7x_1.out, size 13242432
[   11.109264] remoteproc remoteproc14: unsupported resource 65538
[   11.118744] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xaa200000
[   11.126637] remoteproc remoteproc16: Direct firmware load for vision_apps_eaik/vx_app_rtos_linux_mcu2_0.dontload failed with error -2
[   11.138694] remoteproc remoteproc16: powering up 5c00000.r5f
[   11.144425] remoteproc remoteproc16: Direct firmware load for vision_apps_eaik/vx_app_rtos_linux_mcu2_0.dontload failed with error -2
[   11.156429] remoteproc remoteproc16: request_firmware failed: -2
[   11.163108] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   11.174523] iwlwifi 0000:01:00.0: Detected Intel(R) Wireless-AC 9260 160MHz, REV=0x324
[  OK  ] Mounted /boot/firmware.
[   11.184633] platform 5d00000.r5f: configured R5F for remoteproc mode
32m  OK  ] Reached target Local File Systems.
         Starting Load AppArmor profiles...
[   11.203396]  remoteproc14#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
         Starting Set console font and keymap...
[   11.216147]  remoteproc14#vdev0buffer: registered virtio3 (type 7)
         Starting Tell Plymouth To Write Out Runtime Da[   11.227751] remoteproc remoteproc14: remote processor 64800000.dsp is now up
ta...
         Starting Create Volatile Files and Directories...
[  OK  ] Finished Tell Plymouth To Write Out Runtime Data.
[  OK  ] Finished Set console font and keyma[   11.269739] iwlwifi 0000:01:00.0: base HW address: 84:fd:d1:81:f4:1b
p.
[  OK  ] Finished Create Volatile Files and Directories.
[   11.348373] thermal thermal_zone5: failed to read out thermal zone (-61)
         Starting Network Name Resolution...
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[   11.405851] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[   11.415942] remoteproc remoteproc17: 5d00000.r5f is available
[   11.422158] remoteproc remoteproc17: Direct firmware load for vision_apps_eaik/vx_app_rtos_linux_mcu2_1.dontload failed with error -2
[   11.434211] remoteproc remoteproc17: powering up 5d00000.r5f
[   11.439893] remoteproc remoteproc17: Direct firmware load for vision_apps_eaik/vx_app_rtos_linux_mcu2_1.dontload failed with error -2
[   11.451885] remoteproc remoteproc17: request_firmware failed: -2
[  OK  ] Finished Update UTMP about System Boot/Shutdown.
[   11.484394] audit: type=1400 audit(1659878713.572:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=571 comm="apparmor_parser"
[   11.499441] audit: type=1400 audit(1659878713.572:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=571 comm="apparmor_parser"
[   11.514318] audit: type=1400 audit(1659878713.572:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=571 comm="apparmor_parser"
[   11.539904] platform 5e00000.r5f: configured R5F for remoteproc mode
[   11.556233] audit: type=1400 audit(1659878713.644:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=572 comm="apparmor_parser"
[   11.571557] audit: type=1400 audit(1659878713.644:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=572 comm="apparmor_parser"
[   11.623128] audit: type=1400 audit(1659878713.708:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=576 comm="apparmor_parser"
[   11.672518] audit: type=1400 audit(1667987228.582:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/aarch64-linux-gnu/lightdm/lightdm-guest-session" pid=570 comm="apparmor_parser"
[   11.691424] audit: type=1400 audit(1667987228.582:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/aarch64-linux-gnu/lightdm/lightdm-guest-session//chromium" pid=570 comm="apparmor_parser"
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Finished Lo[   11.732216] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[  OK  ] Reached target  remoteproc remoteproc18: 5e00000.r5f is available
[0;1;39mSystem Initialization.
[  OK  ] Started[   11.756970] remoteproc remoteproc18: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
 Periodic ext4 Onli…ata Check for All Filesystems[   11.771435] remoteproc remoteproc18: powering up 5e00000.r5f
[  OK  ] Started Discard unused blocks o[   11.782685] remoteproc remoteproc18: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
nce a week.
[  OK  ] Started Daily rot[   11.797378] platform 5f00000.r5f: configured R5F for remoteproc mode
ation of log files.
[  OK  ] Started D[   11.797386] remoteproc remoteproc18: request_firmware failed: -2
aily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API.
         Starting Raise network interfaces...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting BeagleBoard.org USB gadgets...
[  OK  ] Started Regular background program processing daemon.
[  OK  ] Started D-Bus System Message Bus.
         Starting dphys-swapfile - …unt, and delete a swap file...
         Starting Remove Stale Onli…t4 Metadata Check Snapshots...
         Starting System Logging Service...
         Starting User Login Management...
         Starting LSB: Start daemon at boot time...
         Starting Disk Manager...
         Starting WPA supplicant...
[   11.949130] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[   11.959005] remoteproc remoteproc19: 5f00000.r5f is available
[   11.965435] remoteproc remoteproc19: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[   11.974637] remoteproc remoteproc19: powering up 5f00000.r5f
[   11.980386] remoteproc remoteproc19: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[   11.989567] remoteproc remoteproc19: request_firmware failed: -2
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
         Starting Load/Save RF Kill Switch Status...
[  OK  ] Finished Remove Stale Onli…ext4 Metadata Check Snapshots.
[   12.640681] using random self ethernet address
[   12.645184] using random host ethernet address
[   12.670709] using random self ethernet address
[   12.675296] using random host ethernet address
[  OK  ] Started System Logging Service.
[   12.758181] Mass Storage Function, version: 2009/09/11
[   12.763393] LUN: removable file: (no medium)
[  OK  ] Finished Raise network interfaces.
[   12.835815] Adding 2097148k swap on /var/swap.  Priority:-2 extents:10 across:11509756k SSFS
[   12.837446] Bluetooth: Core ver 2.22
[   12.847927] NET: Registered protocol family 31
[   12.852395] Bluetooth: HCI device and connection manager initialized
[   12.858773] Bluetooth: HCI socket layer initialized
[   12.863666] Bluetooth: L2CAP socket layer initialized
[   12.868783] Bluetooth: SCO socket layer initialized
[  OK  ] Finished dphys-swapfile - …mount, and delete a swap file.
[   12.913283] usbcore: registered new interface driver btusb
[   12.928671] Bluetooth: hci0: Bootloader revision 0.1 build 42 week 52 2015
[   12.936680] Bluetooth: hci0: Device revision is 2
[   12.941402] Bluetooth: hci0: Secure boot is enabled
[   12.946344] Bluetooth: hci0: OTP lock is enabled
[   12.946352] Bluetooth: hci0: API lock is enabled
[   12.946354] Bluetooth: hci0: Debug lock is disabled
[   12.946356] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[   12.986277] Bluetooth: hci0: Found device firmware: intel/ibt-18-16-1.sfi
[   13.012945] virtio_rpmsg_bus virtio0: rpmsg host is online
[   13.016690] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[   13.018835] virtio_rpmsg_bus virtio1: rpmsg host is online
[   13.028330] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[   13.031349] virtio_rpmsg_bus virtio2: rpmsg host is online
[   13.044015] virtio_rpmsg_bus virtio3: rpmsg host is online
[   13.049161] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[   13.062314] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[   13.062451] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[   13.081177] tidss 4a00000.dss: CRTC0 SYNC LOST: (irq 80)
[   13.125923] cdns-csi2rx 4504000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
[   13.134456] cdns-csi2rx 4514000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
[  OK  ] Started User Login Management.
[   13.394061] tidss 4a00000.dss: CRTC0 SYNC LOST: (irq 80)
[   13.399468] tidss 4a00000.dss: CRTC0 SYNC LOST: (irq 80)
[  OK  ] Started Load/Save RF Kill Switch Status.
[  OK  ] Found device /dev/ttyGS0.
[  OK  ] Started WPA supplicant.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[   13.472554] tidss 4a00000.dss: CRTC0 SYNC LOST: (irq 80)
[   13.473423] tidss 4a00000.dss: CRTC0 SYNC LOST: (irq 80)
[   13.473691] tidss 4a00000.dss: CRTC0 SYNC LOST: (irq 80)
[   13.474405] tidss 4a00000.dss: CRTC0 SYNC LOST: (irq 80)
[   13.474825] tidss 4a00000.dss: CRTC0 SYNC LOST: (irq 80)
[   13.475039] tidss 4a00000.dss: CRTC0 SYNC LOST: (irq 80)
[   13.480617] tidss 4a00000.dss: CRTC0 SYNC LOST: (irq 80)
[  OK  ] Created slice system-wpa_supplicant.slice.
         Starting Bluetooth service...
         Starting Authorization Manager...
[  OK  ] Started WPA supplicant dae… (interface-specific version).
[  OK  ] Reached target Network.
[  OK  ] Reached target Network is Online.
         Starting Beagle Flasher Shutdown...
         Starting containerd container runtime...
         Starting A high performanc… and a reverse proxy server...
         Starting OpenBSD Secure Shell server...
         Starting Permit User Sessions...
[  OK  ] Finished Beagle Flasher Shutdown.
[  OK  ] Finished Permit User Sessions.
         Starting Light Display Manager...
         Starting Hold until boot process finishes up...
[  OK  ] Started Authorization Manager.
[  OK  ] Started Bluetooth service.
[  OK  ] Reached target Bluetooth.
[   14.195709] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   14.201100] Bluetooth: BNEP filters: protocol multicast
[   14.206432] Bluetooth: BNEP socket layer initialized
[   14.600548] Bluetooth: hci0: Waiting for firmware download to complete
[   14.607250] Bluetooth: hci0: Firmware loaded in 1648442 usecs
[   14.613074] Bluetooth: hci0: Waiting for device to boot
[   14.626641] Bluetooth: hci0: Device booted in 13294 usecs
[   14.637435] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-18-16-1.ddc
[   14.646649] Bluetooth: hci0: Applying Intel DDC parameters completed
[   14.655608] Bluetooth: hci0: Firmware revision 0.1 build 168 week 48 2020
[   14.734226] NET: Registered protocol family 38
[   15.420279] aufs 5.10.140-20220912
[   17.366188] wlan0: authenticate with 94:00:b0:1e:f6:48
[   17.373943] wlan0: send auth to 94:00:b0:1e:f6:48 (try 1/3)
[   17.418936] wlan0: authenticated
[   17.423670] wlan0: associate with 94:00:b0:1e:f6:48 (try 1/3)
[   17.430694] wlan0: RX AssocResp from 94:00:b0:1e:f6:48 (capab=0x1531 status=0 aid=71)
[   17.442105] wlan0: associated
[   17.455496] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   17.821341] usb0: HOST MAC 34:08:e1:59:03:bd
[   17.825693] usb0: MAC 34:08:e1:59:03:be
[   17.830000] usb1: HOST MAC 34:08:e1:59:03:bf
[   17.834298] usb1: MAC 34:08:e1:59:03:c0
[   18.467509] audit: type=1400 audit(1667987235.374:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=987 comm="apparmor_parser"
[   19.076110] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   19.092873] Bridge firewalling registered
[   19.389771] Initializing XFRM netlink socket
Debian GNU/Linux 11 BeagleBone ttyS2
BeagleBoard.org Debian Bullseye Xfce Image 2022-06-14
Support: https://bbb.io/debian
default username:password is [debian:temppwd]
Are there any suggestions? thank you
That’s disappointing… Something is fishy with your eMMC…
As long as it fails with the latest snapshot:
I’d just RMA it…
I use the latest image you suggested above but the problem is not solved.
Here are the logs of the latest image:
U-Boot SPL 2021.01-g8bafcf50 (Oct 27 2022 - 14:43:30 +0000)
Model: BeagleBoard.org BeagleBone AI-64 R5
EEPROM not available at 0x50, trying to read at 0x51
Board: BBONEAI-64-B0- rev B0
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.5(release):0588523
NOTICE:  BL31: Built : 14:43:30, Oct 27 2022
Model: Texas Instruments K3 J721E SoC
ti_i2c_eeprom_am6_parse_record: Ignoring record id 17
U-Boot 2021.01-g8bafcf50 (Oct 27 2022 - 14:43:30 +0000)
SoC:   J721E SR1.1 GP
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Net:   eth0: ethernet@46000000port@1
Press SPACE to abort autoboot in 2 seconds
board_name=[BBONEAI-64-B0-] ...
name_fdt=[k3-j721e-beagleboneai64.dtb] ...
i2c_write: error waiting for data ACK (status=0x116)
pca953x gpio@22: Error reading output register
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
212 bytes read in 10 ms (20.5 KiB/s)
1:      Linux microSD
Retrieving file: /initrd.img
15375966 bytes read in 674 ms (21.8 MiB/s)
Retrieving file: /Image
28815872 bytes read in 1251 ms (22 MiB/s)
append: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0 quiet
Retrieving file: /k3-j721e-beagleboneai64.dtb
203825 bytes read in 19 ms (10.2 MiB/s)
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8f156000, end 8ffffe5e ... OK
   Loading Device Tree to 000000008f121000, end 000000008f155c30 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.120-ti-arm64-r67 (voodoo@rpi4b8g-19) (gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1bullseye SMP Sun Oct 30 23:43:09 UTC 2022
[    0.000000] Machine model: BeagleBoard.org BeagleBone AI-64
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.705817] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.712098] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.890206] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.896549] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    1.198274] davinci_mdio c000f00.mdio: timed out waiting for user access
[    1.305084] davinci_mdio c000f00.mdio: timed out waiting for idle
[    1.521893] mmc0: mmc_select_hs200 failed, error -110
[    1.526944] mmc0: error -110 whilst initialising MMC card
[    1.564186] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    1.642175] mmc0: mmc_select_hs200 failed, error -110
[    1.647230] mmc0: error -110 whilst initialising MMC card
[    1.758428] davinci_mdio c000f00.mdio: timed out waiting for user access
[    1.776124] mmc0: mmc_select_hs200 failed, error -110
[    1.781165] mmc0: error -110 whilst initialising MMC card
[    1.865261] davinci_mdio c000f00.mdio: timed out waiting for idle
[    1.872987] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@1 error retrieving port phy: -19
[    1.946503] mmc0: mmc_select_hs200 failed, error -110
[    1.951564] mmc0: error -110 whilst initialising MMC card
[    2.598753] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[    2.606015] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[    2.614524] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    2.621845] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    2.629159] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    2.636477] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    3.705135] mmc1: error -110 whilst initialising SD card
[    3.948604] mmc1: error -110 whilst initialising SD card
[    4.194145] mmc1: error -110 whilst initialising SD card
[    4.452830] mmc1: error -110 whilst initialising SD card
Gave up waiting for root file system device.  Common problems:
 - Boot args (cat /proc/cmdline)
   - Check rootdelay= (did the system wait long enough?)
 - Missing modules (cat /proc/modules; ls /dev)
ALERT!  /dev/mmcblk1p2 does not exist.  Dropping to a shell!
BusyBox v1.30.1 (Debian 1:1.30.1-6+b3) built-in shell (ash)
Enter 'help' for a list of built-in commands.
I’m so stuck I don’t know how to solve this problem.
I’d rma it… the onboard emmc is defective…
I think this is an important product quality issue, I just bought BBAI-64 a few days ago and it only damaged the eMMC component, everything else is normal, it very strange.
I don’t know if BB has a warranty policy, isn’t it?
