i have installed ubuntu 13.04 on to my bbb a6 following the instructions from this site http://ozancaglayan.com/2013/11/14/ubuntu-13-10-for-beaglebone-black-part-1/
i got the final image dumped into my sd card.I am not able to flash it into my emmc even after i press the boot button n wait so long.If i remove the sdcard i am booting with angstrom.When i was trying to access ubuntu through sd card to upgrade and then install avahi-daemon i get the following in the terminal. pls help out!!
ubuntu@arm:~$ sudo su
[sudo] password for ubuntu:
root@arm:/home/ubuntu# sudo apt-get update && sudo apt-get install bash-completion
Err http://ports.ubuntu.com saucy InRelease
Err http://ports.ubuntu.com saucy-updates InRelease
Err http://ports.ubuntu.com saucy Release.gpg
Could not resolve ‘ports.ubuntu.com’
Err http://ports.ubuntu.com saucy-updates Release.gpg
Reading package lists… Done
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/saucy/InRelease
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/saucy-updates/InRelease
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/saucy/Release.gpg Could not resolve ‘ports.ubuntu.com’
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/saucy-updates/Release.gpg Could not resolve ‘ports.ubuntu.com’
W: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree
The following NEW packages will be installed:
bash-completion
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 173 kB of archives.
After this operation, 892 kB of additional disk space will be used.
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main bash-completion all 1:2.0-1ubuntu3
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/b/bash-completion/bash-completion_2.0-1ubuntu3_all.deb Could not resolve ‘ports.ubuntu.com’
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
root@arm:/home/ubuntu# sudo apt-get install avahi-daemon
The following extra packages will be installed:
bind9-host dbus geoip-database libapparmor1 libavahi-common-data libavahi-common3 libavahi-core7 libbind9-90 libdaemon0 libdns99 libgeoip1
libglib2.0-0 libglib2.0-data libisc95 libisccc90 libisccfg90 liblwres90 libnss-mdns libpam-systemd libsystemd-daemon0 libsystemd-login0
shared-mime-info systemd-services systemd-shim
Suggested packages:
avahi-autoipd dbus-x11 geoip-bin pm-utils
avahi-daemon bind9-host dbus geoip-database libapparmor1 libavahi-common-data libavahi-common3 libavahi-core7 libbind9-90 libdaemon0 libdns99
libgeoip1 libglib2.0-0 libglib2.0-data libisc95 libisccc90 libisccfg90 liblwres90 libnss-mdns libpam-systemd libsystemd-daemon0 libsystemd-login0
0 upgraded, 25 newly installed, 0 to remove and 0 not upgraded.
Need to get 4,591 kB of archives.
After this operation, 16.1 MB of additional disk space will be used.
Do you want to continue [Y/n]? Y
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main geoip-database all 20130813-1
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main libgeoip1 armhf 1.5.1-1ubuntu1
Err http://ports.ubuntu.com/ubuntu-ports/ saucy-updates/main libglib2.0-0 armhf 2.38.1-0ubuntu1
Err http://ports.ubuntu.com/ubuntu-ports/ saucy-updates/main libsystemd-daemon0 armhf 204-0ubuntu19
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main libapparmor1 armhf 2.8.0-0ubuntu31
Err http://ports.ubuntu.com/ubuntu-ports/ saucy-updates/main libsystemd-login0 armhf 204-0ubuntu19
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main dbus armhf 1.6.12-0ubuntu10
Err http://ports.ubuntu.com/ubuntu-ports/ saucy-updates/main systemd-services armhf 204-0ubuntu19
Err http://ports.ubuntu.com/ubuntu-ports/ saucy-updates/main libpam-systemd armhf 204-0ubuntu19
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main libavahi-common-data armhf 0.6.31-2ubuntu4
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main libavahi-common3 armhf 0.6.31-2ubuntu4
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main libavahi-core7 armhf 0.6.31-2ubuntu4
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main libisc95 armhf 1:9.9.3.dfsg.P2-4ubuntu1
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main libdns99 armhf 1:9.9.3.dfsg.P2-4ubuntu1
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main libisccc90 armhf 1:9.9.3.dfsg.P2-4ubuntu1
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main libisccfg90 armhf 1:9.9.3.dfsg.P2-4ubuntu1
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main libbind9-90 armhf 1:9.9.3.dfsg.P2-4ubuntu1
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main liblwres90 armhf 1:9.9.3.dfsg.P2-4ubuntu1
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main bind9-host armhf 1:9.9.3.dfsg.P2-4ubuntu1
Err http://ports.ubuntu.com/ubuntu-ports/ saucy-updates/main libglib2.0-data all 2.38.1-0ubuntu1
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main shared-mime-info armhf 1.1-0ubuntu5
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main systemd-shim armhf 3+real-0ubuntu1
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main libdaemon0 armhf 0.14-2build1
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main avahi-daemon armhf 0.6.31-2ubuntu4
Err http://ports.ubuntu.com/ubuntu-ports/ saucy/main libnss-mdns armhf 0.10-3.2ubuntu1
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/g/geoip-database/geoip-database_20130813-1_all.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/g/geoip/libgeoip1_1.5.1-1ubuntu1_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/g/glib2.0/libglib2.0-0_2.38.1-0ubuntu1_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/systemd/libsystemd-daemon0_204-0ubuntu19_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/a/apparmor/libapparmor1_2.8.0-0ubuntu31_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/systemd/libsystemd-login0_204-0ubuntu19_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/d/dbus/dbus_1.6.12-0ubuntu10_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/systemd/systemd-services_204-0ubuntu19_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/systemd/libpam-systemd_204-0ubuntu19_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/a/avahi/libavahi-common-data_0.6.31-2ubuntu4_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/a/avahi/libavahi-common3_0.6.31-2ubuntu4_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/a/avahi/libavahi-core7_0.6.31-2ubuntu4_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/b/bind9/libisc95_9.9.3.dfsg.P2-4ubuntu1_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/b/bind9/libdns99_9.9.3.dfsg.P2-4ubuntu1_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/b/bind9/libisccc90_9.9.3.dfsg.P2-4ubuntu1_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/b/bind9/libisccfg90_9.9.3.dfsg.P2-4ubuntu1_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/b/bind9/libbind9-90_9.9.3.dfsg.P2-4ubuntu1_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/b/bind9/liblwres90_9.9.3.dfsg.P2-4ubuntu1_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/b/bind9/bind9-host_9.9.3.dfsg.P2-4ubuntu1_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/g/glib2.0/libglib2.0-data_2.38.1-0ubuntu1_all.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/shared-mime-info/shared-mime-info_1.1-0ubuntu5_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/systemd-shim/systemd-shim_3+real-0ubuntu1_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/libd/libdaemon/libdaemon0_0.14-2build1_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/a/avahi/avahi-daemon_0.6.31-2ubuntu4_armhf.deb Could not resolve ‘ports.ubuntu.com’
Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/n/nss-mdns/libnss-mdns_0.10-3.2ubuntu1_armhf.deb Could not resolve ‘ports.ubuntu.com’
