Hi everyone,
I try to set-up a BBB with the image from here:
https://rcn-ee.net/rootfs/release/2023-12-11/bookworm-iot-armhf/am57xx-eMMC-flasher-debian-12.4-iot-armhf-2023-12-11-4gb.img.xz
After flashing the image to an SD card using balena etcher, I inserted the card into the BBB and got the following result:
U-Boot SPL 2019.04-dirty (Jul 24 2019 - 10:43:45 +0200)
Trying to boot from MMC2
Loading Environment from EXT4... ** File not found /boot/uboot.env **
** Unable to read "/boot/uboot.env" from mmc0:1 **
U-Boot 2019.04-dirty (Jul 24 2019 - 10:43:45 +0200)
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
RTC 32KCLK Source: External.
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
board_name=[A335BNLT] ...
board_rev=[000C] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
1712 bytes read in 27 ms (61.5 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-5.10.168-ti-r73 ...
11338240 bytes read in 734 ms (14.7 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=1] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb ...
loading /boot/dtbs/5.10.168-ti-r73/am335x-boneblack-uboot-univ.dtb ...
210757 bytes read in 138 ms (1.5 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: unable to find [mmc 0:1 /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo]...
uboot_overlays: unable to find [mmc 0:1 /lib/firmware/BB-HDMI-TDA998x-00A0.dtbo]...
uboot_overlays: unable to find [mmc 0:1 /lib/firmware/BB-ADC-00A0.dtbo]...
loading /boot/initrd.img-5.10.168-ti-r73 ...
7845445 bytes read in 513 ms (14.6 MiB/s)
debug: [console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ex t4 rootwait init=/usr/sbin/init-beagle-flasher] ...
debug: [bootz 0x82000000 0x88080000:77b645 0x88000000] ...
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8f884000, end 8ffff645 ... OK
Loading Device Tree to 8f84d000, end 8f883744 ... OK
Starting kernel ...
[ 0.000000] Linux version 5.10.168-ti-r73 (voodoo@rpi4b4g-03) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1bookworm SMP PREEMPT Wed Nov 29 00:38:15 UTC 2023
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x9c800000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x000000009fdfffff]
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fdfffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fdfffff]
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] percpu: Embedded 21 pages/cpu s54604 r8192 d23220 u86016
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129412
[ 0.000000] Kernel command line: console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/de v/mmcblk0p1 ro rootfstype=ext4 rootwait init=/usr/sbin/init-beagle-flasher
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.000000] Memory: 437200K/522240K available (14336K kernel code, 1449K rwdata, 4040K rodata, 1024K init, 445K bss, 35888K reserved, 49152K cma-reserved, 0K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[ 0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module @31000
[ 0.000011] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000032] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 n s
[ 0.000409] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@ 40000
[ 0.002543] Console: colour dummy device 80x30
[ 0.002637] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[ 0.048467] pid_max: default: 32768 minimum: 301
[ 0.049105] LSM: Security Framework initializing
[ 0.049228] Yama: becoming mindful.
[ 0.049529] AppArmor: AppArmor initialized
[ 0.049551] TOMOYO Linux initialized
[ 0.049747] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.049765] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.051453] CPU: Testing write buffer coherency: ok
[ 0.051541] CPU0: Spectre v2: using BPIALL workaround
[ 0.072898] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.080484] rcu: Hierarchical SRCU implementation.
[ 0.089728] EFI services will not be available.
[ 0.100497] smp: Bringing up secondary CPUs ...
[ 0.100519] smp: Brought up 1 node, 1 CPU
[ 0.100531] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[ 0.100543] CPU: All CPU(s) started in SVC mode.
[ 0.101454] devtmpfs: initialized
[ 0.144820] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.145321] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100 000 ns
[ 0.145365] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.149152] pinctrl core: initialized pinctrl subsystem
[ 0.150367] DMI not present or invalid.
[ 0.151255] NET: Registered protocol family 16
[ 0.154438] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.194192] l3-aon-clkctrl:0000:0: failed to disable
[ 0.194970] audit: initializing netlink subsys (disabled)
[ 0.196396] thermal_sys: Registered thermal governor 'fair_share'
[ 0.196411] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.196428] thermal_sys: Registered thermal governor 'step_wise'
[ 0.196439] thermal_sys: Registered thermal governor 'user_space'
[ 0.196526] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.197438] cpuidle: using governor ladder
[ 0.197509] cpuidle: using governor menu
[ 0.204557] audit: type=2000 audit(0.184:1): state=initialized audit_enabled=0 res=1
[ 6.634106] hw-breakpoint: debug architecture 0x4 unsupported.
[ 6.684080] Kprobes globally optimized
[ 6.708944] raid6: skip pq benchmark and using algorithm neonx8
[ 6.708978] raid6: using neon recovery algorithm
[ 6.716619] iommu: Default domain type: Translated
[ 6.721345] SCSI subsystem initialized
[ 6.725049] usbcore: registered new interface driver usbfs
[ 6.725118] usbcore: registered new interface driver hub
[ 6.725178] usbcore: registered new device driver usb
[ 6.726624] mc: Linux media interface: v0.10
[ 6.726685] videodev: Linux video capture interface: v2.00
[ 6.726863] pps_core: LinuxPPS API ver. 1 registered
[ 6.726878] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 6.726906] PTP clock support registered
[ 6.729579] NetLabel: Initializing
[ 6.729604] NetLabel: domain hash size = 128
[ 6.729613] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 6.729712] NetLabel: unlabeled traffic allowed by default
[ 6.730931] clocksource: Switched to clocksource dmtimer
[ 7.762765] VFS: Disk quotas dquot_6.6.0
[ 7.763002] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 7.763323] FS-Cache: Loaded
[ 7.763769] CacheFiles: Loaded
[ 7.764809] AppArmor: AppArmor Filesystem Enabled
[ 7.778276] NET: Registered protocol family 2
[ 7.778578] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 7.780259] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 7.780566] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 7.780638] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 7.780701] TCP: Hash tables configured (established 4096 bind 4096)
[ 7.781316] MPTCP token hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 7.781422] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 7.781457] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 7.781726] NET: Registered protocol family 1
[ 7.795262] RPC: Registered named UNIX socket transport module.
[ 7.795289] RPC: Registered udp transport module.
[ 7.795300] RPC: Registered tcp transport module.
[ 7.795309] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 7.795328] NET: Registered protocol family 44
[ 7.796339] Trying to unpack rootfs image as initramfs...
[ 8.752306] Freeing initrd memory: 7664K
[ 8.753376] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 8.759600] Initialise system trusted keyrings
[ 8.760068] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 8.768483] zbud: loaded
[ 8.776680] NFS: Registering the id_resolver key type
[ 8.776756] Key type id_resolver registered
[ 8.776768] Key type id_legacy registered
[ 8.776942] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 8.776959] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 8.777009] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 8.778164] fuse: init (API version 7.32)
[ 8.867625] NET: Registered protocol family 38
[ 8.867670] xor: measuring software checksum speed
[ 8.875525] arm4regs : 1271 MB/sec
[ 8.885506] 8regs : 999 MB/sec
[ 8.895808] 32regs : 963 MB/sec
[ 8.901323] neon : 1807 MB/sec
[ 8.901334] xor: using function: neon (1807 MB/sec)
[ 8.901361] Key type asymmetric registered
[ 8.901373] Asymmetric key parser 'x509' registered
[ 8.901468] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 8.905827] io scheduler mq-deadline registered
[ 9.625912] ti-sysc: probe of 44e31000.target-module failed with error -16
[ 9.753070] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 9.779675] ti-sysc: probe of 48040000.target-module failed with error -16
[ 9.982183] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 10.098101] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 10.559462] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[ 10.559513] edma 49000000.dma: TI EDMA DMA engine driver
[ 10.590565] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 10.592334] gpio-of-helper ocp:cape-universal: Failed to get gpio property of 'P8_03'
[ 10.592362] gpio-of-helper ocp:cape-universal: Failed to create gpio entry
[ 10.615459] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 10.620344] printk: console [ttyS0] disabled
[ 10.620467] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 20, base_baud = 3000000) is a 8250
[ 11.495136] printk: console [ttyS0] enabled
[ 11.501353] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 26, base_baud = 3000000) is a 8250
[ 11.512077] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 27, base_baud = 3000000) is a 8250
[ 11.522736] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 40, base_baud = 3000000) is a 8250
[ 11.533130] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 41, base_baud = 3000000) is a 8250
[ 11.543519] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 42, base_baud = 3000000) is a 8250
[ 11.557216] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 11.563873] random: crng init done
[ 11.683097] loop: module loaded
[ 11.686606] at24 2-0054: supply vcc not found, using dummy regulator
[ 11.722357] at24 2-0055: supply vcc not found, using dummy regulator
[ 11.758184] at24 2-0056: supply vcc not found, using dummy regulator
[ 11.794207] at24 2-0057: supply vcc not found, using dummy regulator
[ 11.981538] mdio_bus 4a101000.mdio: mii_bus 4a101000.mdio couldn't get reset GPIO
[ 11.990291] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[ 11.996885] cpsw 4a100000.ethernet: ALE Table size 1024
[ 12.002331] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[ 12.009752] cpsw 4a100000.ethernet: Detected MACID = ac:1f:0f:bd:93:0b
[ 12.020120] usbcore: registered new interface driver smsc95xx
[ 12.028907] am335x-phy-driver 47401300.usb-phy: supply vcc not found, using dummy regulator
[ 12.037742] am335x-phy-driver 47401300.usb-phy: dummy supplies not allowed for exclusive requests
[ 12.052666] am335x-phy-driver 47401b00.usb-phy: supply vcc not found, using dummy regulator
[ 12.061546] am335x-phy-driver 47401b00.usb-phy: dummy supplies not allowed for exclusive requests
[ 12.077591] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 12.084465] ehci-platform: EHCI generic platform driver
[ 12.090579] ehci-omap: OMAP-EHCI Host Controller driver
[ 12.109583] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 12.115253] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 12.123089] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 12.131428] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.138702] usb usb1: Product: MUSB HDRC host driver
[ 12.143708] usb usb1: Manufacturer: Linux 5.10.168-ti-r73 musb-hcd
[ 12.149935] usb usb1: SerialNumber: musb-hdrc.1
[ 12.155465] hub 1-0:1.0: USB hub found
[ 12.159381] hub 1-0:1.0: 1 port detected
[ 12.178553] omap_rtc 44e3e000.rtc: registered as rtc0
[ 12.184111] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
[ 12.194827] i2c /dev entries driver
[ 12.200206] Driver for 1-wire Dallas network protocol.
[ 12.210254] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 12.218109] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[ 12.226640] softdog: soft_reboot_cmd=<not set> soft_active_on_boot=0
[ 12.236699] cpuidle: enable-method property 'ti,am3352' found operations
[ 12.245880] sdhci: Secure Digital Host Controller Interface driver
[ 12.252204] sdhci: Copyright(c) Pierre Ossman
[ 12.256604] sdhci-pltfm: SDHCI platform and OF driver helper
[ 12.270322] ledtrig-cpu: registered to indicate activity on CPUs
[ 12.277628] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 12.283880] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 12.295321] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 12.301585] omap-sham 53100000.sham: will run requests pump with realtime priority
[ 12.314046] hid: raw HID events driver (C) Jiri Kosina
[ 12.320533] usbcore: registered new interface driver usbhid
[ 12.326461] usbhid: USB HID core driver
[ 12.331112] remoteproc remoteproc0: wkup_m3 is available
[ 12.343508] NET: Registered protocol family 10
[ 12.435027] Segment Routing with IPv6
[ 12.438876] mip6: Mobile IPv6
[ 12.442100] NET: Registered protocol family 17
[ 12.451226] Key type dns_resolver registered
[ 12.455655] mpls_gso: MPLS GSO support
[ 12.459739] ThumbEE CPU extension supported.
[ 12.464092] Registering SWP/SWPB emulation handler
[ 12.468931] omap_voltage_late_init: Voltage driver support not added
[ 12.476395] registered taskstats version 1
[ 12.480606] Loading compiled-in X.509 certificates
[ 12.485598] zswap: loaded using pool lzo/zbud
[ 12.494970] Key type .fscrypt registered
[ 12.499013] Key type fscrypt-provisioning registered
[ 12.511260] Btrfs loaded, crc32c=crc32c-generic
[ 12.516022] AppArmor: AppArmor sha1 policy hashing enabled
[ 12.542454] OMAP GPIO hardware version 0.1
[ 12.575706] tps65217-pmic: Failed to locate of_node [id: -1]
[ 12.592494] tps65217-bl: Failed to locate of_node [id: -1]
[ 12.601168] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[ 12.608586] input: tps65217_pwr_but as /devices/platform/ocp/44c00000.interconnect/44c00000.interconn ect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 12.627172] tps65217 0-0024: TPS65217 ID 0x6 version 1.2
[ 12.634269] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 12.641496] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 12.655072] gpio-of-helper ocp:cape-universal: Allocated GPIO id=0 name='P8_03'
[ 12.662703] gpio-of-helper ocp:cape-universal: Allocated GPIO id=1 name='P8_04'
[ 12.670256] gpio-of-helper ocp:cape-universal: Allocated GPIO id=2 name='P8_05'
[ 12.677809] gpio-of-helper ocp:cape-universal: Allocated GPIO id=3 name='P8_06'
[ 12.685620] gpio-of-helper ocp:cape-universal: Allocated GPIO id=4 name='P8_07'
[ 12.693241] gpio-of-helper ocp:cape-universal: Allocated GPIO id=5 name='P8_08'
[ 12.700795] gpio-of-helper ocp:cape-universal: Allocated GPIO id=6 name='P8_09'
[ 12.708354] gpio-of-helper ocp:cape-universal: Allocated GPIO id=7 name='P8_10'
[ 12.715923] gpio-of-helper ocp:cape-universal: Allocated GPIO id=8 name='P8_11'
[ 12.723453] gpio-of-helper ocp:cape-universal: Allocated GPIO id=9 name='P8_12'
[ 12.731102] gpio-of-helper ocp:cape-universal: Allocated GPIO id=10 name='P8_13'
[ 12.738738] gpio-of-helper ocp:cape-universal: Allocated GPIO id=11 name='P8_14'
[ 12.746371] gpio-of-helper ocp:cape-universal: Allocated GPIO id=12 name='P8_15'
[ 12.754011] gpio-of-helper ocp:cape-universal: Allocated GPIO id=13 name='P8_16'
[ 12.761652] gpio-of-helper ocp:cape-universal: Allocated GPIO id=14 name='P8_17'
[ 12.769268] gpio-of-helper ocp:cape-universal: Allocated GPIO id=15 name='P8_18'
[ 12.776896] gpio-of-helper ocp:cape-universal: Allocated GPIO id=16 name='P8_19'
[ 12.784513] gpio-of-helper ocp:cape-universal: Allocated GPIO id=17 name='P8_20'
[ 12.792138] gpio-of-helper ocp:cape-universal: Allocated GPIO id=18 name='P8_21'
[ 12.799785] gpio-of-helper ocp:cape-universal: Allocated GPIO id=19 name='P8_22'
[ 12.807402] gpio-of-helper ocp:cape-universal: Allocated GPIO id=20 name='P8_23'
[ 12.815075] gpio-of-helper ocp:cape-universal: Allocated GPIO id=21 name='P8_24'
[ 12.822709] gpio-of-helper ocp:cape-universal: Allocated GPIO id=22 name='P8_25'
[ 12.830358] gpio-of-helper ocp:cape-universal: Allocated GPIO id=23 name='P8_26'
[ 12.837987] gpio-of-helper ocp:cape-universal: Allocated GPIO id=24 name='P8_27'
[ 12.845736] gpio-of-helper ocp:cape-universal: Allocated GPIO id=25 name='P8_28'
[ 12.853388] gpio-of-helper ocp:cape-universal: Allocated GPIO id=26 name='P8_29'
[ 12.861006] gpio-of-helper ocp:cape-universal: Allocated GPIO id=27 name='P8_30'
[ 12.868640] gpio-of-helper ocp:cape-universal: Allocated GPIO id=28 name='P8_31'
[ 12.876269] gpio-of-helper ocp:cape-universal: Allocated GPIO id=29 name='P8_32'
[ 12.883886] gpio-of-helper ocp:cape-universal: Allocated GPIO id=30 name='P8_33'
[ 12.891514] gpio-of-helper ocp:cape-universal: Allocated GPIO id=31 name='P8_34'
[ 12.899145] gpio-of-helper ocp:cape-universal: Allocated GPIO id=32 name='P8_35'
[ 12.906780] gpio-of-helper ocp:cape-universal: Allocated GPIO id=33 name='P8_36'
[ 12.914410] gpio-of-helper ocp:cape-universal: Allocated GPIO id=34 name='P8_37'
[ 12.922034] gpio-of-helper ocp:cape-universal: Allocated GPIO id=35 name='P8_38'
[ 12.929672] gpio-of-helper ocp:cape-universal: Allocated GPIO id=36 name='P8_39'
[ 12.937321] gpio-of-helper ocp:cape-universal: Allocated GPIO id=37 name='P8_40'
[ 12.944937] gpio-of-helper ocp:cape-universal: Allocated GPIO id=38 name='P8_41'
[ 12.952562] gpio-of-helper ocp:cape-universal: Allocated GPIO id=39 name='P8_42'
[ 12.960172] gpio-of-helper ocp:cape-universal: Allocated GPIO id=40 name='P8_43'
[ 12.967815] gpio-of-helper ocp:cape-universal: Allocated GPIO id=41 name='P8_44'
[ 12.975439] gpio-of-helper ocp:cape-universal: Allocated GPIO id=42 name='P8_45'
[ 12.983062] gpio-of-helper ocp:cape-universal: Allocated GPIO id=43 name='P8_46'
[ 12.990702] gpio-of-helper ocp:cape-universal: Allocated GPIO id=44 name='P9_11'
[ 12.998342] gpio-of-helper ocp:cape-universal: Allocated GPIO id=45 name='P9_12'
[ 13.005975] gpio-of-helper ocp:cape-universal: Allocated GPIO id=46 name='P9_13'
[ 13.013604] gpio-of-helper ocp:cape-universal: Allocated GPIO id=47 name='P9_14'
[ 13.021223] gpio-of-helper ocp:cape-universal: Allocated GPIO id=48 name='P9_15'
[ 13.028851] gpio-of-helper ocp:cape-universal: Allocated GPIO id=49 name='P9_16'
[ 13.036482] gpio-of-helper ocp:cape-universal: Allocated GPIO id=50 name='P9_17'
[ 13.044148] gpio-of-helper ocp:cape-universal: Allocated GPIO id=51 name='P9_18'
[ 13.051779] gpio-of-helper ocp:cape-universal: Allocated GPIO id=52 name='P9_19'
[ 13.059402] gpio-of-helper ocp:cape-universal: Allocated GPIO id=53 name='P9_20'
[ 13.067056] gpio-of-helper ocp:cape-universal: Allocated GPIO id=54 name='P9_21'
[ 13.074679] gpio-of-helper ocp:cape-universal: Allocated GPIO id=55 name='P9_22'
[ 13.082315] gpio-of-helper ocp:cape-universal: Allocated GPIO id=56 name='P9_23'
[ 13.089950] gpio-of-helper ocp:cape-universal: Allocated GPIO id=57 name='P9_24'
[ 13.097868] gpio-of-helper ocp:cape-universal: Allocated GPIO id=58 name='P9_25'
[ 13.105566] gpio-of-helper ocp:cape-universal: Allocated GPIO id=59 name='P9_26'
[ 13.113225] gpio-of-helper ocp:cape-universal: Allocated GPIO id=60 name='P9_27'
[ 13.120853] gpio-of-helper ocp:cape-universal: Allocated GPIO id=61 name='P9_28'
[ 13.128482] gpio-of-helper ocp:cape-universal: Allocated GPIO id=62 name='P9_29'
[ 13.136101] gpio-of-helper ocp:cape-universal: Allocated GPIO id=63 name='P9_30'
[ 13.143783] gpio-of-helper ocp:cape-universal: Allocated GPIO id=64 name='P9_31'
[ 13.151425] gpio-of-helper ocp:cape-universal: Allocated GPIO id=65 name='P9_41'
[ 13.159064] gpio-of-helper ocp:cape-universal: Allocated GPIO id=66 name='P9_91'
[ 13.166703] gpio-of-helper ocp:cape-universal: Allocated GPIO id=67 name='P9_42'
[ 13.174317] gpio-of-helper ocp:cape-universal: Allocated GPIO id=68 name='P9_92'
[ 13.181775] gpio-of-helper ocp:cape-universal: ready
[ 13.226994] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 13.255459] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 13.272401] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[ 13.285505] of_cfs_init
[ 13.288464] of_cfs_init: OK
[ 13.293617] sdhci-omap 48060000.mmc: Got CD GPIO
[ 13.298697] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[ 13.338788] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[ 13.349548] Freeing unused kernel memory: 1024K
[ 13.355062] Run /init as init process
Loading, please wait...
[ 13.390437] mmc0: new high speed SDHC card at address 59b4
[ 13.407386] mmcblk0: mmc0:59b4 SDC 7.51 GiB
[ 13.417078] mmcblk0: p1
Starting systemd-udevd version 252.19-1~deb12u1
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
Warning: fsck not present, so skipping root file system
[ 21.508940] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... trap: EXIT: bad trap
done.
Version: [1.20231211.0, e2fsprogs (1.47.0) disable ^metadata_csum,64bit,orphan_file...]
cat /etc/default/beagle-flasher:
#debug_over_display=tty0
source=/dev/mmcblk0
destination=/dev/mmcblk1
rfs_partition=single
rfs_rootfs_type=ext4
rfs_rootfs_startmb=4
bootloader=/opt/u-boot/bb-u-boot-am335x-evm/install-mmcblk1.sh
flash_back=beaglebone-black-emmc-to-microsd
INFO: Giving system time to stablize...
5
4
3
2
1
INFO: Preparing /tmp
INFO: [mount -t tmpfs tmpfs /tmp]
INFO: /proc/cmdline
INFO: [cat /proc/cmdline]
console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootw ait init=/usr/sbin/init-beagle-flasher
INFO: Preparing sysctl
INFO: [sysctl: vm.min_free_kbytes=[2789]
INFO: [sysctl: setting: [sysctl -w vm.min_free_kbytes=16384]
vm.min_free_kbytes = 16384
INFO: [lsblk -i]
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
mmcblk0 179:0 0 7.5G 0 disk
`-mmcblk0p1 179:1 0 [ 27.288494] Kernel panic - not syncing: Attempted to kill init! exitcode=0x000 00200
[ 27.299181] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000200 ]---
3.5G 0 part /
INFO: copying [/dev/mmcblk0] -> [/dev/mmcblk1]
INFO: [source=/dev/mmcblk0] is a valid block device
ERROR: [destination=/dev/mmcblk1] does not exist
Example: /etc/default/beagle-flasher
source=/dev/mmcblk0
Do I understand correctly, that the BBB booted from SD but did not recognize the EMMC storage?
As far as I can see, the bootloader looked for three files, one for the eMMC storage in the wrong place:
uboot_overlays: unable to find [mmc 0:1 /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo]…
uboot_overlays: unable to find [mmc 0:1 /lib/firmware/BB-HDMI-TDA998x-00A0.dtbo]…
uboot_overlays: unable to find [mmc 0:1 /lib/firmware/BB-ADC-00A0.dtbo]…
Looking at the SD card, I can find these files in the folder /boot/dtbs/5.10.168-ti-r73/overlays.
1. Can I simply create a symbolic link from /lib/firmware to the files under /boot/dtbs/5.10.168-ti-r73/overlays (or copy them)?
2. Will this solve the actual problem:
Thanks a lot!
