Emulate running Linux on BeagleV Starlight with Renode
FYI - @mgielda writes how to use Renode to emulate Linux running on the BeagleV Starlight system in Renode:
https://antmicro.com/blog/2021/05/linux-on-beaglev-starlight-in-renode/
Followed the instructions but had to start renode and do the include @/…/file.resc then start the emu. Just an fyi. It starts up though so this is still a win.
One small hickup I am looking to solve today is I cant login. Since this is a buildroot, root ( no password ) should work but its failing the login, I have had this before after doing a build for a pandaboard, unless a password has been set ( did not see anything about that in the text ).
From Piotr:
https://twitter.com/pzierhoffer/status/1393718389835698177?s=19
that’s the default for the sdk - root/starfive - not very convenient indeed. I’ll update it to root/root as soon as I get my hands on it
Hi, I try to rebuild software from opensbi, uboot, Linux, rootfs, and emulate with Renode. Do you have any get starting documents?
This should help to compile:
https://wiki.seeedstudio.com/BeagleV-Make-File-System-Compile-uboot-Kernal/
@pzierhoffer any advice on how to use that in Renode?
