enable hdmi in console images
Hi to all of you,
I am using a rev B with 1gb emmc and I have booted with the console image of buster, but I have not been able to have any hdmi output what so ever.
When I am booting with AM3358 Debian 10.3 2020-04-06 4GB SD IoT I have my hdmi monitor working fine
dogtag:[BeagleBoard.org Debian Buster IoT Image 2020-04-06]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2019.04-00002-g07d5700e21]:[location: dd MBR]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2019.04-g1da4564]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-boneblack-uboot-univ.dts]
UBOOT: Loaded Overlay:[AM335X-PRU-RPROC-4-19-TI-00A0]
UBOOT: Loaded Overlay:[BB-ADC-00A0]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0]
UBOOT: Loaded Overlay:[BB-HDMI-TDA998x-00A0]
kernel:[4.19.94-ti-r42]
nodejs:[v10.15.2]
/boot/uEnv.txt Settings:
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade ]
pkg:[bb-cape-overlays]:[4.14.20200403.0-0rcnee0~buster+20200403]
pkg:[bb-wl18xx-firmware]:[1.20200322.0-0rcnee0~buster+20200322]
pkg:[kmod]:[26-1]
pkg:[librobotcontrol]:[1.0.4-git20190227.1-0rcnee0~buster+20190327]
pkg:[firmware-ti-connectivity]:[20190717-2rcnee1~buster+20200305]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal bluetooth netdev i2c gpio pwm eqep remoteproc admin spi iio docker tisdk weston-launch xenomai cloud9ide]
cmdline:[console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote…
whike my console image has
debian@beaglebone:~$ sudo /opt/scripts/tools/version.sh
git:/opt/scripts/:[721f317b40aabe880c34e8e16311812eeb464ce4]
eeprom:[A335BNLT000B1114BBBK1897]
dogtag:[BeagleBoard.org Debian Buster Console Image 2021-09-01]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot SPL 2019.04-g1da4564 (Aug 31 2021 - 14:32:40 +0000)]:[location: dd MBR]
UBOOT: Loaded Overlay:[BB-ADC-00A0.bb.org-overlays]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0.bb.org-overlays]
UBOOT: Loaded Overlay:[BB-HDMI-TDA998x-00A0.bb.org-overlays]
kernel:[4.19.94-ti-r66]
uboot_overlay_options:[uboot_overlay_pru=AM335X-PRU-RPROC-4-19-TI-00A0.dtbo]
pkg:[bb-cape-overlays]:[4.14.20210821.0-0~buster+20210821]
pkg:[bb-customizations]:[1.20210810.1-0~buster+20210810]
pkg:[bb-usb-gadgets]:[1.20210902.0-0~buster+20210902]
pkg:[bb-wl18xx-firmware]:[1.20210901.0-0~buster+20210901]
pkg:[kmod]:[26-1]
WARNING:pkg:[librobotcontrol]:[NOT_INSTALLED]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal input bluetooth netdev gpio admin tisdk weston-launch cloud9ide]
cmdline:[console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait optargs=quiet drm.debug=7 consoleblank=0 video=HDMI-A-1:640x480M@60]
dmesg | grep remote
If I am correct The previous two outputs show that both versions come up with the same overlays.
I have also tried to have the default resolution defined but no result.
I would appreciate any help or hint
Kind regards
Dimitris
I think you need to change in uEnv.txt file.
go to:
debian@beaglebone:~$ nano /boot/uEnv.txt
then comment below lines:
disable_uboot_overlay_video=1
disable_uboot_overlay_audio=1
Next:
Ctrl-x(save).
Final:
debian@beaglebone:~$ sudo reboot
After Rebooting Beaglebone. your problem will be solved.
Hi Raj,
My respective lines are commented anyhow but there is no video. In case there was some misconception, I also tried to comment also out and in with sequential reboots but nothing come out .
Cheers
Dimitris
