Hi, all:
I’ve been stuck at RTL8192CU wireless connection on my beaglebone. I tried the solution here http://gencarelle.com/blog/2013/07/19/problems-with-rtl8188cus/ . With the wired connection, the current situation on my beaglebone is like:
1)
ubuntu@arm:~$ lsusb
Bus 001 Device 002: ID 0bda:8178 Realtek Semiconductor Corp. RTL8192CU 802.11n WLAN Adapter
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
ubuntu@arm:~$ lsmod | grep 8192
8192cu 535620 0
ubuntu@arm:~$ cat /etc/network/interfaces
This file describes the network interfaces available on your system
and how to activate them. For more information, see interfaces(5).
The loopback network interface
auto lo
iface lo inet loopback
The primary network interface
auto eth0
iface eth0 inet dhcp
Example to keep MAC address between reboots
#hwaddress ether DE:AD:BE:EF:CA:FE
WiFi Example
auto wlan0
iface wlan0 inet dhcp
wpa-ssid “MYSSID”
wpa-psk “PASSWORD”
Ethernet/RNDIS gadget (g_ether)
… or on host side, usbnet and random hwaddr
iface usb0 inet static
address 192.168.1.50
netmask 255.255.255.0
network 192.168.1.0
gateway 192.168.1.1
ubuntu@arm:~$ ifconfig
eth0 Link encap:Ethernet HWaddr d4:94:a1:8e:d6:eb
inet addr:192.168.1.41 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::d694:a1ff:fe8e:d6eb/64 Scope:Link
RX packets:330 errors:0 dropped:0 overruns:0 frame:0
TX packets:244 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:32330 (32.3 KB) TX bytes:31436 (31.4 KB)
Interrupt:56
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
usb0 Link encap:Ethernet HWaddr 9a:e2:fb:a9:24:de
inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252
UP BROADCAST MULTICAST MTU:1500 Metric:1
wlan0 Link encap:Ethernet HWaddr 00:e0:4c:14:4b:30
My questions are:
- What is usb0? Is it corresponding to the usb wireless adapter? But, I think the usb wireless adapter should be corresponding to wlan0 .
- My own intranet’s gateway is: 192.168.1.1 . I just want to realize wireless connection by using my RTK8192CU USB wireless adapter, instead of the Wired connection. How should I proceed?? The current phenomenon is: whenever I plugged out the Wired connection, my router seems to be unable to detect the wireless device on this beaglebone. However, if I plugged the wire into my beaglebone, I got the above quoted phenomenon, but still, no wireless connection.
Can anybody help please?
Best Regards
Pei
