Enable Wireless (Wi-Fi) interface for beagleplay yocto meta-ti-bsp
hostapd.conf
interface=wlan0
#If this fails, try rt1871xdrv a
driver=nl80211
# Name of the new network: best use the hostname
ssid=wifipi
# Pick a channel not already in use
channel=6
# Change to b for older devices?
hw_mode=g
macaddr_acl=0
auth_algs=3
# Disable this to insure the AP is visible:
ignore_broadcast_ssid=0```
Running hostapd and giving driver error
hostapd -dd -K hostapd.conf
random: Trying to read entropy from /dev/random
Configuration file: hostapd.conf
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-14-72:1
nl80211: Supports Probe Response offload in AP mode
nl80211: Using driver-based off-channel TX
nl80211: Driver-advertised extended capabilities (default) - hexdump(len=8): 04 00 00 00 00 00 00 40
nl80211: Driver-advertised extended capabilities mask (default) - hexdump(len=8): 04 00 00 00 00 00 00 40
nl80211: Supported vendor command: vendor_id=0x80028 subcmd=0
nl80211: Supported vendor command: vendor_id=0x80028 subcmd=1
nl80211: Supported vendor command: vendor_id=0x80028 subcmd=2
nl80211: Supported vendor event: vendor_id=0x80028 subcmd=0
nl80211: Supported vendor event: vendor_id=0x80028 subcmd=1
nl80211: Use separate P2P group interface (driver advertised support)
nl80211: Enable multi-channel concurrent (driver advertised support)
nl80211: use P2P_DEVICE support
nl80211: key_mgmt=0x1fd0f enc=0xf auth=0x7 flags=0x4000511f363fae0 rrm_flags=0x10 probe_resp_offloads=0x7 max_stations=0 max_remain_on_chan=30000 max_scan_ssids=1
nl80211: interface wlan0 in phy phy0
nl80211: Set mode ifindex 5 iftype 3 (AP)
nl80211: Setup AP(wlan0) - device_ap_sme=0 use_monitor=0
nl80211: Subscribe to mgmt frames with AP handle 0xaaaafa1c8200
nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0xaaaafa1c8200 match= multicast=0
nl80211: kernel reports: Match already configured
nl80211: Register frame command failed (type=176): ret=-114 (Operation already in progress)
nl80211: Register frame match - hexdump(len=0): [NULL]
nl80211: Could not configure driver mode
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
nl80211: Remove monitor interface: refcount=0
nl80211: Remove beacon (ifindex=5)
netlink: Operstate: ifindex=5 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
nl80211 driver initialization failed.
hostapd_interface_deinit_free(0xaaaafa1c5e50)
hostapd_interface_deinit_free: num_bss=1 conf->num_bss=1
hostapd_interface_deinit(0xaaaafa1c5e50)
wlan0: interface state UNINITIALIZED->DISABLED
hostapd_bss_deinit: deinit bss wlan0
wlan0: AP-DISABLED
hostapd_cleanup(hapd=0xaaaafa1c75e0 (wlan0))
wlan0: CTRL-EVENT-TERMINATING
hostapd_free_hapd_data: Interface wlan0 wasn't started
hostapd_interface_deinit_free: driver=(nil) drv_priv=(nil) -> hapd_deinit
hostapd_interface_free(0xaaaafa1c5e50)
hostapd_interface_free: free hapd 0xaaaafa1c75e0
hostapd_cleanup_iface(0xaaaafa1c5e50)
hostapd_cleanup_iface_partial(0xaaaafa1c5e50)
hostapd_cleanup_iface: free iface=0xaaaafa1c5e50
I have created SoftAp0 interface and AP is coming
Creating SoftAp0 interface
iw phy phy0 interface add SoftAp0 type managed
ip link set dev SoftAp0 up
ip addr add 192.168.8.1/24 broadcast 192.168.8.255 dev SoftAp0
hostapd.conf
interface=SoftAp0
ssid=BeaglePlay_24G
auth_algs=1
wpa=2
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
wpa_passphrase=Beagleplay
hw_mode=g
channel=1
ieee80211d=1
country_code=IN
ieee80211n=1
wmm_enabled=1
macaddr_acl=0
logger_syslog=-1
logger_syslog_level=2
hostapd -B hostapd.conf
Access point visible for desktop and able to connect AP to Laptop and mobile.
Changes these two variable to create 5GHz Access point
hw_mode=a
channel=36
