Dear all,
I’m currently working on a IEEE802.11s WSN using 5 BBBs and a TP-Link stick. To evaluate the wireless link I need to get more information on the wireless link. Therefore, I want to enable the debugfs option of the ATH9k driver module (because just enabling the debug mode using ‘modprobe ath9k_htc debug=0xffffffff’ didn’t work for me).
I think I will have to recompile the ath9k module and some related modules. As far as I understand all what I need for that is part of the backports project [1]. I have already used this on Android for another purpose and everything worked fine. BUT, I will need the kernel source for the compiling process! Where to get the source? (I used Roberts update_kernel.sh script to upgrade my kernel to 3.19)
Another possibility would be to compile a kernel and using make menuconfig to configure the modules. But therefore I would also need the kernel source. I really want to use Robert Nelsons version because I will also need to use DTBs for CAN.
Can anyone help me out here? What would be better/easier?
Thanks a lot in advance and best regards,
Marco
[1] https://www.kernel.org/pub/linux/kernel/projects/backports/
There's a repo here:
https://github.com/RobertCNelson/linux-stable-rcn-ee
Each release (uname -r) is tagged so:
git clone https://github.com/RobertCNelson/linux-stable-rcn-ee
cd ./linux-stable-rcn-ee
git checkout `uname -r` -b tmp
so I just can use this source without any patches or something like that?
I will just try to use:
1.) make menuconfig
2.) make
3.) make install
is this right?
Best regards and thanks for your help,
Marco
Yeap, all the patches are in the tag... The default config is: rcn-ee_defconfig
1.) make menuconfig
2.) make
3.) make install
is this right?
However, make install won't install the files in the correct place..
make ARCH=arm LOCALVERSION=-<some value> CROSS_COMPILE=
KBUILD_DEBARCH=armhf deb-pkg
Then install the *.deb
Dear Robert,
thanks for your help - again!
Yeap, all the patches are in the tag… The default config is: rcn-ee_defconfig
This is great! Makes things much easier!
make ARCH=arm LOCALVERSION=- CROSS_COMPILE=
I’m not really sure here: Does this mean that the compiling will be done on the BBB or crosscompile on another PC? But I will need to install a toolchain for that rigth? This one: 'gcc-arm-linux-gnueabi
I also tried to comple my backports (directly on the BBB). Therefore, I used KLIB and KLIB_BUILD to point to the kernel source. But this didn’t worked for me. But maybe also a problem with missing tools / toolchain. Has anyone expiriences with backports on BBB?
Thanks for all your help!!! Really great!!!
Best regards,
Marco
Dear Robert,
rcn-ee_defconfig
I'm not really sure here: Does this mean that the compiling will be done on
toolchain for that rigth? This one: 'gcc-arm-linux-gnueabi'?
If on the "BBB" just use: CROSS_COMPILE=
If on an x86, use: CROSS_COMPILE=/path/to/bin/gcc
KLIB and KLIB_BUILD to point to the kernel source. But this didn't worked
debian backport repo?
Hi Robert,
thank you - I will try To compile the kernel tomorrow.
Backports: https://backports.wiki.kernel.org/index.php/Documentation
I’m not sure if it is also part of the Debian backport repo. It’s mainly about wireles: 80211, Bluetooth, …
Thanks again and besteht regards,
Marco
Dear Robert, dear all,
compiling the kernel directly on the BBB took the whole last day (maybe also because of some errors during build: missing packages & some file where corrupted or missing).
For all which also want to do that these are the required steps:
Prerequirements (at least):
- apt-get install ncurses-dev
- apt-get install bc
- apt-get install lzop
1.) Download kernel source from:
2.) load def-config
make ARCH=arm LOCALVERSION=1.0 CROSS_COMPILE= rcn-ee_defconfig
2.) make menuconfig
→ I wanted to enable the debugfs option for the ATH9k driver module (see link below). But you have A LOT possibilities to change your kernel here.
https://wireless.wiki.kernel.org/en/users/Drivers/ath9k/debug
3.)
make ARCH=arm LOCALVERSION=1.0 CROSS_COMPILE= KBUILD_DEBARCH=armhf deb-pkg
@Robert or other experts: are the commands and the order correct?
Now I have four deb files:
- linux-firmware-image-XYZ.deb
- linux-headers-XYZ.deb
- linux-image-XYZ.deb
- linux-libc-dev-XYZ.deb
To install the new kernel I think I will just have to use
dpkg --install *.deb (in the subdirectory where the .deb files are located). Is this ok? Or do I have to think about the right order when installing the deb files?
Or something else to think about after installing the deb files?
Will this also install all the driver modules (the main reason while I’m doing all this)? (on my linux PC I installed my kernel AND had to use ‘make module_install’)
I hope you can help me with that once again!
Thanks in advance and best regards,
Marco
Hi all,
for all who wants to compile and install a custom build kernel, these are that required steps: (configure and build was done directly on the BBB)
2.) load def-config
2.) make menuconfig
3.) compiling the kernel
4.) install the deb file and reboot
Best regards,
Marco
@Robert: Thanks again for your great help!!!
