I have trying to enable LCD 7 inch cape with beaglebone black board. I am using Yocto Daisy. And linux kernel 3.14. Could you please help to enable LCD.
DMESG:
matchbox: Cant find a keycode for keysym 269025050
matchbox: ignoring key shortcut XF86Start=!matchbox-remote -desktop
[settings daemon] Forking. run with -n to prevent fork
** (matchbox-panel:530): WARNING **: Failed to load applet “battery” (/usr/lib/matchbox-panel/libbattery.so: cannot open shared object file: No such file or directory).
tilcdc 4830e000.lcdc: timeout waiting for framedone
After going through the source of LInux Kernel 3.14, I have identified, there is missing driver in git.yoctoproject.org.linux-yocto-3.14/drivers/video/omap2/displays-new/. Do we require a panel driver over here or just modifying the dts to include panel node with
compatible string “ti,tilcdc,panel” is sufficient for enabling beaglebone black cape 7 inch LCD>
( Is this a right mailing list for asking these questions? If not could you please suggest the mailing list for asking the same. )
Those are for the "omapdss" ip block, not found on the am335x.
Do
panel node with
compatible string "ti,tilcdc,panel" is sufficient for enabling beaglebone
You need to modify your dts for that lcd simliar to:
