Enabling UART0 on BB-AI64
I am trying to get uart0 (pin 9_11 and 9_13) working on the bb-ai64. I want those pins using uart because of my cape.
I follow the same steps from my previous post https://forum.beagleboard.org/t/need-help-enabling-uart-on-ai64/34844.
Except I add BONE_UART0.dts and include it in extlinux.conf and also see that it got loaded on reboot.
&{/chosen} {
	overlays {
		BONE-UART0.kernel = __TIMESTAMP__;
&bone_uart_0 {
	status = "okay";
I also edit k3-j721e-beagleboneai64-bone-buses.dtsi with:
bone_uart_0: &main_uart0 {
	pinctrl-names = "default";
	pinctrl-0 = <
		&P9_11_uart_pin /* uart0_rxd */
		&P9_13_uart_pin /* uart0_txd */
	symlink = "bone/uart/0";
	status = "okay";
I realized that P9_11 p9_13 had a beat using my logic analyzer which I think is caused by BONE_LED_P9_11.dts in arm64/overlays/? But I did not include the dtbo file in extlinux.conf and the beat was still there after deleting the file. Or is it caused by the line in extlinux.conf “append console=ttyS2,115200n8” in ttyS2 since uart0 is using the same link?
I found this online. https://docs.beagleboard.org/latest/boards/capes/cape-interface-spec.html
and…one of the three pin headers is for seeing boot logs while the other one is for a very specific boot log having to do w/ security (I think). Introduction — TISCI User Guide
P.S. I am not sure if UART0 is completely available b/c of the boot log usage dedication. I am sure others that are behind the building of the board will introduce more in time. I am sort of guessing here but familiarity w/ the am335x and UART0 being the debug header makes me think it is similar on this board but I could be severely mistaken.
Update
https://docs.beagleboard.org/latest/boards/capes/cape-interface-spec.html#id38
Thanks for the documentation. That’s interesting. Now i’m wondering if it’s possible to disable the console debug or to move it to a different uart.
If you really need to use UART0 then depending on what you have hooked up to it and what it does when it gets input, you will need to -
  1. modify and recompile u-boot so that it does not use UART0
  2. Remove the console= from the kernel command line, passed by u-boot
  3. modify linux so it does not start up a tty on the serial port. Probably a Systemd config somewhere (used to be in inittab when using SYSV init)
If whatever you have connected can live with a little spam on the UART, you could skip step 1.
That can be turned off in the kernel.
I was referring to u-boot debug text, which can only be stopped y recompiling u-boot.
Yes, correct. The kernel config also has settings to customize the messages sent out. It just depends on how far one needs to go.
Thanks for all the help.
So I removed the “console=…” from the kernel command line and also stopped the systemd services. Specifically the serial-getty@ttyS2.service and serial-getty@ttyGS0.service on boot.
I am not sure what to modify in the u-boot. I tried removing the default pins uart0 controls. But I am still getting the console debug output on the pins.
Ok I was looking at the schematic for the bbai64 and I was wrong, you don’t need to modify u-boot at all.
The debug serial console output from uart0 on the debug pins is actually muxed to different pins from uart0 on P9.11 & P9.13
In which case just disabling the console in linux and of course loading the correct pinmux overlay should be enough to make uart0 available.
