from Adafruit_BBIO.Encoder import RotaryEncoder, eQEP2
import time
Instantiate the class to access channel eQEP2, and initialize
that channel
myEncoder = RotaryEncoder(eQEP2)
Get the current position
while True:
cur_position = myEncoder.position
print(cur_position)
time.sleep(1)
But I get the following error:
Traceback (most recent call last):
File “./eQEP.py”, line 8, in
File “/usr/local/lib/python3.7/dist-packages/Adafruit_BBIO-1.1.1-py3.7-linux-armv7l.egg/Adafruit_BBIO/Encoder.py”, line 195, in init
self._eqep = _eQEP.fromdict(_eQEP_DEFS[eqep_num])
File “/usr/local/lib/python3.7/dist-packages/Adafruit_BBIO-1.1.1-py3.7-linux-armv7l.egg/Adafruit_BBIO/Encoder.py”, line 126, in fromdict
return cls(**df)
File “/usr/local/lib/python3.7/dist-packages/Adafruit_BBIO-1.1.1-py3.7-linux-armv7l.egg/Adafruit_BBIO/Encoder.py”, line 150, in init
self.node = Node(sys_path)
File “/usr/local/lib/python3.7/dist-packages/Adafruit_BBIO-1.1.1-py3.7-linux-armv7l.egg/Adafruit_BBIO/sysfs.py”, line 78, in init
self.dict.update(dict.fromkeys(listdir(self.path)))
FileNotFoundError: [Errno 2] No such file or directory: ‘/sys/devices/platform/ocp/48304000.epwmss/48304180.eqep’
I’m running the current image. cat /ID.txt BeagleBoard.org Debian Buster IoT Image 2020-04-06 uname -a
Linux pocket 4.19.94-ti-r42 #1buster SMP PREEMPT Tue Mar 31 19:38:29 UTC 2020 armv7l GNU/Linux
