I am trying to run this: bitbake console-image
However I am getting the following error stack:
(any help?)
BEGIN failed--compilation aborted at /home/arthurnn/setup-scripts/
build/tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/bin/glib-
mkenums line 4.
make[2]: *** [stamp-typebuiltins.h] Error 255
make[2]: Leaving directory `/home/arthurnn/setup-scripts/build/tmp-
angstrom_2010_x-eglibc/work/armv7a-angstrom-linux-gnueabi/gtk+-2.24.8-
r2/gtk+-2.24.8/perf'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/arthurnn/setup-scripts/build/tmp-
NOTE: package gtk+-2.24.8-r2: task do_compile: Failed
ERROR: Task 2835 (/home/arthurnn/setup-scripts/sources/openembedded-
core/meta/recipes-gnome/gtk+/gtk+_2.24.8.bb, do_compile) failed with
exit code '1'
Waiting for 1 active tasks to finish:
0: vala-native-0.12.1-r0 do_configure (pid 9961)
NOTE: package vala-native-0.12.1-r0: task do_configure: Started
ERROR: Function failed: do_configure (see /home/arthurnn/setup-scripts/
build/tmp-angstrom_2010_x-eglibc/work/i686-linux/vala-native-0.12.1-r0/
temp/log.do_configure.9961 for further information)
ERROR: Logfile of failure stored in: /home/arthurnn/setup-scripts/
Log data follows:
+ cd /home/arthurnn/setup-scripts/build/tmp-angstrom_2010_x-eglibc/
work/i686-linux/vala-native-0.12.1-r0/vala-0.12.1
+ do_configure
+ autotools_do_configure
+ find /home/arthurnn/setup-scripts/build/tmp-angstrom_2010_x-eglibc/
work/i686-linux/vala-native-0.12.1-r0/vala-0.12.1 -name configure.in -
o -name configure.ac
+ dirname /home/arthurnn/setup-scripts/build/tmp-angstrom_2010_x-
eglibc/work/i686-linux/vala-native-0.12.1-r0/vala-0.12.1/configure.ac
+ rm -f /home/arthurnn/setup-scripts/build/tmp-angstrom_2010_x-
+ [ -e /home/arthurnn/setup-scripts/build/tmp-angstrom_2010_x-eglibc/
work/i686-linux/vala-native-0.12.1-r0/vala-0.12.1/configure.in -o -e /
home/arthurnn/setup-scripts/build/tmp-angstrom_2010_x-eglibc/work/i686-
linux/vala-native-0.12.1-r0/vala-0.12.1/configure.ac ]
+ pwd
+ olddir=/home/arthurnn/setup-scripts/build/tmp-angstrom_2010_x-
+ [ xdefault = xdefault ]
+ acpaths=
+ + sort -u
sed -e s,\(.*/\).*$,\1,
+ grep -v acinclude.m4
+ grep -v aclocal.m4
work/i686-linux/vala-native-0.12.1-r0/vala-0.12.1 -maxdepth 2 -name
*.m4
+ acpaths= -I /home/arthurnn/setup-scripts/build/tmp-angstrom_2010_x-
eglibc/work/i686-linux/vala-native-0.12.1-r0/vala-0.12.1/ -I /home/
linux/vala-native-0.12.1-r0/vala-0.12.1/m4/
+ sed+ s/.* //;s/\.[0-9]\+$//
head -n 1
+ automake --version
syntax error at /usr/share/perl/5.12/File/Basename.pm line 138, near
""AmigaOS" {"
syntax error at /usr/share/perl/5.12/File/Basename.pm line 142, near
"elsif"
Global symbol "$type" requires explicit package name at /usr/share/
perl/5.12/File/Basename.pm line 142.
Global symbol "$dirpath" requires explicit package name at /usr/
share/perl/5.12/File/Basename.pm line 143.
Global symbol "$basename" requires explicit package name at /usr/
Global symbol "$fullname" requires explicit package name at /usr/
share/perl/5.12/File/Basename.pm line 144.
syntax error at /usr/share/perl/5.12/File/Basename.pm line 145, near
share/perl/5.12/File/Basename.pm line 147.
Global symbol "$orig_type" requires explicit package name at /usr/
share/perl/5.12/File/Basename.pm line 148.
share/perl/5.12/File/Basename.pm line 153.
share/perl/5.12/File/Basename.pm line 154.
share/perl/5.12/File/Basename.pm line 155.
share/perl/5.12/File/Basename.pm line 157.
syntax error at /usr/share/perl/5.12/File/Basename.pm line 158, near
/usr/share/perl/5.12/File/Basename.pm has too many errors.
Compilation failed in require at /home/arthurnn/setup-scripts/build/
tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/shERROR: Function
failed: do_configure (see /home/arthurnn/setup-scripts/build/tmp-
angstrom_2010_x-eglibc/work/i686-linux/vala-native-0.12.1-r0/temp/
are/automake-1.11/Automake/General.pm line 21.
build/tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/share/
tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/bin/automake line
145.
build/tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/bin/automake
line 145.
+ AUTOV=
""AmigaOS" {"
"elsif"
tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/share/automake-1.11/
145.
line 145.
NOTE: package vala-native-0.12.1-r0: task do_configure: Failed
ERROR: Task 1062 (virtual:native:/home/arthurnn/setup-scripts/sources/
meta-openembedded/meta-oe/recipes-devtools/vala/vala_0.12.1.bb,
do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2418 tasks of which 2416 didn't need to
be rerun and 2 failed.
work/armv7a-angstrom-linux-gnueabi/bblayers-1.0-r0/bblayers-1.0
+ buildhistory_commit
+ [ ! -d /home/arthurnn/setup-scripts/build/tmp-angstrom_2010_x-eglibc/
buildhistory ]
buildhistory/
+ [ ! -d .git ]
+ git status --porcelain
+ repostatus=
Summary: 2 tasks failed:
/home/arthurnn/setup-scripts/sources/openembedded-core/meta/recipes-
virtual:native:/home/arthurnn/setup-scripts/sources/meta-
do_configure
Summary: There were 2 ERROR messages shown, returning a non-zero exit
code.
arthurnn@arthurnn-VirtualBox:~/setup-scripts$
