Hello Everyone
I was trying to compile a Linux kernel with DSP Bridge Driver support
Using Resources given below
[1]: http://elinux.org/BeagleBoard#Linux_kernel
[2]: http://elinux.org/BeagleBoard/DSP_Howto
[3]: http://omappedia.org/wiki/DSPBridge_Project
am using Ubuntu 10.04 with Sourcery G++ Lite 2010q1-202 also I've set
environment variable CROSS_COMPILE=arm-none-linux-gnueabi- and
ARCH=arm
Then Executed following commands
$git clone git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6.git
$cd linux-omap-2.6
$make CROSS_COMPILE=$CROSS_COMPILE omap2plus_defconfig
$make CROSS_COMPILE=$CROSS_COMPILE menuconfig #enabled Dspbridege as
a module
$make CROSS_COMPILE=$CROSS_COMPILE uImage
and i got uImage on arch/arm/boot/
Then i issued
$make CROSS_COMPILE=$CROSS_COMPILE modules
after some drivers it comes to DSPBridge and end up with an error
which is shown below
CC [M] drivers/staging/tidspbridge/gen/gb.o
CC [M] drivers/staging/tidspbridge/gen/gs.o
CC [M] drivers/staging/tidspbridge/gen/gh.o
CC [M] drivers/staging/tidspbridge/gen/uuidutil.o
CC [M] drivers/staging/tidspbridge/services/sync.o
CC [M] drivers/staging/tidspbridge/services/cfg.o
CC [M] drivers/staging/tidspbridge/services/ntfy.o
CC [M] drivers/staging/tidspbridge/services/services.o
CC [M] drivers/staging/tidspbridge/core/chnl_sm.o
CC [M] drivers/staging/tidspbridge/core/msg_sm.o
CC [M] drivers/staging/tidspbridge/core/io_sm.o
drivers/staging/tidspbridge/core/io_sm.c: In function
'bridge_io_on_loaded':
drivers/staging/tidspbridge/core/io_sm.c:801: warning: the frame size
of 1032 bytes is larger than 1024 bytes
CC [M] drivers/staging/tidspbridge/core/tiomap3430.o
drivers/staging/tidspbridge/core/tiomap3430.c:24: fatal error: plat/
control.h: No such file or directory
compilation terminated.
make[3]: *** [drivers/staging/tidspbridge/core/tiomap3430.o] Error 1
make[2]: *** [drivers/staging/tidspbridge] Error 2
make[1]: *** [drivers/staging] Error 2
make: *** [drivers] Error 2
So its look like control.h is missing. how can i resolve this? Is
there any Mistakes in my approach?
