Trying to build u-boot for BeagleV-Fire, but obtained the following ERROR messages:
arch/riscv/cpu/start.S:98: Error: illegal operands `li t1,(CFG_SYS_INIT_RAM_ADDR+CFG_SYS_INIT_RAM_SIZE-400)'
CC arch/riscv/lib/interrupts.o
CC arch/riscv/lib/reset.o
In file included from include/config.h:3,
from include/common.h:16,
from arch/riscv/cpu/cpu.c:6:
include/configs/microchip_mpfs_icicle.h:15: warning: "CONFIG_SYS_BOOTM_LEN" redefined
15 | #define CONFIG_SYS_BOOTM_LEN SZ_64M
In file included from ././include/linux/kconfig.h:4,
from <command-line>:
include/generated/autoconf.h:142: note: this is the location of the previous definition
142 | #define CONFIG_SYS_BOOTM_LEN 0x800000
CC arch/riscv/lib/fdt_fixup.o
AS arch/riscv/lib/setjmp.o
make[1]: *** [scripts/Makefile.build:292: arch/riscv/cpu/start.o] Error 1
make[1]: *** Waiting for unfinished jobs....
AS arch/riscv/lib/memset.o
AS arch/riscv/lib/memmove.o
AS arch/riscv/lib/memcpy.o
AS arch/riscv/lib/crt0_riscv_efi.o
CC boot/bootm.o
CC arch/riscv/lib/reloc_riscv_efi.o
CC boot/bootm_os.o
from arch/riscv/lib/boot.c:7:
CC common/splash.o
make: *** [Makefile:1853: arch/riscv/cpu] Error 2
AR drivers/cache/built-in.o
make: *** Waiting for unfinished jobs....
CC common/menu.o
Noticed in file ....../u-boot/include/system-constants.h:
#ifdef CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR
#define SYS_INIT_SP_ADDR CONFIG_CUSTOM_SYS_INIT_SP_ADDR
#else
#ifdef CONFIG_MIPS
#define SYS_INIT_SP_ADDR (CFG_SYS_SDRAM_BASE + CFG_SYS_INIT_SP_OFFSET)
#else
#define SYS_INIT_SP_ADDR \
(CFG_SYS_INIT_RAM_ADDR + CFG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
#endif
#endif
Shall we define a customized CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR in an extra microchip_beaglev_fire_defconfig ???
Cheers
