While testing a 7 Segment Click, I found an error in am335x-pocketbeagle.dts: The mode for P2_25 (SPI1 MOSI) should be 4 (spi1_d1), not 5 (spi1_cs0).
@@ -660,7 +660,7 @@
/* P2_25 (ZCZ ball E17) */
P2_25_default_pin: pinmux_P2_25_default_pin { pinctrl-single,pins = <
- AM33XX_IOPAD(0x096c, PIN_OUTPUT_PULLUP | INPUT_EN | MUX_MODE5) >; }; /* uart0_rtsn.spi1_cs0 */
- AM33XX_IOPAD(0x096c, PIN_OUTPUT_PULLUP | INPUT_EN | MUX_MODE4) >; }; /* uart0_rtsn.spi1_d1 /
P2_25_gpio_pin: pinmux_P2_25_gpio_pin { pinctrl-single,pins = <
AM33XX_IOPAD(0x096c, PIN_OUTPUT | INPUT_EN | MUX_MODE7) >; }; / uart0_rtsn.gpio1_9 /
P2_25_gpio_pu_pin: pinmux_P2_25_gpio_pu_pin { pinctrl-single,pins = <
@@ -668,7 +668,7 @@
P2_25_gpio_pd_pin: pinmux_P2_25_gpio_pd_pin { pinctrl-single,pins = <
AM33XX_IOPAD(0x096c, PIN_OUTPUT_PULLDOWN | INPUT_EN | MUX_MODE7) >; }; / uart0_rtsn.gpio1_9 */
P2_25_spi_pin: pinmux_P2_25_spi_pin { pinctrl-single,pins = <
P2_25_i2c_pin: pinmux_P2_25_i2c_pin { pinctrl-single,pins = <
AM33XX_IOPAD(0x096c, PIN_OUTPUT_PULLUP | INPUT_EN | MUX_MODE3) >; }; / uart0_rtsn.I2C1_SCL */
P2_25_uart_pin: pinmux_P2_25_uart_pin { pinctrl-single,pins = <
Hi Philip,
@@ -660,7 +660,7 @@
+ AM33XX_IOPAD(0x096c, PIN_OUTPUT_PULLUP | INPUT_EN | MUX_MODE4) >; }; /*
uart0_rtsn.spi1_d1 */
AM33XX_IOPAD(0x096c, PIN_OUTPUT | INPUT_EN | MUX_MODE7) >; }; /*
@@ -668,7 +668,7 @@
AM33XX_IOPAD(0x096c, PIN_OUTPUT_PULLDOWN | INPUT_EN | MUX_MODE7) >; }; /*
AM33XX_IOPAD(0x096c, PIN_OUTPUT_PULLUP | INPUT_EN | MUX_MODE3) >; }; /*
Thanks for testing!
Just merged the same fix, just a moment ago..
"tools/pinmux-generator/PocketBeagle.dts"
I've split the "spi" to, spi, spi_cs, spi_sclk (and also brought the
can pins out)
i'll have updated 4.4.x/4.9.x/4.14.x-ti kernels out later today, with
this new default..
