I am using beagle board Rev C and I want to debug an application on it
using the gdb-server and runtime libraries provided by code sourcery.
I am using code sourcery IDE for arm GNU/Linux -172 .
following are the connection on my beagle board:
one serial cable from beagle board conncted to linux host machine and
usb to serial converter on beagle board connected to serial on host
machine.
I am getting the error on debuggging and target gets hang.
I have copied sysroot files and I can run the sample code that is
given with the code sourcery sample programs but I am getting error in
debugging.
This is the output on bealge board shell:
root@beagleboard:/sysroot/usr/lib/bin# sysroot-run /
sample1
HelloWorld!
root@beagleboard:/sysroot/usr/lib/bin# sysroot-gdbserver :10000 /
sample1
Process /sample1 created; pid =
9700
Listening on port 10000
+$Hg0#dfc-1#09$qC#b4+$s#4b-+
I am getting above error when in the dedug configuration/ debugger/
connection I have set
type: Serial
Device: /dev/ttyS0
Speed: 115200
Also in the console pane I am getting:
in the console pane i am getting:
warning: unrecognized item "qSupported" in "qSupported" response
Ignoring packet error, continuing...
after some time I get following error:
"launching sample1" has encountered a problem.
Target selection Failed.
Malformed response to offset query,timeout
Can anyone tell me the settings necessary for solving these errors?
Ritika
