I installed the latest angstrom demo image on beagleboard rev C4 using
SD card. Logged in as root. Pico projector is connected to HDMI port
and shows the login screen. I have a serial port connected with tera
term pro and a mouse and keyboard connected to beagleboard. I can play
the included BigBunny movie on pico projector.
However, running bus3-i2c or picodlp command gives the following error
root@beagleboard:/dev# bus3-i2c 0x1b wb4 0x08 0xf0000000
ERROR: I2cTransfer: ioctl failed: Input/output error (5)
ERROR: I2cWriteBytes failed: -1
root@beagleboard:# picodlp-control hflip 1
How can I fix this?
thanks
Amit
