Hi, I am attempting to cross compile the Linux Kernel 4.20 to be loaded on my BeagleBone Black, however I am receiving the below error:
AS usr/initramfs_data.o
/tmp/cc6hWxZG.s: Assembler messages:
/tmp/cc6hWxZG.s:39: Error: selected processor does not support isb ' in ARM mode /tmp/cc6hWxZG.s:90: Error: selected processor does not support isb ’ in ARM mode
/tmp/cc6hWxZG.s:354: Error: selected processor does not support isb ' in ARM mode scripts/Makefile.build:291: recipe for target 'arch/arm/vfp/vfpmodule.o' failed make[1]: *** [arch/arm/vfp/vfpmodule.o] Error 1 Makefile:1060: recipe for target 'arch/arm/vfp' failed make: *** [arch/arm/vfp] Error 2 make: *** Waiting for unfinished jobs.... CC init/do_mounts_rd.o AR usr/built-in.a CC init/do_mounts_initrd.o /tmp/ccBVuroD.s: Assembler messages: /tmp/ccBVuroD.s:1680: Error: selected processor does not support cpsid i’ in ARM mode
/tmp/ccBVuroD.s:1819: Error: selected processor does not support cpsid i' in ARM mode /tmp/ccBVuroD.s:1876: Error: selected processor does not support cpsie i’ in ARM mode
/tmp/ccBVuroD.s:2073: Error: selected processor does not support cpsie i' in ARM mode scripts/Makefile.build:291: recipe for target 'init/main.o' failed make[1]: *** [init/main.o] Error 1 make[1]: *** Waiting for unfinished jobs.... /tmp/cc8dytlI.s: Assembler messages: /tmp/cc8dytlI.s:808: Error: selected processor does not support dmb ish’ in ARM mode
/tmp/cc8dytlI.s:811: Error: architectural extension mp' is not allowed for the current base architecture /tmp/cc8dytlI.s:812: Error: selected processor does not support pldw [r3]’ in ARM mode
/tmp/cc8dytlI.s:815: Error: selected processor does not support pld [r3]' in ARM mode /tmp/cc8dytlI.s:821: Error: selected processor does not support ldrex r2,[r3]’ in ARM mode
/tmp/cc8dytlI.s:823: Error: selected processor does not support strex r1,r2,[r3]' in ARM mode /tmp/cc8dytlI.s:828: Error: selected processor does not support dmb ish’ in ARM mode
scripts/Makefile.build:291: recipe for target ‘init/do_mounts.o’ failed
make[1]: *** [init/do_mounts.o] Error 1
Makefile:1060: recipe for target ‘init’ failed
make: *** [init] Error 2
ERROR
I am running the below commands, and it is crashing on line 14 “building the zImage”. Has anyone seen this problem before?
1 #!/bin/bash
2
3 PATH=${HOME}/x-tools/arm-cortex_a8-linux-gnueabihf/bin/:$PATH
4
5 cd linux-stable
6 if [ $? != 0 ]; then echo “ERROR”; exit; fi
7
8 make ARCH=arm CROSS_COMPILE=arm-cortex_a8-linux-gnueabihf- mrproper
9 if [ $? != 0 ]; then echo “ERROR”; exit; fi
10
11 make ARCH=arm multi_v7_defconfig
12 if [ $? != 0 ]; then echo “ERROR”; exit; fi
13
14 make -j4 ARCH=arm CROSS_COMPILE=arm-cortex_a8-linux-gnueabihf- zImage
15 if [ $? != 0 ]; then echo “ERROR”; exit; fi
16
17 make -j4 ARCH=arm CROSS_COMPILE=arm-cortex_a8-linux-gnueabihf- modules
18 if [ $? != 0 ]; then echo “ERROR”; exit; fi
19
20 make ARCH=arm CROSS_COMPILE=arm-cortex_a8-linux-gnueabihf- dtbs
21 if [ $? != 0 ]; then echo “ERROR”; exit; fi
22
