Hey everyone,
as the title says, when i include init.S in my project i get the following errors:
- undefined reference to `_bss_end’
- undefined reference to `_bss_start’
- undefined reference to `_stack’
Below i provide the file for your convenience…(just a reminder that i use the gcc compiler,GNU v4.8.4 (Linaro) and thus i take init.S from M335X_StarterWare_02_00_01_01/system_config/armv7a/gcc/)
Enter code here.@****************************** Global Symbols*********************************
.global Entry
.global _stack
.global _bss_start
.global _bss_end
.global start_boot
@************************ Internal Definitions ********************************
@ Define the stack sizes for different modes. The user/system mode will use
@ the rest of the total stack size
.set UND_STACK_SIZE, 0x8
.set ABT_STACK_SIZE, 0x8
.set FIQ_STACK_SIZE, 0x8
.set IRQ_STACK_SIZE, 0x800
.set SVC_STACK_SIZE, 0x8
@ to set the mode bits in CPSR for different modes
.set MODE_USR, 0x10
.set MODE_FIQ, 0x11
.set MODE_IRQ, 0x12
.set MODE_SVC, 0x13
.set MODE_ABT, 0x17
.set MODE_UND, 0x1B
.set MODE_SYS, 0x1F
.equ I_F_BIT, 0xC0
@**************************** Code Seection ***********************************
.text
@ This code is assembled for ARM instructions
.code 32
@ The reset handler in StarterWare is named as ‘Entry’.
@ The reset handler sets up the stack pointers for all the modes. The FIQ and
@ IRQ shall be disabled during this. Then clear the BSS sections and finally
@ switch to the function calling the main() function.
Entry:
@ Set up the Stack for Undefined mode
LDR r0, =_stack @ Read the stack address
MSR cpsr_c, #MODE_UND|I_F_BIT @ switch to undef mode
MOV sp,r0 @ write the stack pointer
SUB r0, r0, #UND_STACK_SIZE @ give stack space
@ Set up the Stack for abort mode
MSR cpsr_c, #MODE_ABT|I_F_BIT @ Change to abort mode
MOV sp, r0 @ write the stack pointer
SUB r0,r0, #ABT_STACK_SIZE @ give stack space
@ Set up the Stack for FIQ mode
MSR cpsr_c, #MODE_FIQ|I_F_BIT @ change to FIQ mode
SUB r0,r0, #FIQ_STACK_SIZE @ give stack space
@ Set up the Stack for IRQ mode
MSR cpsr_c, #MODE_IRQ|I_F_BIT @ change to IRQ mode
SUB r0,r0, #IRQ_STACK_SIZE @ give stack space
@ Set up the Stack for SVC mode
MSR cpsr_c, #MODE_SVC|I_F_BIT @ change to SVC mode
SUB r0,r0, #SVC_STACK_SIZE @ give stack space
@ Set up the Stack for USer/System mode
MSR cpsr_c, #MODE_SYS|I_F_BIT @ change to system mode
@ Invalidate and Enable Branch Prediction
MOV r0, #0
MCR p15, #0, r0, c7, c5, #6
ISB
MRC p15, #0, r0, c1, c0, #0
ORR r0, r0, #0x00000800
MCR p15, #0, r0, c1, c0, #0
@ Enable and initialise VFP and NEON
ORR r1, r1, #(0xf << 20) @ OR over CPACR read value so to enable CP’s
MCR p15, #0, r1, c1, c0, #2 @ Write to CPACR
MOV r1, #0
MCR p15, #0, r1, c7, c5, #4 @ flush prefetch buffer because of FMXR below
MOV r0,#0x40000000 @ and CP 10 & 11 were only just enabled
FMXR FPEXC, r0 ; FPEXC = r0 @ Enable VFP itself
@ Clear the BSS section here
Clear_Bss_Section:
LDR r0, =_bss_start @ Start address of BSS
LDR r1, =(_bss_end - 0x04) @ End address of BSS
MOV r2, #0
Loop:
STR r2, [r0], #4 @ Clear one word in BSS
CMP r0, r1
BLE Loop @ Clear till BSS end
@ Enter the start_boot function. The execution still happens in system mode.
@Enter_main:
LDR r10,=start_boot
MOV lr,pc @ Dummy return from start_boot
BX r10 @ Branch to start_boot
SUB pc, pc, #0x08 @ looping
@ End of the file
.end…
Does anyone know what to do?
Thanks in advance
